[PATCH v2 04/15] score: Move processor affinity to Thread_Control
Sun Jul 9 11:51:47 UTC 2017
On Fri, Jul 7, 2017 at 9:54 AM, Sebastian Huber
> Update #3059.
>  cpukit/score/Makefile.am                           |  1 -
>  cpukit/score/include/rtems/score/processormask.h   |  2 ++
>  cpukit/score/include/rtems/score/scheduler.h       | 27 ----------------
>  cpukit/score/include/rtems/score/schedulerimpl.h   | 14 --------
>  .../rtems/score/schedulerpriorityaffinitysmp.h     | 19 -----------
>  cpukit/score/include/rtems/score/thread.h          |  7 +++-
>  cpukit/score/src/processormaskcopy.c               |  2 ++
>  cpukit/score/src/schedulerdefaultgetaffinity.c     | 37 ----------------------
>  cpukit/score/src/schedulergetaffinity.c            | 30 ++++++------------
>  cpukit/score/src/schedulerpriorityaffinitysmp.c    | 23 --------------
>  cpukit/score/src/threadinitialize.c                |  1 +
>  testsuites/smptests/smpaffinity01/init.c           |  2 +-
>  testsuites/smptests/smppsxaffinity02/init.c        |  2 +-
>  testsuites/smptests/smpscheduler02/init.c          | 19 ++++++++---
>  14 files changed, 36 insertions(+), 150 deletions(-)
>  delete mode 100644 cpukit/score/src/schedulerdefaultgetaffinity.c
> diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
> index 1ac7c1545c..d2dd80d6f0 100644
> --- a/cpukit/score/Makefile.am
> +++ b/cpukit/score/Makefile.am
> @@ -161,7 +161,6 @@ libscore_a_SOURCES += src/smpmulticastaction.c
>  libscore_a_SOURCES += src/cpuset.c
>  libscore_a_SOURCES += src/cpusetprintsupport.c
>  libscore_a_SOURCES += src/schedulerdefaultaskforhelp.c
> -libscore_a_SOURCES += src/schedulerdefaultgetaffinity.c
>  libscore_a_SOURCES += src/schedulerdefaultsetaffinity.c
>  libscore_a_SOURCES += src/schedulersmp.c
>  libscore_a_SOURCES += src/schedulersmpstartidle.c
> diff --git a/cpukit/score/include/rtems/score/processormask.h b/cpukit/score/include/rtems/score/processormask.h
> index b550aa42a9..ed79e63d6f 100644
> --- a/cpukit/score/include/rtems/score/processormask.h
> +++ b/cpukit/score/include/rtems/score/processormask.h
> @@ -252,6 +252,8 @@ RTEMS_INLINE_ROUTINE Processor_mask_Copy_status _Processor_mask_From_cpu_set_t(
> +extern const Processor_mask _Processor_mask_The_one_and_only;
I would prefer _Processor_mask_Only_one, but it is a minor thing.
>  #ifdef __cplusplus
> diff --git a/cpukit/score/include/rtems/score/scheduler.h b/cpukit/score/include/rtems/score/scheduler.h
> index 1b9509ae4f..6e7bdcbd9a 100644
> --- a/cpukit/score/include/rtems/score/scheduler.h
> +++ b/cpukit/score/include/rtems/score/scheduler.h
> @@ -203,14 +203,6 @@ typedef struct {
>  #if defined(RTEMS_SMP)
> -  /** @see _Scheduler_Get_affinity() */
> -  bool ( *get_affinity )(
> -    const Scheduler_Control *,
> -    Thread_Control *,
> -    size_t,
> -    cpu_set_t *
>    /** @see _Scheduler_Set_affinity() */
>    bool ( *set_affinity )(
> @@ -514,24 +506,6 @@ void _Scheduler_default_Start_idle(
> -   * @brief Get affinity for the default scheduler.
> -   * @param[in] scheduler The scheduler instance.
> -   * @param[in] thread The associated thread.
> -   * @param[in] cpusetsize The size of the cpuset.
> -   * @param[out] cpuset Affinity set containing all CPUs.
> -   * @retval 0 Successfully got cpuset
> -   * @retval -1 The cpusetsize is invalid for the system
> -  bool _Scheduler_default_Get_affinity(
> -    const Scheduler_Control *scheduler,
> -    Thread_Control          *thread,
> -    size_t                   cpusetsize,
> -    cpu_set_t               *cpuset
>     * @brief Set affinity for the default scheduler.
> @@ -553,7 +527,6 @@ void _Scheduler_default_Start_idle(
>    #define SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY \
> -    , _Scheduler_default_Get_affinity \
>      , _Scheduler_default_Set_affinity
>  #else
> diff --git a/cpukit/score/include/rtems/score/schedulerimpl.h b/cpukit/score/include/rtems/score/schedulerimpl.h
> index c7c8bf05a0..927c6e1762 100644
> --- a/cpukit/score/include/rtems/score/schedulerimpl.h
> +++ b/cpukit/score/include/rtems/score/schedulerimpl.h
> @@ -613,20 +613,6 @@ RTEMS_INLINE_ROUTINE void _Scheduler_Get_processor_set(
> -RTEMS_INLINE_ROUTINE bool _Scheduler_default_Get_affinity_body(
> -  Thread_Control          *the_thread,
> -  cpu_set_t               *cpuset
> -  (void) the_thread;
> -  _Scheduler_Get_processor_set( scheduler, cpusetsize, cpuset );
> -  return true;
>  bool _Scheduler_Get_affinity(
>    size_t          cpusetsize,
> diff --git a/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h b/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h
> index 850c72bb40..fd4a33670f 100644
> --- a/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h
> +++ b/cpukit/score/include/rtems/score/schedulerpriorityaffinitysmp.h
> @@ -68,7 +68,6 @@ extern "C" {
>      _Scheduler_default_Cancel_job, \
>      _Scheduler_default_Tick, \
>      _Scheduler_SMP_Start_idle, \
> -    _Scheduler_priority_affinity_SMP_Get_affinity, \
>      _Scheduler_priority_affinity_SMP_Set_affinity \
> @@ -102,24 +101,6 @@ void _Scheduler_priority_affinity_SMP_Unblock(
>    Scheduler_Node          *node
> - * @brief Get affinity for the priority affinity SMP scheduler.
> - * @param[in] scheduler The scheduler of the thread.
> - * @param[in,out] cpuset The associated affinity set.
> -bool _Scheduler_priority_affinity_SMP_Get_affinity(
> -  cpu_set_t               *cpuset
>  void _Scheduler_priority_affinity_SMP_Update_priority(
> diff --git a/cpukit/score/include/rtems/score/thread.h b/cpukit/score/include/rtems/score/thread.h
> index 54b207f137..ecab766fee 100644
> --- a/cpukit/score/include/rtems/score/thread.h
> +++ b/cpukit/score/include/rtems/score/thread.h
> @@ -37,7 +37,7 @@
>  #include <rtems/score/watchdog.h>
> -  #include <rtems/score/cpuset.h>
> +#include <rtems/score/processormask.h>
>  #endif
>  struct _pthread_cleanup_context;
> @@ -311,6 +311,11 @@ typedef struct {
>     * This list is protected by the thread scheduler lock.
>    Scheduler_Node *requests;
> +   * @brief The thread processor affinity set.
> +  Processor_mask Affinity;
>  #endif
> diff --git a/cpukit/score/src/processormaskcopy.c b/cpukit/score/src/processormaskcopy.c
> index bf8082d3c4..677c886e60 100644
> --- a/cpukit/score/src/processormaskcopy.c
> +++ b/cpukit/score/src/processormaskcopy.c
> @@ -26,6 +26,8 @@
> +const Processor_mask _Processor_mask_The_one_and_only = { .__bits[ 0 ] = 1 };
>  Processor_mask_Copy_status _Processor_mask_Copy(
>    long       *dst,
>    size_t      dst_size,
> diff --git a/cpukit/score/src/schedulerdefaultgetaffinity.c b/cpukit/score/src/schedulerdefaultgetaffinity.c
> deleted file mode 100644
> index 56a4ee4fad..0000000000
> --- a/cpukit/score/src/schedulerdefaultgetaffinity.c
> +++ /dev/null
> @@ -1,37 +0,0 @@
> - * @file
> - * @brief Scheduler Default Get Affinity Operation
> - * @ingroup ScoreScheduler
> - *  COPYRIGHT (c) 2014.
> - *  On-Line Applications Research Corporation (OAR).
> - *  The license and distribution terms for this file may be
> - *  found in the file LICENSE in this distribution or at
> - *  http://www.rtems.org/license/LICENSE.
> -#if HAVE_CONFIG_H
> -  #include "config.h"
> -#endif
> -#include <rtems/score/schedulerimpl.h>
> -bool _Scheduler_default_Get_affinity(
> -  cpu_set_t               *cpuset
> -  return _Scheduler_default_Get_affinity_body(
> -    scheduler,
> -    thread,
> -    cpusetsize,
> -    cpuset
> diff --git a/cpukit/score/src/schedulergetaffinity.c b/cpukit/score/src/schedulergetaffinity.c
> index 37e10de958..8425a7fcf6 100644
> --- a/cpukit/score/src/schedulergetaffinity.c
> +++ b/cpukit/score/src/schedulergetaffinity.c
> @@ -1,5 +1,5 @@
> - * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
> + * Copyright (c) 2014, 2017 embedded brains GmbH.  All rights reserved.
>   *  embedded brains GmbH
>   *  Dornierstr. 4
> @@ -24,33 +24,21 @@ bool _Scheduler_Get_affinity(
>    cpu_set_t      *cpuset
> -  const Scheduler_Control *scheduler;
> -  ISR_lock_Context         lock_context;
> -  bool                     ok;
> -  if ( !_CPU_set_Is_large_enough( cpusetsize ) ) {
> -    return false;
> +  const Scheduler_Control    *scheduler;
> +  ISR_lock_Context            lock_context;
> +  Processor_mask             *affinity;
> +  Processor_mask_Copy_status  status;
>    scheduler = _Thread_Scheduler_get_home( the_thread );
>    _Scheduler_Acquire_critical( scheduler, &lock_context );
> -  ok = ( *scheduler->Operations.get_affinity )(
> -    scheduler,
> -    the_thread,
> -    cpusetsize,
> -    cpuset
> +  affinity = &the_thread->Scheduler.Affinity;
>  #else
> -  ok = _Scheduler_default_Get_affinity_body(
> -    scheduler,
> -    the_thread,
> -    cpusetsize,
> -    cpuset
> +  affinity = &_Processor_mask_The_one_and_only;
>  #endif
> +  status = _Processor_mask_To_cpu_set_t( affinity, cpusetsize, cpuset );
>    _Scheduler_Release_critical( scheduler, &lock_context );
> -  return ok;
> +  return status == PROCESSOR_MASK_COPY_LOSSLESS;
> diff --git a/cpukit/score/src/schedulerpriorityaffinitysmp.c b/cpukit/score/src/schedulerpriorityaffinitysmp.c
> index 1fa5dbf920..4533dec9d7 100644
> --- a/cpukit/score/src/schedulerpriorityaffinitysmp.c
> +++ b/cpukit/score/src/schedulerpriorityaffinitysmp.c
> @@ -611,29 +611,6 @@ Thread_Control *_Scheduler_priority_affinity_SMP_Remove_processor(
> - * This is the public scheduler specific Change Priority operation.
> -  cpu_set_t               *cpuset
> -  Scheduler_priority_affinity_SMP_Node *node =
> -    _Scheduler_priority_affinity_SMP_Thread_get_node(thread);
> -  (void) scheduler;
> -  if ( node->Affinity.setsize != cpusetsize ) {
> -    return false;
> -  CPU_COPY( node->Affinity.set, cpuset );
> -  return true;
>  bool _Scheduler_priority_affinity_SMP_Set_affinity(
> diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
> index c34113db3d..803ee7b646 100644
> --- a/cpukit/score/src/threadinitialize.c
> +++ b/cpukit/score/src/threadinitialize.c
> @@ -248,6 +248,7 @@ bool _Thread_Initialize(
>    RTEMS_STATIC_ASSERT( THREAD_SCHEDULER_BLOCKED == 0, Scheduler_state );
>    the_thread->Scheduler.home = scheduler;
>    _ISR_lock_Initialize( &the_thread->Scheduler.Lock, "Thread Scheduler" );
> +  _Processor_mask_Assign( &the_thread->Scheduler.Affinity, &_SMP_Online_processors );
>    _ISR_lock_Initialize( &the_thread->Wait.Lock.Default, "Thread Wait Default" );
>    _Thread_queue_Gate_open( &the_thread->Wait.Lock.Tranquilizer );
>    _RBTree_Initialize_node( &the_thread->Wait.Link.Registry_node );
> diff --git a/testsuites/smptests/smpaffinity01/init.c b/testsuites/smptests/smpaffinity01/init.c
> index cf95fc54d1..be68e1bbfd 100644
> --- a/testsuites/smptests/smpaffinity01/init.c
> +++ b/testsuites/smptests/smpaffinity01/init.c
> @@ -84,7 +84,7 @@ void Validate_getaffinity_errors(void)
>    puts(
>      "Init - rtems_task_get_affinity - Invalid cpusetsize - RTEMS_INVALID_NUMBER"
> -  sc = rtems_task_get_affinity( Init_id,  sizeof(cpu_set_t) * 2, &cpuset );
> +  sc = rtems_task_get_affinity( Init_id,  1, &cpuset );
>    rtems_test_assert( sc == RTEMS_INVALID_NUMBER );
>    /* Verify rtems_task_get_affinity validates cpuset */
> diff --git a/testsuites/smptests/smppsxaffinity02/init.c b/testsuites/smptests/smppsxaffinity02/init.c
> index 462462f275..5f8abac0a0 100644
> --- a/testsuites/smptests/smppsxaffinity02/init.c
> +++ b/testsuites/smptests/smppsxaffinity02/init.c
> @@ -89,7 +89,7 @@ void Validate_getaffinity_errors(void)
>    /* Verify pthread_getaffinity_np validates cpusetsize */
>    puts( "Init - pthread_getaffinity_np - Invalid cpusetsize - EINVAL" );
> -  sc = pthread_getaffinity_np( Init_id,  sizeof(cpu_set_t) * 2, &cpuset );
> +  sc = pthread_getaffinity_np( Init_id,  1, &cpuset );
>    rtems_test_assert( sc == EINVAL );
>    /* Verify pthread_getaffinity_np validates cpuset */
> diff --git a/testsuites/smptests/smpscheduler02/init.c b/testsuites/smptests/smpscheduler02/init.c
> index 43558579ab..db7d863991 100644
> --- a/testsuites/smptests/smpscheduler02/init.c
> +++ b/testsuites/smptests/smpscheduler02/init.c
> @@ -1,5 +1,5 @@
> - * Copyright (c) 2014, 2016 embedded brains GmbH.  All rights reserved.
>   *  Dornierstr. 4
> @@ -207,8 +207,14 @@ static void test(void)
>    cpu_set_t first_cpu;
>    cpu_set_t second_cpu;
>    cpu_set_t all_cpus;
> +  cpu_set_t online_cpus;
>    uint32_t cpu_count;
> +  cpu_count = rtems_get_processor_count();
> +  rtems_test_assert(cpu_count == 1 || cpu_count == 2);
> +  rtems_test_assert(rtems_get_current_processor() == 0);
>    main_task_id = rtems_task_self();
>    CPU_ZERO(&first_cpu);
> @@ -221,9 +227,12 @@ static void test(void)
>    CPU_SET(0, &all_cpus);
>    CPU_SET(1, &all_cpus);
> -  cpu_count = rtems_get_processor_count();
> +  CPU_ZERO(&online_cpus);
> +  CPU_SET(0, &online_cpus);
> -  rtems_test_assert(rtems_get_current_processor() == 0);
> +  if (cpu_count > 1) {
> +    CPU_SET(1, &online_cpus);
>    sc = rtems_scheduler_ident(SCHED_A, &scheduler_a_id);
>    rtems_test_assert(sc == RTEMS_SUCCESSFUL);
> @@ -304,7 +313,7 @@ static void test(void)
>    CPU_ZERO(&cpuset);
>    sc = rtems_task_get_affinity(task_id, sizeof(cpuset), &cpuset);
> -  rtems_test_assert(CPU_EQUAL(&cpuset, &first_cpu));
> +  rtems_test_assert(CPU_EQUAL(&cpuset, &online_cpus));
>    rtems_test_assert(sched_get_priority_min(SCHED_RR) == 1);
>    rtems_test_assert(sched_get_priority_max(SCHED_RR) == 254);
> @@ -326,7 +335,7 @@ static void test(void)
>      CPU_ZERO(&cpuset);
> -    rtems_test_assert(CPU_EQUAL(&cpuset, &second_cpu));
>      sc = rtems_task_set_affinity(task_id, sizeof(all_cpus), &all_cpus);
> 2.12.3
> devel mailing list
> devel at rtems.org
