[PATCH v2 2/2] Add dts file to generate dtb binary file for Beaglebone black.
Sichen Zhao 1473996754 at qq.com
Tue Jul 11 10:51:20 UTC 2017
These dts files import from FreeBSD, git link:
https://github.com/freebsd/freebsd/tree/master/sys/gnu/dts
The license for these files in beagle/simscripts
 c/src/lib/libbsp/arm/beagle/README                 |   11 +
 c/src/lib/libbsp/arm/beagle/simscripts/LICENSE     |    2 +
 .../arm/beagle/simscripts/am335x-bone-common.dtsi  |  417 ++++++++
 .../beagle/simscripts/am335x-boneblack-common.dtsi |  163 ++++
 .../arm/beagle/simscripts/am335x-boneblack.dts     |   28 +
 .../arm/beagle/simscripts/am33xx-clocks.dtsi       |  646 +++++++++++++
 c/src/lib/libbsp/arm/beagle/simscripts/am33xx.dtsi | 1011 ++++++++++++++++++++
 .../simscripts/dt-bindings/display/tda998x.h       |    7 +
 .../arm/beagle/simscripts/dt-bindings/gpio/gpio.h  |   31 +
 .../beagle/simscripts/dt-bindings/pinctrl/am33xx.h |   43 +
 .../beagle/simscripts/dt-bindings/pinctrl/omap.h   |   90 ++
 c/src/lib/libbsp/arm/beagle/simscripts/sdcard.sh   |   10 +-
 .../lib/libbsp/arm/beagle/simscripts/tps65217.dtsi |   68 ++
 13 files changed, 2525 insertions(+), 2 deletions(-)
 create mode 100644 c/src/lib/libbsp/arm/beagle/simscripts/LICENSE
 create mode 100644 c/src/lib/libbsp/arm/beagle/simscripts/am335x-bone-common.dtsi
 create mode 100644 c/src/lib/libbsp/arm/beagle/simscripts/am335x-boneblack-common.dtsi
 create mode 100644 c/src/lib/libbsp/arm/beagle/simscripts/am335x-boneblack.dts
 create mode 100644 c/src/lib/libbsp/arm/beagle/simscripts/am33xx-clocks.dtsi
 create mode 100644 c/src/lib/libbsp/arm/beagle/simscripts/am33xx.dtsi
 create mode 100644 c/src/lib/libbsp/arm/beagle/simscripts/dt-bindings/display/tda998x.h
 create mode 100644 c/src/lib/libbsp/arm/beagle/simscripts/dt-bindings/gpio/gpio.h
 create mode 100644 c/src/lib/libbsp/arm/beagle/simscripts/dt-bindings/pinctrl/am33xx.h
 create mode 100644 c/src/lib/libbsp/arm/beagle/simscripts/dt-bindings/pinctrl/omap.h
 create mode 100644 c/src/lib/libbsp/arm/beagle/simscripts/tps65217.dtsi
diff --git a/c/src/lib/libbsp/arm/beagle/README b/c/src/lib/libbsp/arm/beagle/README
index e558287..2ed9393 100644
--- a/c/src/lib/libbsp/arm/beagle/README
+++ b/c/src/lib/libbsp/arm/beagle/README
@@ -93,6 +93,17 @@ uboot# bootm 0x80800000
 There is a script here that automatically writes an SD card for any of
 the beagle targets.
+Before using the script, you need DTC(device tree compiler) tool to
+compile dts to dtb file. So you need add this tool in RSB bset file.
+These dts and dtsi files are licensed under the terms of the GNU
+General Public License * version 2.
+For example, to add dtc tool in rtems-arm.bset, you need include
+dtc.bset in rtems-arm.bset.
+%include devel/dtc.bset
 Let's write one for the Beaglebone Black. Assuming your source tree is
 at $HOME/development/rtems/rtems-src and your bsp is built and linked
 with examples and installed at $HOME/development/rtems/4.11.
diff --git a/c/src/lib/libbsp/arm/beagle/simscripts/LICENSE b/c/src/lib/libbsp/arm/beagle/simscripts/LICENSE
new file mode 100644
index 0000000..587a3dd
--- /dev/null
+++ b/c/src/lib/libbsp/arm/beagle/simscripts/LICENSE
@@ -0,0 +1,2 @@
+These files are imported from FreeBSD.
+These files is licensed under the terms of the GNU General Public License * version 2.
diff --git a/c/src/lib/libbsp/arm/beagle/simscripts/am335x-bone-common.dtsi b/c/src/lib/libbsp/arm/beagle/simscripts/am335x-bone-common.dtsi
index 0000000..bf6b26a
--- /dev/null
+++ b/c/src/lib/libbsp/arm/beagle/simscripts/am335x-bone-common.dtsi
@@ -0,0 +1,417 @@
+ * Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/
+ * This program is free software; you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License version 2 as
+ * published by the Free Software Foundation.
+	cpus {
+		cpu at 0 {
+			cpu0-supply = <&dcdc2_reg>;
+	memory at 80000000 {
+		device_type = "memory";
+		reg = <0x80000000 0x10000000>; /* 256 MB */
+	chosen {
+		stdout-path = &uart0;
+	leds {
+		pinctrl-names = "default";
+		pinctrl-0 = <&user_leds_s0>;
+		compatible = "gpio-leds";
+		led2 {
+			label = "beaglebone:green:heartbeat";
+			gpios = <&gpio1 21 GPIO_ACTIVE_HIGH>;
+			linux,default-trigger = "heartbeat";
+			default-state = "off";
+		led3 {
+			label = "beaglebone:green:mmc0";
+			gpios = <&gpio1 22 GPIO_ACTIVE_HIGH>;
+			linux,default-trigger = "mmc0";
+		led4 {
+			label = "beaglebone:green:usr2";
+			gpios = <&gpio1 23 GPIO_ACTIVE_HIGH>;
+			linux,default-trigger = "cpu0";
+		led5 {
+			label = "beaglebone:green:usr3";
+			gpios = <&gpio1 24 GPIO_ACTIVE_HIGH>;
+			linux,default-trigger = "mmc1";
+	vmmcsd_fixed: fixedregulator0 {
+		compatible = "regulator-fixed";
+		regulator-name = "vmmcsd_fixed";
+		regulator-min-microvolt = <3300000>;
+		regulator-max-microvolt = <3300000>;
+&am33xx_pinmux {
+	pinctrl-0 = <&clkout2_pin>;
+	user_leds_s0: user_leds_s0 {
+		pinctrl-single,pins = <
+			AM33XX_IOPAD(0x854, PIN_OUTPUT_PULLDOWN | MUX_MODE7)	/* gpmc_a5.gpio1_21 */
+			AM33XX_IOPAD(0x858, PIN_OUTPUT_PULLUP | MUX_MODE7)	/* gpmc_a6.gpio1_22 */
+			AM33XX_IOPAD(0x85c, PIN_OUTPUT_PULLDOWN | MUX_MODE7)	/* gpmc_a7.gpio1_23 */
+			AM33XX_IOPAD(0x860, PIN_OUTPUT_PULLUP | MUX_MODE7)	/* gpmc_a8.gpio1_24 */
+	i2c0_pins: pinmux_i2c0_pins {
+			AM33XX_IOPAD(0x988, PIN_INPUT_PULLUP | MUX_MODE0)	/* i2c0_sda.i2c0_sda */
+			AM33XX_IOPAD(0x98c, PIN_INPUT_PULLUP | MUX_MODE0)	/* i2c0_scl.i2c0_scl */
+	i2c2_pins: pinmux_i2c2_pins {
+			AM33XX_IOPAD(0x978, PIN_INPUT_PULLUP | MUX_MODE3)	/* uart1_ctsn.i2c2_sda */
+			AM33XX_IOPAD(0x97c, PIN_INPUT_PULLUP | MUX_MODE3)	/* uart1_rtsn.i2c2_scl */
+	uart0_pins: pinmux_uart0_pins {
+			AM33XX_IOPAD(0x970, PIN_INPUT_PULLUP | MUX_MODE0)	/* uart0_rxd.uart0_rxd */
+			AM33XX_IOPAD(0x974, PIN_OUTPUT_PULLDOWN | MUX_MODE0)	/* uart0_txd.uart0_txd */
+	clkout2_pin: pinmux_clkout2_pin {
+			AM33XX_IOPAD(0x9b4, PIN_OUTPUT_PULLDOWN | MUX_MODE3)	/* xdma_event_intr1.clkout2 */
+	cpsw_default: cpsw_default {
+			/* Slave 1 */
+			AM33XX_IOPAD(0x910, PIN_INPUT_PULLUP | MUX_MODE0)	/* mii1_rxerr.mii1_rxerr */
+			AM33XX_IOPAD(0x914, PIN_OUTPUT_PULLDOWN | MUX_MODE0)	/* mii1_txen.mii1_txen */
+			AM33XX_IOPAD(0x918, PIN_INPUT_PULLUP | MUX_MODE0)	/* mii1_rxdv.mii1_rxdv */
+			AM33XX_IOPAD(0x91c, PIN_OUTPUT_PULLDOWN | MUX_MODE0)	/* mii1_txd3.mii1_txd3 */
+			AM33XX_IOPAD(0x920, PIN_OUTPUT_PULLDOWN | MUX_MODE0)	/* mii1_txd2.mii1_txd2 */
+			AM33XX_IOPAD(0x924, PIN_OUTPUT_PULLDOWN | MUX_MODE0)	/* mii1_txd1.mii1_txd1 */
+			AM33XX_IOPAD(0x928, PIN_OUTPUT_PULLDOWN | MUX_MODE0)	/* mii1_txd0.mii1_txd0 */
+			AM33XX_IOPAD(0x92c, PIN_INPUT_PULLUP | MUX_MODE0)	/* mii1_txclk.mii1_txclk */
+			AM33XX_IOPAD(0x930, PIN_INPUT_PULLUP | MUX_MODE0)	/* mii1_rxclk.mii1_rxclk */
+			AM33XX_IOPAD(0x934, PIN_INPUT_PULLUP | MUX_MODE0)	/* mii1_rxd3.mii1_rxd3 */
+			AM33XX_IOPAD(0x938, PIN_INPUT_PULLUP | MUX_MODE0)	/* mii1_rxd2.mii1_rxd2 */
+			AM33XX_IOPAD(0x93c, PIN_INPUT_PULLUP | MUX_MODE0)	/* mii1_rxd1.mii1_rxd1 */
+			AM33XX_IOPAD(0x940, PIN_INPUT_PULLUP | MUX_MODE0)	/* mii1_rxd0.mii1_rxd0 */
+	cpsw_sleep: cpsw_sleep {
+			/* Slave 1 reset value */
+			AM33XX_IOPAD(0x910, PIN_INPUT_PULLDOWN | MUX_MODE7)
+			AM33XX_IOPAD(0x914, PIN_INPUT_PULLDOWN | MUX_MODE7)
+			AM33XX_IOPAD(0x918, PIN_INPUT_PULLDOWN | MUX_MODE7)
+			AM33XX_IOPAD(0x91c, PIN_INPUT_PULLDOWN | MUX_MODE7)
+			AM33XX_IOPAD(0x920, PIN_INPUT_PULLDOWN | MUX_MODE7)
+			AM33XX_IOPAD(0x924, PIN_INPUT_PULLDOWN | MUX_MODE7)
+			AM33XX_IOPAD(0x928, PIN_INPUT_PULLDOWN | MUX_MODE7)
+			AM33XX_IOPAD(0x92c, PIN_INPUT_PULLDOWN | MUX_MODE7)
+			AM33XX_IOPAD(0x930, PIN_INPUT_PULLDOWN | MUX_MODE7)
+			AM33XX_IOPAD(0x934, PIN_INPUT_PULLDOWN | MUX_MODE7)
+			AM33XX_IOPAD(0x938, PIN_INPUT_PULLDOWN | MUX_MODE7)
+			AM33XX_IOPAD(0x93c, PIN_INPUT_PULLDOWN | MUX_MODE7)
+			AM33XX_IOPAD(0x940, PIN_INPUT_PULLDOWN | MUX_MODE7)
+	davinci_mdio_default: davinci_mdio_default {
+			/* MDIO */
+			AM33XX_IOPAD(0x948, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0)	/* mdio_data.mdio_data */
+			AM33XX_IOPAD(0x94c, PIN_OUTPUT_PULLUP | MUX_MODE0)			/* mdio_clk.mdio_clk */
+	davinci_mdio_sleep: davinci_mdio_sleep {
+			/* MDIO reset value */
+			AM33XX_IOPAD(0x948, PIN_INPUT_PULLDOWN | MUX_MODE7)
+			AM33XX_IOPAD(0x94c, PIN_INPUT_PULLDOWN | MUX_MODE7)
+	mmc1_pins: pinmux_mmc1_pins {
+			AM33XX_IOPAD(0x960, PIN_INPUT | MUX_MODE7) /* GPIO0_6 */
+	emmc_pins: pinmux_emmc_pins {
+			AM33XX_IOPAD(0x880, PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_csn1.mmc1_clk */
+			AM33XX_IOPAD(0x884, PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_csn2.mmc1_cmd */
+			AM33XX_IOPAD(0x800, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad0.mmc1_dat0 */
+			AM33XX_IOPAD(0x804, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad1.mmc1_dat1 */
+			AM33XX_IOPAD(0x808, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad2.mmc1_dat2 */
+			AM33XX_IOPAD(0x80c, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad3.mmc1_dat3 */
+			AM33XX_IOPAD(0x810, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad4.mmc1_dat4 */
+			AM33XX_IOPAD(0x814, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad5.mmc1_dat5 */
+			AM33XX_IOPAD(0x818, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad6.mmc1_dat6 */
+			AM33XX_IOPAD(0x81c, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad7.mmc1_dat7 */
+&uart0 {
+	pinctrl-0 = <&uart0_pins>;
+	status = "okay";
+&usb {
+	status = "okay";
+&usb_ctrl_mod {
+	status = "okay";
+&usb0_phy {
+	status = "okay";
+&usb1_phy {
+	status = "okay";
+&usb0 {
+	status = "okay";
+	dr_mode = "peripheral";
+	interrupts-extended = <&intc 18 &tps 0>;
+	interrupt-names = "mc", "vbus";
+&usb1 {
+	status = "okay";
+	dr_mode = "host";
+&cppi41dma  {
+	status = "okay";
+&i2c0 {
+	pinctrl-0 = <&i2c0_pins>;
+	status = "okay";
+	clock-frequency = <400000>;
+	tps: tps at 24 {
+		reg = <0x24>;
+	baseboard_eeprom: baseboard_eeprom at 50 {
+		compatible = "at,24c256";
+		reg = <0x50>;
+		#address-cells = <1>;
+		#size-cells = <1>;
+		baseboard_data: baseboard_data at 0 {
+			reg = <0 0x100>;
+&i2c2 {
+	pinctrl-0 = <&i2c2_pins>;
+	status = "okay";
+	clock-frequency = <100000>;
+	cape_eeprom0: cape_eeprom0 at 54 {
+		reg = <0x54>;
+		cape0_data: cape_data at 0 {
+			reg = <0 0x100>;
+	cape_eeprom1: cape_eeprom1 at 55 {
+		reg = <0x55>;
+		cape1_data: cape_data at 0 {
+			reg = <0 0x100>;
+	cape_eeprom2: cape_eeprom2 at 56 {
+		reg = <0x56>;
+		cape2_data: cape_data at 0 {
+			reg = <0 0x100>;
+	cape_eeprom3: cape_eeprom3 at 57 {
+		reg = <0x57>;
+		cape3_data: cape_data at 0 {
+			reg = <0 0x100>;
+/include/ "tps65217.dtsi"
+&tps {
+	 * Configure pmic to enter OFF-state instead of SLEEP-state ("RTC-only
+	 * mode") at poweroff.  Most BeagleBone versions do not support RTC-only
+	 * mode and risk hardware damage if this mode is entered.
+	 * For details, see linux-omap mailing list May 2015 thread
+	 *	[PATCH] ARM: dts: am335x-bone* enable pmic-shutdown-controller
+	 * In particular, messages:
+	 *	http://www.spinics.net/lists/linux-omap/msg118585.html
+	 *	http://www.spinics.net/lists/linux-omap/msg118615.html
+	 * You can override this later with
+	 *	&tps {  /delete-property/ ti,pmic-shutdown-controller;  }
+	 * if you want to use RTC-only mode and made sure you are not affected
+	 * by the hardware problems. (Tip: double-check by performing a current
+	 * measurement after shutdown: it should be less than 1 mA.)
+	interrupts = <7>; /* NMI */
+	interrupt-parent = <&intc>;
+	ti,pmic-shutdown-controller;
+	charger {
+		interrupts = <0>, <1>;
+		interrupt-names = "USB", "AC";
+		status = "okay";
+	pwrbutton {
+		interrupts = <2>;
+		status = "okay";
+	regulators {
+		dcdc1_reg: regulator at 0 {
+			regulator-name = "vdds_dpr";
+			regulator-always-on;
+		dcdc2_reg: regulator at 1 {
+			/* VDD_MPU voltage limits 0.95V - 1.26V with +/-4% tolerance */
+			regulator-name = "vdd_mpu";
+			regulator-min-microvolt = <925000>;
+			regulator-max-microvolt = <1351500>;
+			regulator-boot-on;
+		dcdc3_reg: regulator at 2 {
+			/* VDD_CORE voltage limits 0.95V - 1.1V with +/-4% tolerance */
+			regulator-name = "vdd_core";
+			regulator-max-microvolt = <1150000>;
+		ldo1_reg: regulator at 3 {
+			regulator-name = "vio,vrtc,vdds";
+		ldo2_reg: regulator at 4 {
+			regulator-name = "vdd_3v3aux";
+		ldo3_reg: regulator at 5 {
+			regulator-name = "vdd_1v8";
+		ldo4_reg: regulator at 6 {
+			regulator-name = "vdd_3v3a";
+&cpsw_emac0 {
+	phy_id = <&davinci_mdio>, <0>;
+	phy-mode = "mii";
+&mac {
+	slaves = <1>;
+	pinctrl-names = "default", "sleep";
+	pinctrl-0 = <&cpsw_default>;
+	pinctrl-1 = <&cpsw_sleep>;
+	status = "okay";
+&davinci_mdio {
+	pinctrl-0 = <&davinci_mdio_default>;
+	pinctrl-1 = <&davinci_mdio_sleep>;
+	status = "okay";
+&mmc1 {
+	status = "okay";
+	bus-width = <0x4>;
+	pinctrl-0 = <&mmc1_pins>;
+	cd-gpios = <&gpio0 6 GPIO_ACTIVE_LOW>;
+&aes {
+	status = "okay";
+&sham {
+	status = "okay";
+&rtc {
+	clocks = <&clk_32768_ck>, <&clkdiv32k_ick>;
+	clock-names = "ext-clk", "int-clk";
diff --git a/c/src/lib/libbsp/arm/beagle/simscripts/am335x-boneblack-common.dtsi b/c/src/lib/libbsp/arm/beagle/simscripts/am335x-boneblack-common.dtsi
index 0000000..325daae
--- /dev/null
+++ b/c/src/lib/libbsp/arm/beagle/simscripts/am335x-boneblack-common.dtsi
@@ -0,0 +1,163 @@
+#include <dt-bindings/display/tda998x.h>
+&ldo3_reg {
+	regulator-min-microvolt = <1800000>;
+	regulator-max-microvolt = <1800000>;
+&mmc1 {
+	vmmc-supply = <&vmmcsd_fixed>;
+&mmc2 {
+	pinctrl-0 = <&emmc_pins>;
+	bus-width = <8>;
+	status = "okay";
+&am33xx_pinmux {
+	nxp_hdmi_bonelt_pins: nxp_hdmi_bonelt_pins {
+			AM33XX_IOPAD(0x9b0, PIN_OUTPUT_PULLDOWN | MUX_MODE3)	/* xdma_event_intr0 */
+			AM33XX_IOPAD(0x8a0, PIN_OUTPUT | MUX_MODE0)		/* lcd_data0.lcd_data0 */
+			AM33XX_IOPAD(0x8a4, PIN_OUTPUT | MUX_MODE0)		/* lcd_data1.lcd_data1 */
+			AM33XX_IOPAD(0x8a8, PIN_OUTPUT | MUX_MODE0)		/* lcd_data2.lcd_data2 */
+			AM33XX_IOPAD(0x8ac, PIN_OUTPUT | MUX_MODE0)		/* lcd_data3.lcd_data3 */
+			AM33XX_IOPAD(0x8b0, PIN_OUTPUT | MUX_MODE0)		/* lcd_data4.lcd_data4 */
+			AM33XX_IOPAD(0x8b4, PIN_OUTPUT | MUX_MODE0)		/* lcd_data5.lcd_data5 */
+			AM33XX_IOPAD(0x8b8, PIN_OUTPUT | MUX_MODE0)		/* lcd_data6.lcd_data6 */
+			AM33XX_IOPAD(0x8bc, PIN_OUTPUT | MUX_MODE0)		/* lcd_data7.lcd_data7 */
+			AM33XX_IOPAD(0x8c0, PIN_OUTPUT | MUX_MODE0)		/* lcd_data8.lcd_data8 */
+			AM33XX_IOPAD(0x8c4, PIN_OUTPUT | MUX_MODE0)		/* lcd_data9.lcd_data9 */
+			AM33XX_IOPAD(0x8c8, PIN_OUTPUT | MUX_MODE0)		/* lcd_data10.lcd_data10 */
+			AM33XX_IOPAD(0x8cc, PIN_OUTPUT | MUX_MODE0)		/* lcd_data11.lcd_data11 */
+			AM33XX_IOPAD(0x8d0, PIN_OUTPUT | MUX_MODE0)		/* lcd_data12.lcd_data12 */
+			AM33XX_IOPAD(0x8d4, PIN_OUTPUT | MUX_MODE0)		/* lcd_data13.lcd_data13 */
+			AM33XX_IOPAD(0x8d8, PIN_OUTPUT | MUX_MODE0)		/* lcd_data14.lcd_data14 */
+			AM33XX_IOPAD(0x8dc, PIN_OUTPUT | MUX_MODE0)		/* lcd_data15.lcd_data15 */
+			AM33XX_IOPAD(0x8e0, PIN_OUTPUT_PULLDOWN | MUX_MODE0)	/* lcd_vsync.lcd_vsync */
+			AM33XX_IOPAD(0x8e4, PIN_OUTPUT_PULLDOWN | MUX_MODE0)	/* lcd_hsync.lcd_hsync */
+			AM33XX_IOPAD(0x8e8, PIN_OUTPUT_PULLDOWN | MUX_MODE0)	/* lcd_pclk.lcd_pclk */
+			AM33XX_IOPAD(0x8ec, PIN_OUTPUT_PULLDOWN | MUX_MODE0)	/* lcd_ac_bias_en.lcd_ac_bias_en */
+	nxp_hdmi_bonelt_off_pins: nxp_hdmi_bonelt_off_pins {
+	mcasp0_pins: mcasp0_pins {
+			AM33XX_IOPAD(0x9ac, PIN_INPUT_PULLUP | MUX_MODE0) /* mcasp0_ahcklx.mcasp0_ahclkx */
+			AM33XX_IOPAD(0x99c, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mcasp0_ahclkr.mcasp0_axr2*/
+			AM33XX_IOPAD(0x994, PIN_OUTPUT_PULLUP | MUX_MODE0) /* mcasp0_fsx.mcasp0_fsx */
+			AM33XX_IOPAD(0x990, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* mcasp0_aclkx.mcasp0_aclkx */
+			AM33XX_IOPAD(0x86c, PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* gpmc_a11.GPIO1_27 */
+&lcdc {
+	status = "okay";
+	/* If you want to get 24 bit RGB and 16 BGR mode instead of
+	 * current 16 bit RGB and 24 BGR modes, set the propety
+	 * below to "crossed" and uncomment the video-ports -property
+	 * in tda19988 node.
+	blue-and-red-wiring = "straight";
+	port {
+		lcdc_0: endpoint at 0 {
+			remote-endpoint = <&hdmi_0>;
+&i2c0 {
+	tda19988: tda19988 {
+		compatible = "nxp,tda998x";
+		reg = <0x70>;
+		pinctrl-names = "default", "off";
+		pinctrl-0 = <&nxp_hdmi_bonelt_pins>;
+		pinctrl-1 = <&nxp_hdmi_bonelt_off_pins>;
+		/* Convert 24bit BGR to RGB, e.g. cross red and blue wiring */
+		/* video-ports = <0x234501>; */
+		#sound-dai-cells = <0>;
+		audio-ports = <	TDA998x_I2S	0x03>;
+		ports {
+			port at 0 {
+				hdmi_0: endpoint at 0 {
+					remote-endpoint = <&lcdc_0>;
+&rtc {
+	system-power-controller;
+&mcasp0	{
+	pinctrl-0 = <&mcasp0_pins>;
+	status = "okay";
+	op-mode = <0>;	/* MCASP_IIS_MODE */
+	tdm-slots = <2>;
+	serial-dir = <	/* 0: INACTIVE, 1: TX, 2: RX */
+			0 0 1 0
+	tx-num-evt = <32>;
+	rx-num-evt = <32>;
+	clk_mcasp0_fixed: clk_mcasp0_fixed {
+		#clock-cells = <0>;
+		compatible = "fixed-clock";
+		clock-frequency = <24576000>;
+	clk_mcasp0: clk_mcasp0 {
+		compatible = "gpio-gate-clock";
+		clocks = <&clk_mcasp0_fixed>;
+		enable-gpios = <&gpio1 27 0>; /* BeagleBone Black Clk enable on GPIO1_27 */
+	sound {
+		compatible = "simple-audio-card";
+		simple-audio-card,name = "TI BeagleBone Black";
+		simple-audio-card,format = "i2s";
+		simple-audio-card,bitclock-master = <&dailink0_master>;
+		simple-audio-card,frame-master = <&dailink0_master>;
+		dailink0_master: simple-audio-card,cpu {
+			sound-dai = <&mcasp0>;
+			clocks = <&clk_mcasp0>;
+		simple-audio-card,codec {
+			sound-dai = <&tda19988>;
diff --git a/c/src/lib/libbsp/arm/beagle/simscripts/am335x-boneblack.dts b/c/src/lib/libbsp/arm/beagle/simscripts/am335x-boneblack.dts
index 0000000..935ed17
--- /dev/null
+++ b/c/src/lib/libbsp/arm/beagle/simscripts/am335x-boneblack.dts
@@ -0,0 +1,28 @@
+/dts-v1/;
+#include "am33xx.dtsi"
+#include "am335x-bone-common.dtsi"
+#include "am335x-boneblack-common.dtsi"
+	model = "TI AM335x BeagleBone Black";
+	compatible = "ti,am335x-bone-black", "ti,am335x-bone", "ti,am33xx";
+&cpu0_opp_table {
+	 * All PG 2.0 silicon may not support 1GHz but some of the early
+	 * BeagleBone Blacks have PG 2.0 silicon which is guaranteed
+	 * to support 1GHz OPP so enable it for PG 2.0 on this board.
+	oppnitro at 1000000000 {
+		opp-supported-hw = <0x06 0x0100>;
diff --git a/c/src/lib/libbsp/arm/beagle/simscripts/am33xx-clocks.dtsi b/c/src/lib/libbsp/arm/beagle/simscripts/am33xx-clocks.dtsi
index 0000000..8d83195
--- /dev/null
+++ b/c/src/lib/libbsp/arm/beagle/simscripts/am33xx-clocks.dtsi
@@ -0,0 +1,646 @@
+ * Device Tree Source for AM33xx clock data
+ * Copyright (C) 2013 Texas Instruments, Inc.
+&scm_clocks {
+	sys_clkin_ck: sys_clkin_ck at 40 {
+		compatible = "ti,mux-clock";
+		clocks = <&virt_19200000_ck>, <&virt_24000000_ck>, <&virt_25000000_ck>, <&virt_26000000_ck>;
+		ti,bit-shift = <22>;
+		reg = <0x0040>;
+	adc_tsc_fck: adc_tsc_fck {
+		compatible = "fixed-factor-clock";
+		clocks = <&sys_clkin_ck>;
+		clock-mult = <1>;
+		clock-div = <1>;
+	dcan0_fck: dcan0_fck {
+		clock-mult = <1>;
+		clock-div = <1>;
+	dcan1_fck: dcan1_fck {
+		clock-mult = <1>;
+		clock-div = <1>;
+	mcasp0_fck: mcasp0_fck {
+		clock-mult = <1>;
+		clock-div = <1>;
+	mcasp1_fck: mcasp1_fck {
+		clock-mult = <1>;
+		clock-div = <1>;
+	smartreflex0_fck: smartreflex0_fck {
+		clock-mult = <1>;
+		clock-div = <1>;
+	smartreflex1_fck: smartreflex1_fck {
+		clock-mult = <1>;
+		clock-div = <1>;
+	sha0_fck: sha0_fck {
+		clock-mult = <1>;
+		clock-div = <1>;
+	aes0_fck: aes0_fck {
+		clock-mult = <1>;
+		clock-div = <1>;
+	rng_fck: rng_fck {
+		clock-mult = <1>;
+		clock-div = <1>;
+	ehrpwm0_tbclk: ehrpwm0_tbclk at 44e10664 {
+		compatible = "ti,gate-clock";
+		clocks = <&l4ls_gclk>;
+		ti,bit-shift = <0>;
+		reg = <0x0664>;
+	ehrpwm1_tbclk: ehrpwm1_tbclk at 44e10664 {
+		ti,bit-shift = <1>;
+		reg = <0x0664>;
+	ehrpwm2_tbclk: ehrpwm2_tbclk at 44e10664 {
+		ti,bit-shift = <2>;
+		reg = <0x0664>;
+&prcm_clocks {
+	clk_32768_ck: clk_32768_ck {
+		clock-frequency = <32768>;
+	clk_rc32k_ck: clk_rc32k_ck {
+		clock-frequency = <32000>;
+	virt_19200000_ck: virt_19200000_ck {
+		clock-frequency = <19200000>;
+	virt_24000000_ck: virt_24000000_ck {
+		clock-frequency = <24000000>;
+	virt_25000000_ck: virt_25000000_ck {
+		clock-frequency = <25000000>;
+	virt_26000000_ck: virt_26000000_ck {
+		clock-frequency = <26000000>;
+	tclkin_ck: tclkin_ck {
+		clock-frequency = <12000000>;
+	dpll_core_ck: dpll_core_ck at 490 {
+		compatible = "ti,am3-dpll-core-clock";
+		clocks = <&sys_clkin_ck>, <&sys_clkin_ck>;
+		reg = <0x0490>, <0x045c>, <0x0468>;
+	dpll_core_x2_ck: dpll_core_x2_ck {
+		compatible = "ti,am3-dpll-x2-clock";
+		clocks = <&dpll_core_ck>;
+	dpll_core_m4_ck: dpll_core_m4_ck at 480 {
+		compatible = "ti,divider-clock";
+		clocks = <&dpll_core_x2_ck>;
+		ti,max-div = <31>;
+		reg = <0x0480>;
+		ti,index-starts-at-one;
+	dpll_core_m5_ck: dpll_core_m5_ck at 484 {
+		reg = <0x0484>;
+	dpll_core_m6_ck: dpll_core_m6_ck at 4d8 {
+		reg = <0x04d8>;
+	dpll_mpu_ck: dpll_mpu_ck at 488 {
+		compatible = "ti,am3-dpll-clock";
+		reg = <0x0488>, <0x0420>, <0x042c>;
+	dpll_mpu_m2_ck: dpll_mpu_m2_ck at 4a8 {
+		clocks = <&dpll_mpu_ck>;
+		reg = <0x04a8>;
+	dpll_ddr_ck: dpll_ddr_ck at 494 {
+		compatible = "ti,am3-dpll-no-gate-clock";
+		reg = <0x0494>, <0x0434>, <0x0440>;
+	dpll_ddr_m2_ck: dpll_ddr_m2_ck at 4a0 {
+		clocks = <&dpll_ddr_ck>;
+		reg = <0x04a0>;
+	dpll_ddr_m2_div2_ck: dpll_ddr_m2_div2_ck {
+		clocks = <&dpll_ddr_m2_ck>;
+		clock-mult = <1>;
+		clock-div = <2>;
+	dpll_disp_ck: dpll_disp_ck at 498 {
+		reg = <0x0498>, <0x0448>, <0x0454>;
+	dpll_disp_m2_ck: dpll_disp_m2_ck at 4a4 {
+		clocks = <&dpll_disp_ck>;
+		reg = <0x04a4>;
+		ti,set-rate-parent;
+	dpll_per_ck: dpll_per_ck at 48c {
+		compatible = "ti,am3-dpll-no-gate-j-type-clock";
+		reg = <0x048c>, <0x0470>, <0x049c>;
+	dpll_per_m2_ck: dpll_per_m2_ck at 4ac {
+		clocks = <&dpll_per_ck>;
+		reg = <0x04ac>;
+	dpll_per_m2_div4_wkupdm_ck: dpll_per_m2_div4_wkupdm_ck {
+		clocks = <&dpll_per_m2_ck>;
+		clock-mult = <1>;
+		clock-div = <4>;
+	dpll_per_m2_div4_ck: dpll_per_m2_div4_ck {
+		clock-mult = <1>;
+		clock-div = <4>;
+	cefuse_fck: cefuse_fck at a20 {
+		reg = <0x0a20>;
+	clk_24mhz: clk_24mhz {
+		clock-mult = <1>;
+		clock-div = <8>;
+	clkdiv32k_ck: clkdiv32k_ck {
+		clocks = <&clk_24mhz>;
+		clock-mult = <1>;
+		clock-div = <732>;
+	clkdiv32k_ick: clkdiv32k_ick at 14c {
+		clocks = <&clkdiv32k_ck>;
+		reg = <0x014c>;
+	l3_gclk: l3_gclk {
+		clocks = <&dpll_core_m4_ck>;
+		clock-mult = <1>;
+		clock-div = <1>;
+	pruss_ocp_gclk: pruss_ocp_gclk at 530 {
+		clocks = <&l3_gclk>, <&dpll_disp_m2_ck>;
+		reg = <0x0530>;
+	mmu_fck: mmu_fck at 914 {
+		reg = <0x0914>;
+	timer1_fck: timer1_fck at 528 {
+		clocks = <&sys_clkin_ck>, <&clkdiv32k_ick>, <&tclkin_ck>, <&clk_rc32k_ck>, <&clk_32768_ck>;
+		reg = <0x0528>;
+	timer2_fck: timer2_fck at 508 {
+		clocks = <&tclkin_ck>, <&sys_clkin_ck>, <&clkdiv32k_ick>;
+		reg = <0x0508>;
+	timer3_fck: timer3_fck at 50c {
+		reg = <0x050c>;
+	timer4_fck: timer4_fck at 510 {
+		reg = <0x0510>;
+	timer5_fck: timer5_fck at 518 {
+		reg = <0x0518>;
+	timer6_fck: timer6_fck at 51c {
+		reg = <0x051c>;
+	timer7_fck: timer7_fck at 504 {
+		reg = <0x0504>;
+	usbotg_fck: usbotg_fck at 47c {
+		ti,bit-shift = <8>;
+		reg = <0x047c>;
+	dpll_core_m4_div2_ck: dpll_core_m4_div2_ck {
+		clock-mult = <1>;
+		clock-div = <2>;
+	ieee5000_fck: ieee5000_fck at e4 {
+		clocks = <&dpll_core_m4_div2_ck>;
+		reg = <0x00e4>;
+	wdt1_fck: wdt1_fck at 538 {
+		clocks = <&clk_rc32k_ck>, <&clkdiv32k_ick>;
+		reg = <0x0538>;
+	l4_rtc_gclk: l4_rtc_gclk {
+		clock-mult = <1>;
+		clock-div = <2>;
+	l4hs_gclk: l4hs_gclk {
+		clock-mult = <1>;
+		clock-div = <1>;
+	l3s_gclk: l3s_gclk {
+		clock-mult = <1>;
+		clock-div = <1>;
+	l4fw_gclk: l4fw_gclk {
+		clock-mult = <1>;
+		clock-div = <1>;
+	l4ls_gclk: l4ls_gclk {
+		clock-mult = <1>;
+		clock-div = <1>;
+	sysclk_div_ck: sysclk_div_ck {
+		clock-mult = <1>;
+		clock-div = <1>;
+	cpsw_125mhz_gclk: cpsw_125mhz_gclk {
+		clocks = <&dpll_core_m5_ck>;
+		clock-mult = <1>;
+		clock-div = <2>;
+	cpsw_cpts_rft_clk: cpsw_cpts_rft_clk at 520 {
+		clocks = <&dpll_core_m5_ck>, <&dpll_core_m4_ck>;
+		reg = <0x0520>;
+	gpio0_dbclk_mux_ck: gpio0_dbclk_mux_ck at 53c {
+		clocks = <&clk_rc32k_ck>, <&clk_32768_ck>, <&clkdiv32k_ick>;
+		reg = <0x053c>;
+	gpio0_dbclk: gpio0_dbclk at 408 {
+		clocks = <&gpio0_dbclk_mux_ck>;
+		ti,bit-shift = <18>;
+		reg = <0x0408>;
+	gpio1_dbclk: gpio1_dbclk at ac {
+		clocks = <&clkdiv32k_ick>;
+		reg = <0x00ac>;
+	gpio2_dbclk: gpio2_dbclk at b0 {
+		reg = <0x00b0>;
+	gpio3_dbclk: gpio3_dbclk at b4 {
+		reg = <0x00b4>;
+	lcd_gclk: lcd_gclk at 534 {
+		clocks = <&dpll_disp_m2_ck>, <&dpll_core_m5_ck>, <&dpll_per_m2_ck>;
+		reg = <0x0534>;
+	mmc_clk: mmc_clk {
+		clock-mult = <1>;
+		clock-div = <2>;
+	gfx_fclk_clksel_ck: gfx_fclk_clksel_ck at 52c {
+		clocks = <&dpll_core_m4_ck>, <&dpll_per_m2_ck>;
+		reg = <0x052c>;
+	gfx_fck_div_ck: gfx_fck_div_ck at 52c {
+		clocks = <&gfx_fclk_clksel_ck>;
+		reg = <0x052c>;
+		ti,max-div = <2>;
+	sysclkout_pre_ck: sysclkout_pre_ck at 700 {
+		clocks = <&clk_32768_ck>, <&l3_gclk>, <&dpll_ddr_m2_ck>, <&dpll_per_m2_ck>, <&lcd_gclk>;
+		reg = <0x0700>;
+	clkout2_div_ck: clkout2_div_ck at 700 {
+		clocks = <&sysclkout_pre_ck>;
+		ti,bit-shift = <3>;
+		ti,max-div = <8>;
+		reg = <0x0700>;
+	dbg_sysclk_ck: dbg_sysclk_ck at 414 {
+		ti,bit-shift = <19>;
+		reg = <0x0414>;
+	dbg_clka_ck: dbg_clka_ck at 414 {
+		ti,bit-shift = <30>;
+		reg = <0x0414>;
+	stm_pmd_clock_mux_ck: stm_pmd_clock_mux_ck at 414 {
+		clocks = <&dbg_sysclk_ck>, <&dbg_clka_ck>;
+		reg = <0x0414>;
+	trace_pmd_clk_mux_ck: trace_pmd_clk_mux_ck at 414 {
+		ti,bit-shift = <20>;
+		reg = <0x0414>;
+	stm_clk_div_ck: stm_clk_div_ck at 414 {
+		clocks = <&stm_pmd_clock_mux_ck>;
+		ti,bit-shift = <27>;
+		ti,max-div = <64>;
+		reg = <0x0414>;
+		ti,index-power-of-two;
+	trace_clk_div_ck: trace_clk_div_ck at 414 {
+		clocks = <&trace_pmd_clk_mux_ck>;
+		ti,bit-shift = <24>;
+		reg = <0x0414>;
+	clkout2_ck: clkout2_ck at 700 {
+		clocks = <&clkout2_div_ck>;
+		ti,bit-shift = <7>;
+		reg = <0x0700>;
+&prcm_clockdomains {
+	clk_24mhz_clkdm: clk_24mhz_clkdm {
+		compatible = "ti,clockdomain";
diff --git a/c/src/lib/libbsp/arm/beagle/simscripts/am33xx.dtsi b/c/src/lib/libbsp/arm/beagle/simscripts/am33xx.dtsi
index 0000000..9e24294
--- /dev/null
+++ b/c/src/lib/libbsp/arm/beagle/simscripts/am33xx.dtsi
@@ -0,0 +1,1011 @@
+ * Device Tree Source for AM33XX SoC
+ * This file is licensed under the terms of the GNU General Public License
+ * version 2.  This program is licensed "as is" without any warranty of any
+ * kind, whether express or implied.
+#include <dt-bindings/gpio/gpio.h>
+#include <dt-bindings/pinctrl/am33xx.h>
+	compatible = "ti,am33xx";
+	chosen { };
+	aliases {
+		i2c0 = &i2c0;
+		i2c1 = &i2c1;
+		i2c2 = &i2c2;
+		serial0 = &uart0;
+		serial1 = &uart1;
+		serial2 = &uart2;
+		serial3 = &uart3;
+		serial4 = &uart4;
+		serial5 = &uart5;
+		d_can0 = &dcan0;
+		d_can1 = &dcan1;
+		usb0 = &usb0;
+		usb1 = &usb1;
+		phy0 = &usb0_phy;
+		phy1 = &usb1_phy;
+		ethernet0 = &cpsw_emac0;
+		ethernet1 = &cpsw_emac1;
+	cpus {
+		#size-cells = <0>;
+		cpu at 0 {
+			compatible = "arm,cortex-a8";
+			device_type = "cpu";
+			reg = <0>;
+			operating-points-v2 = <&cpu0_opp_table>;
+			clock-names = "cpu";
+			clock-latency = <300000>; /* From omap-cpufreq driver */
+	cpu0_opp_table: opp-table {
+		compatible = "operating-points-v2-ti-cpu";
+		syscon = <&scm_conf>;
+		 * The three following nodes are marked with opp-suspend
+		 * because the can not be enabled simultaneously on a
+		 * single SoC.
+		opp50 at 300000000 {
+			opp-hz = /bits/ 64 <300000000>;
+			opp-microvolt = <950000 931000 969000>;
+			opp-supported-hw = <0x06 0x0010>;
+			opp-suspend;
+		opp100 at 275000000 {
+			opp-hz = /bits/ 64 <275000000>;
+			opp-microvolt = <1100000 1078000 1122000>;
+			opp-supported-hw = <0x01 0x00FF>;
+			opp-suspend;
+		opp100 at 300000000 {
+			opp-supported-hw = <0x06 0x0020>;
+			opp-suspend;
+		opp100 at 500000000 {
+			opp-hz = /bits/ 64 <500000000>;
+			opp-supported-hw = <0x01 0xFFFF>;
+		opp100 at 600000000 {
+			opp-hz = /bits/ 64 <600000000>;
+			opp-supported-hw = <0x06 0x0040>;
+		opp120 at 600000000 {
+			opp-microvolt = <1200000 1176000 1224000>;
+		opp120 at 720000000 {
+			opp-hz = /bits/ 64 <720000000>;
+			opp-supported-hw = <0x06 0x0080>;
+		oppturbo at 720000000 {
+			opp-microvolt = <1260000 1234800 1285200>;
+		oppturbo at 800000000 {
+			opp-hz = /bits/ 64 <800000000>;
+			opp-hz = /bits/ 64 <1000000000>;
+			opp-microvolt = <1325000 1298500 1351500>;
+			opp-supported-hw = <0x04 0x0200>;
+	pmu {
+		compatible = "arm,cortex-a8-pmu";
+		interrupts = <3>;
+	 * The soc node represents the soc top level view. It is used for IPs
+	 * that are not memory mapped in the MPU view or for the MPU itself.
+	soc {
+		compatible = "ti,omap-infra";
+		mpu {
+			compatible = "ti,omap3-mpu";
+			ti,hwmods = "mpu";
+	 * XXX: Use a flat representation of the AM33XX interconnect.
+	 * The real AM33XX interconnect network is quite complex. Since
+	 * it will not bring real advantage to represent that in DT
+	 * for the moment, just use a fake OCP bus entry to represent
+	 * the whole bus hierarchy.
+	ocp {
+		compatible = "simple-bus";
+		ranges;
+		ti,hwmods = "l3_main";
+		l4_wkup: l4_wkup at 44c00000 {
+			compatible = "ti,am3-l4-wkup", "simple-bus";
+			ranges = <0 0x44c00000 0x280000>;
+			wkup_m3: wkup_m3 at 100000 {
+				compatible = "ti,am3352-wkup-m3";
+				reg = <0x100000 0x4000>,
+				      <0x180000	0x2000>;
+				reg-names = "umem", "dmem";
+				ti,hwmods = "wkup_m3";
+				ti,pm-firmware = "am335x-pm-firmware.elf";
+			prcm: prcm at 200000 {
+				compatible = "ti,am3-prcm";
+				reg = <0x200000 0x4000>;
+				prcm_clocks: clocks {
+				prcm_clockdomains: clockdomains {
+			scm: scm at 210000 {
+				compatible = "ti,am3-scm", "simple-bus";
+				reg = <0x210000 0x2000>;
+				#pinctrl-cells = <1>;
+				ranges = <0 0x210000 0x2000>;
+				am33xx_pinmux: pinmux at 800 {
+					compatible = "pinctrl-single";
+					reg = <0x800 0x238>;
+					pinctrl-single,register-width = <32>;
+					pinctrl-single,function-mask = <0x7f>;
+				scm_conf: scm_conf at 0 {
+					compatible = "syscon", "simple-bus";
+					reg = <0x0 0x800>;
+					ranges = <0 0 0x800>;
+					scm_clocks: clocks {
+				wkup_m3_ipc: wkup_m3_ipc at 1324 {
+					compatible = "ti,am3352-wkup-m3-ipc";
+					reg = <0x1324 0x24>;
+					interrupts = <78>;
+					ti,rproc = <&wkup_m3>;
+					mboxes = <&mailbox &mbox_wkupm3>;
+				edma_xbar: dma-router at f90 {
+					compatible = "ti,am335x-edma-crossbar";
+					reg = <0xf90 0x40>;
+					#dma-cells = <3>;
+					dma-requests = <32>;
+					dma-masters = <&edma>;
+				scm_clockdomains: clockdomains {
+		intc: interrupt-controller at 48200000 {
+			compatible = "ti,am33xx-intc";
+			interrupt-controller;
+			#interrupt-cells = <1>;
+			reg = <0x48200000 0x1000>;
+		edma: edma at 49000000 {
+			compatible = "ti,edma3-tpcc";
+			ti,hwmods = "tpcc";
+			reg =	<0x49000000 0x10000>;
+			reg-names = "edma3_cc";
+			interrupts = <12 13 14>;
+			interrupt-names = "edma3_ccint", "edma3_mperr",
+					  "edma3_ccerrint";
+			dma-requests = <64>;
+			#dma-cells = <2>;
+			ti,tptcs = <&edma_tptc0 7>, <&edma_tptc1 5>,
+				   <&edma_tptc2 0>;
+			ti,edma-memcpy-channels = <20 21>;
+		edma_tptc0: tptc at 49800000 {
+			compatible = "ti,edma3-tptc";
+			ti,hwmods = "tptc0";
+			reg =	<0x49800000 0x100000>;
+			interrupts = <112>;
+			interrupt-names = "edma3_tcerrint";
+		edma_tptc1: tptc at 49900000 {
+			ti,hwmods = "tptc1";
+			reg =	<0x49900000 0x100000>;
+			interrupts = <113>;
+		edma_tptc2: tptc at 49a00000 {
+			ti,hwmods = "tptc2";
+			reg =	<0x49a00000 0x100000>;
+			interrupts = <114>;
+		gpio0: gpio at 44e07000 {
+			compatible = "ti,omap4-gpio";
+			ti,hwmods = "gpio1";
+			gpio-controller;
+			#gpio-cells = <2>;
+			#interrupt-cells = <2>;
+			reg = <0x44e07000 0x1000>;
+			interrupts = <96>;
+		gpio1: gpio at 4804c000 {
+			ti,hwmods = "gpio2";
+			gpio-controller;
+			reg = <0x4804c000 0x1000>;
+			interrupts = <98>;
+		gpio2: gpio at 481ac000 {
+			ti,hwmods = "gpio3";
+			gpio-controller;
+			reg = <0x481ac000 0x1000>;
+			interrupts = <32>;
+		gpio3: gpio at 481ae000 {
+			ti,hwmods = "gpio4";
+			gpio-controller;
+			reg = <0x481ae000 0x1000>;
+			interrupts = <62>;
+		uart0: serial at 44e09000 {
+			compatible = "ti,am3352-uart", "ti,omap3-uart";
+			ti,hwmods = "uart1";
+			clock-frequency = <48000000>;
+			reg = <0x44e09000 0x2000>;
+			interrupts = <72>;
+			status = "disabled";
+			dmas = <&edma 26 0>, <&edma 27 0>;
+			dma-names = "tx", "rx";
+		uart1: serial at 48022000 {
+			ti,hwmods = "uart2";
+			reg = <0x48022000 0x2000>;
+			interrupts = <73>;
+			dmas = <&edma 28 0>, <&edma 29 0>;
+		uart2: serial at 48024000 {
+			ti,hwmods = "uart3";
+			reg = <0x48024000 0x2000>;
+			interrupts = <74>;
+			dmas = <&edma 30 0>, <&edma 31 0>;
+		uart3: serial at 481a6000 {
+			ti,hwmods = "uart4";
+			reg = <0x481a6000 0x2000>;
+			interrupts = <44>;
+		uart4: serial at 481a8000 {
+			ti,hwmods = "uart5";
+			reg = <0x481a8000 0x2000>;
+			interrupts = <45>;
+		uart5: serial at 481aa000 {
+			ti,hwmods = "uart6";
+			reg = <0x481aa000 0x2000>;
+			interrupts = <46>;
+		i2c0: i2c at 44e0b000 {
+			compatible = "ti,omap4-i2c";
+			ti,hwmods = "i2c1";
+			reg = <0x44e0b000 0x1000>;
+			interrupts = <70>;
+		i2c1: i2c at 4802a000 {
+			ti,hwmods = "i2c2";
+			reg = <0x4802a000 0x1000>;
+			interrupts = <71>;
+		i2c2: i2c at 4819c000 {
+			ti,hwmods = "i2c3";
+			reg = <0x4819c000 0x1000>;
+			interrupts = <30>;
+		mmc1: mmc at 48060000 {
+			compatible = "ti,omap4-hsmmc";
+			ti,hwmods = "mmc1";
+			ti,dual-volt;
+			ti,needs-special-reset;
+			ti,needs-special-hs-handling;
+			dmas = <&edma_xbar 24 0 0
+				&edma_xbar 25 0 0>;
+			interrupts = <64>;
+			reg = <0x48060000 0x1000>;
+		mmc2: mmc at 481d8000 {
+			ti,hwmods = "mmc2";
+			dmas = <&edma 2 0
+				&edma 3 0>;
+			interrupts = <28>;
+			reg = <0x481d8000 0x1000>;
+		mmc3: mmc at 47810000 {
+			ti,hwmods = "mmc3";
+			interrupts = <29>;
+			reg = <0x47810000 0x1000>;
+		hwspinlock: spinlock at 480ca000 {
+			compatible = "ti,omap4-hwspinlock";
+			reg = <0x480ca000 0x1000>;
+			ti,hwmods = "spinlock";
+			#hwlock-cells = <1>;
+		wdt2: wdt at 44e35000 {
+			compatible = "ti,omap3-wdt";
+			ti,hwmods = "wd_timer2";
+			reg = <0x44e35000 0x1000>;
+			interrupts = <91>;
+		dcan0: can at 481cc000 {
+			compatible = "ti,am3352-d_can";
+			ti,hwmods = "d_can0";
+			reg = <0x481cc000 0x2000>;
+			clocks = <&dcan0_fck>;
+			clock-names = "fck";
+			syscon-raminit = <&scm_conf 0x644 0>;
+			interrupts = <52>;
+		dcan1: can at 481d0000 {
+			ti,hwmods = "d_can1";
+			reg = <0x481d0000 0x2000>;
+			clocks = <&dcan1_fck>;
+			syscon-raminit = <&scm_conf 0x644 1>;
+			interrupts = <55>;
+		mailbox: mailbox at 480C8000 {
+			compatible = "ti,omap4-mailbox";
+			reg = <0x480C8000 0x200>;
+			interrupts = <77>;
+			ti,hwmods = "mailbox";
+			#mbox-cells = <1>;
+			ti,mbox-num-users = <4>;
+			ti,mbox-num-fifos = <8>;
+			mbox_wkupm3: wkup_m3 {
+				ti,mbox-send-noirq;
+				ti,mbox-tx = <0 0 0>;
+				ti,mbox-rx = <0 0 3>;
+		timer1: timer at 44e31000 {
+			compatible = "ti,am335x-timer-1ms";
+			reg = <0x44e31000 0x400>;
+			interrupts = <67>;
+			ti,hwmods = "timer1";
+			ti,timer-alwon;
+		timer2: timer at 48040000 {
+			compatible = "ti,am335x-timer";
+			reg = <0x48040000 0x400>;
+			interrupts = <68>;
+			ti,hwmods = "timer2";
+		timer3: timer at 48042000 {
+			reg = <0x48042000 0x400>;
+			interrupts = <69>;
+			ti,hwmods = "timer3";
+		timer4: timer at 48044000 {
+			reg = <0x48044000 0x400>;
+			interrupts = <92>;
+			ti,hwmods = "timer4";
+			ti,timer-pwm;
+		timer5: timer at 48046000 {
+			reg = <0x48046000 0x400>;
+			interrupts = <93>;
+			ti,hwmods = "timer5";
+			ti,timer-pwm;
+		timer6: timer at 48048000 {
+			reg = <0x48048000 0x400>;
+			interrupts = <94>;
+			ti,hwmods = "timer6";
+			ti,timer-pwm;
+		timer7: timer at 4804a000 {
+			reg = <0x4804a000 0x400>;
+			interrupts = <95>;
+			ti,hwmods = "timer7";
+			ti,timer-pwm;
+		rtc: rtc at 44e3e000 {
+			compatible = "ti,am3352-rtc", "ti,da830-rtc";
+			reg = <0x44e3e000 0x1000>;
+			interrupts = <75
+				      76>;
+			ti,hwmods = "rtc";
+			clock-names = "int-clk";
+		spi0: spi at 48030000 {
+			compatible = "ti,omap4-mcspi";
+			reg = <0x48030000 0x400>;
+			interrupts = <65>;
+			ti,spi-num-cs = <2>;
+			ti,hwmods = "spi0";
+			dmas = <&edma 16 0
+				&edma 17 0
+				&edma 18 0
+				&edma 19 0>;
+			dma-names = "tx0", "rx0", "tx1", "rx1";
+		spi1: spi at 481a0000 {
+			reg = <0x481a0000 0x400>;
+			interrupts = <125>;
+			ti,hwmods = "spi1";
+			dmas = <&edma 42 0
+				&edma 43 0
+				&edma 44 0
+				&edma 45 0>;
+		usb: usb at 47400000 {
+			compatible = "ti,am33xx-usb";
+			reg = <0x47400000 0x1000>;
+			ranges;
+			ti,hwmods = "usb_otg_hs";
+			usb_ctrl_mod: control at 44e10620 {
+				compatible = "ti,am335x-usb-ctrl-module";
+				reg = <0x44e10620 0x10
+					0x44e10648 0x4>;
+				reg-names = "phy_ctrl", "wakeup";
+			usb0_phy: usb-phy at 47401300 {
+				compatible = "ti,am335x-usb-phy";
+				reg = <0x47401300 0x100>;
+				reg-names = "phy";
+				ti,ctrl_mod = <&usb_ctrl_mod>;
+			usb0: usb at 47401000 {
+				compatible = "ti,musb-am33xx";
+				reg = <0x47401400 0x400
+					0x47401000 0x200>;
+				reg-names = "mc", "control";
+				interrupts = <18>;
+				interrupt-names = "mc";
+				dr_mode = "otg";
+				mentor,multipoint = <1>;
+				mentor,num-eps = <16>;
+				mentor,ram-bits = <12>;
+				mentor,power = <500>;
+				phys = <&usb0_phy>;
+				dmas = <&cppi41dma  0 0 &cppi41dma  1 0
+					&cppi41dma  2 0 &cppi41dma  3 0
+					&cppi41dma  4 0 &cppi41dma  5 0
+					&cppi41dma  6 0 &cppi41dma  7 0
+					&cppi41dma  8 0 &cppi41dma  9 0
+					&cppi41dma 10 0 &cppi41dma 11 0
+					&cppi41dma 12 0 &cppi41dma 13 0
+					&cppi41dma 14 0 &cppi41dma  0 1
+					&cppi41dma  1 1 &cppi41dma  2 1
+					&cppi41dma  3 1 &cppi41dma  4 1
+					&cppi41dma  5 1 &cppi41dma  6 1
+					&cppi41dma  7 1 &cppi41dma  8 1
+					&cppi41dma  9 1 &cppi41dma 10 1
+					&cppi41dma 11 1 &cppi41dma 12 1
+					&cppi41dma 13 1 &cppi41dma 14 1>;
+				dma-names =
+					"rx1", "rx2", "rx3", "rx4", "rx5", "rx6", "rx7",
+					"rx8", "rx9", "rx10", "rx11", "rx12", "rx13",
+					"rx14", "rx15",
+					"tx1", "tx2", "tx3", "tx4", "tx5", "tx6", "tx7",
+					"tx8", "tx9", "tx10", "tx11", "tx12", "tx13",
+					"tx14", "tx15";
+			usb1_phy: usb-phy at 47401b00 {
+				reg = <0x47401b00 0x100>;
+			usb1: usb at 47401800 {
+				reg = <0x47401c00 0x400
+					0x47401800 0x200>;
+				interrupts = <19>;
+				dr_mode = "otg";
+				phys = <&usb1_phy>;
+				dmas = <&cppi41dma 15 0 &cppi41dma 16 0
+					&cppi41dma 17 0 &cppi41dma 18 0
+					&cppi41dma 19 0 &cppi41dma 20 0
+					&cppi41dma 21 0 &cppi41dma 22 0
+					&cppi41dma 23 0 &cppi41dma 24 0
+					&cppi41dma 25 0 &cppi41dma 26 0
+					&cppi41dma 27 0 &cppi41dma 28 0
+					&cppi41dma 29 0 &cppi41dma 15 1
+					&cppi41dma 16 1 &cppi41dma 17 1
+					&cppi41dma 18 1 &cppi41dma 19 1
+					&cppi41dma 20 1 &cppi41dma 21 1
+					&cppi41dma 22 1 &cppi41dma 23 1
+					&cppi41dma 24 1 &cppi41dma 25 1
+					&cppi41dma 26 1 &cppi41dma 27 1
+					&cppi41dma 28 1 &cppi41dma 29 1>;
+				dma-names =
+					"rx14", "rx15",
+					"tx14", "tx15";
+			cppi41dma: dma-controller at 47402000 {
+				compatible = "ti,am3359-cppi41";
+					0x47402000 0x1000
+					0x47403000 0x1000
+					0x47404000 0x4000>;
+				reg-names = "glue", "controller", "scheduler", "queuemgr";
+				interrupts = <17>;
+				interrupt-names = "glue";
+				#dma-cells = <2>;
+				#dma-channels = <30>;
+				#dma-requests = <256>;
+		epwmss0: epwmss at 48300000 {
+			compatible = "ti,am33xx-pwmss";
+			reg = <0x48300000 0x10>;
+			ti,hwmods = "epwmss0";
+			ranges = <0x48300100 0x48300100 0x80   /* ECAP */
+				  0x48300180 0x48300180 0x80   /* EQEP */
+				  0x48300200 0x48300200 0x80>; /* EHRPWM */
+			ecap0: ecap at 48300100 {
+				compatible = "ti,am3352-ecap",
+					     "ti,am33xx-ecap";
+				#pwm-cells = <3>;
+				reg = <0x48300100 0x80>;
+				interrupts = <31>;
+				interrupt-names = "ecap0";
+			ehrpwm0: pwm at 48300200 {
+				compatible = "ti,am3352-ehrpwm",
+					     "ti,am33xx-ehrpwm";
+				#pwm-cells = <3>;
+				reg = <0x48300200 0x80>;
+				clocks = <&ehrpwm0_tbclk>, <&l4ls_gclk>;
+				clock-names = "tbclk", "fck";
+		epwmss1: epwmss at 48302000 {
+			reg = <0x48302000 0x10>;
+			ti,hwmods = "epwmss1";
+			ranges = <0x48302100 0x48302100 0x80   /* ECAP */
+				  0x48302180 0x48302180 0x80   /* EQEP */
+				  0x48302200 0x48302200 0x80>; /* EHRPWM */
+			ecap1: ecap at 48302100 {
+					     "ti,am33xx-ecap";
+				#pwm-cells = <3>;
+				reg = <0x48302100 0x80>;
+				interrupts = <47>;
+				interrupt-names = "ecap1";
+			ehrpwm1: pwm at 48302200 {
+				#pwm-cells = <3>;
+				reg = <0x48302200 0x80>;
+				clocks = <&ehrpwm1_tbclk>, <&l4ls_gclk>;
+		epwmss2: epwmss at 48304000 {
+			reg = <0x48304000 0x10>;
+			ti,hwmods = "epwmss2";
+			ranges = <0x48304100 0x48304100 0x80   /* ECAP */
+				  0x48304180 0x48304180 0x80   /* EQEP */
+				  0x48304200 0x48304200 0x80>; /* EHRPWM */
+			ecap2: ecap at 48304100 {
+					     "ti,am33xx-ecap";
+				#pwm-cells = <3>;
+				reg = <0x48304100 0x80>;
+				interrupts = <61>;
+				interrupt-names = "ecap2";
+			ehrpwm2: pwm at 48304200 {
+				#pwm-cells = <3>;
+				reg = <0x48304200 0x80>;
+				clocks = <&ehrpwm2_tbclk>, <&l4ls_gclk>;
+		mac: ethernet at 4a100000 {
+			compatible = "ti,am335x-cpsw","ti,cpsw";
+			ti,hwmods = "cpgmac0";
+			clocks = <&cpsw_125mhz_gclk>, <&cpsw_cpts_rft_clk>;
+			clock-names = "fck", "cpts";
+			cpdma_channels = <8>;
+			ale_entries = <1024>;
+			bd_ram_size = <0x2000>;
+			mac_control = <0x20>;
+			slaves = <2>;
+			active_slave = <0>;
+			cpts_clock_mult = <0x80000000>;
+			cpts_clock_shift = <29>;
+			reg = <0x4a100000 0x800
+			       0x4a101200 0x100>;
+			 * c0_rx_thresh_pend
+			 * c0_rx_pend
+			 * c0_tx_pend
+			 * c0_misc_pend
+			interrupts = <40 41 42 43>;
+			ranges;
+			davinci_mdio: mdio at 4a101000 {
+				compatible = "ti,cpsw-mdio","ti,davinci_mdio";
+				ti,hwmods = "davinci_mdio";
+				bus_freq = <1000000>;
+				reg = <0x4a101000 0x100>;
+			cpsw_emac0: slave at 4a100200 {
+				/* Filled in by U-Boot */
+				mac-address = [ 00 00 00 00 00 00 ];
+			cpsw_emac1: slave at 4a100300 {
+			phy_sel: cpsw-phy-sel at 44e10650 {
+				compatible = "ti,am3352-cpsw-phy-sel";
+				reg= <0x44e10650 0x4>;
+				reg-names = "gmii-sel";
+		ocmcram: ocmcram at 40300000 {
+			compatible = "mmio-sram";
+			reg = <0x40300000 0x10000>; /* 64k */
+		elm: elm at 48080000 {
+			compatible = "ti,am3352-elm";
+			reg = <0x48080000 0x2000>;
+			interrupts = <4>;
+			ti,hwmods = "elm";
+		lcdc: lcdc at 4830e000 {
+			compatible = "ti,am33xx-tilcdc";
+			reg = <0x4830e000 0x1000>;
+			interrupts = <36>;
+			ti,hwmods = "lcdc";
+		tscadc: tscadc at 44e0d000 {
+			compatible = "ti,am3359-tscadc";
+			reg = <0x44e0d000 0x1000>;
+			interrupts = <16>;
+			ti,hwmods = "adc_tsc";
+			dmas = <&edma 53 0>, <&edma 57 0>;
+			dma-names = "fifo0", "fifo1";
+			tsc {
+				compatible = "ti,am3359-tsc";
+			am335x_adc: adc {
+				#io-channel-cells = <1>;
+				compatible = "ti,am3359-adc";
+		gpmc: gpmc at 50000000 {
+			compatible = "ti,am3352-gpmc";
+			ti,hwmods = "gpmc";
+			ti,no-idle-on-init;
+			reg = <0x50000000 0x2000>;
+			interrupts = <100>;
+			dmas = <&edma 52 0>;
+			dma-names = "rxtx";
+			gpmc,num-cs = <7>;
+			gpmc,num-waitpins = <2>;
+			#address-cells = <2>;
+			gpio-controller;
+		sham: sham at 53100000 {
+			compatible = "ti,omap4-sham";
+			ti,hwmods = "sham";
+			reg = <0x53100000 0x200>;
+			interrupts = <109>;
+			dmas = <&edma 36 0>;
+			dma-names = "rx";
+		aes: aes at 53500000 {
+			compatible = "ti,omap4-aes";
+			ti,hwmods = "aes";
+			reg = <0x53500000 0xa0>;
+			interrupts = <103>;
+			dmas = <&edma 6 0>,
+			       <&edma 5 0>;
+		mcasp0: mcasp at 48038000 {
+			compatible = "ti,am33xx-mcasp-audio";
+			ti,hwmods = "mcasp0";
+			reg = <0x48038000 0x2000>,
+			      <0x46000000 0x400000>;
+			reg-names = "mpu", "dat";
+			interrupts = <80>, <81>;
+			interrupt-names = "tx", "rx";
+			dmas = <&edma 8 2>,
+				<&edma 9 2>;
+		mcasp1: mcasp at 4803C000 {
+			ti,hwmods = "mcasp1";
+			reg = <0x4803C000 0x2000>,
+			      <0x46400000 0x400000>;
+			interrupts = <82>, <83>;
+			dmas = <&edma 10 2>,
+				<&edma 11 2>;
+		rng: rng at 48310000 {
+			compatible = "ti,omap4-rng";
+			ti,hwmods = "rng";
+			reg = <0x48310000 0x2000>;
+			interrupts = <111>;
+/include/ "am33xx-clocks.dtsi"
diff --git a/c/src/lib/libbsp/arm/beagle/simscripts/dt-bindings/display/tda998x.h b/c/src/lib/libbsp/arm/beagle/simscripts/dt-bindings/display/tda998x.h
index 0000000..34757a3
--- /dev/null
+++ b/c/src/lib/libbsp/arm/beagle/simscripts/dt-bindings/display/tda998x.h
@@ -0,0 +1,7 @@
+#ifndef _DT_BINDINGS_TDA998X_H
+#define _DT_BINDINGS_TDA998X_H
+#define TDA998x_SPDIF	1
+#define TDA998x_I2S	2
+#endif /*_DT_BINDINGS_TDA998X_H */
diff --git a/c/src/lib/libbsp/arm/beagle/simscripts/dt-bindings/gpio/gpio.h b/c/src/lib/libbsp/arm/beagle/simscripts/dt-bindings/gpio/gpio.h
index 0000000..b4f54da
--- /dev/null
+++ b/c/src/lib/libbsp/arm/beagle/simscripts/dt-bindings/gpio/gpio.h
@@ -0,0 +1,31 @@
+ * This header provides constants for most GPIO bindings.
+ * Most GPIO bindings include a flags cell as part of the GPIO specifier.
+ * In most cases, the format of the flags cell uses the standard values
+ * defined in this header.
+#ifndef _DT_BINDINGS_GPIO_GPIO_H
+#define _DT_BINDINGS_GPIO_GPIO_H
+/* Bit 0 express polarity */
+#define GPIO_ACTIVE_HIGH 0
+#define GPIO_ACTIVE_LOW 1
+/* Bit 1 express single-endedness */
+#define GPIO_PUSH_PULL 0
+#define GPIO_SINGLE_ENDED 2
+/* Bit 2 express Open drain or open source */
+#define GPIO_LINE_OPEN_SOURCE 0
+#define GPIO_LINE_OPEN_DRAIN 4
+ * Open Drain/Collector is the combination of single-ended open drain interface.
+ * Open Source/Emitter is the combination of single-ended open source interface.
+#define GPIO_OPEN_DRAIN (GPIO_SINGLE_ENDED | GPIO_LINE_OPEN_DRAIN)
+#define GPIO_OPEN_SOURCE (GPIO_SINGLE_ENDED | GPIO_LINE_OPEN_SOURCE)
+#endif
diff --git a/c/src/lib/libbsp/arm/beagle/simscripts/dt-bindings/pinctrl/am33xx.h b/c/src/lib/libbsp/arm/beagle/simscripts/dt-bindings/pinctrl/am33xx.h
index 0000000..226f772
--- /dev/null
+++ b/c/src/lib/libbsp/arm/beagle/simscripts/dt-bindings/pinctrl/am33xx.h
@@ -0,0 +1,43 @@
+ * This header provides constants specific to AM33XX pinctrl bindings.
+#ifndef _DT_BINDINGS_PINCTRL_AM33XX_H
+#define _DT_BINDINGS_PINCTRL_AM33XX_H
+#include <dt-bindings/pinctrl/omap.h>
+/* am33xx specific mux bit defines */
+#undef PULL_ENA
+#undef INPUT_EN
+#define PULL_DISABLE		(1 << 3)
+#define INPUT_EN		(1 << 5)
+#define SLEWCTRL_SLOW		(1 << 6)
+#define SLEWCTRL_FAST		0
+/* update macro depending on INPUT_EN and PULL_ENA */
+#undef PIN_OUTPUT
+#undef PIN_OUTPUT_PULLUP
+#undef PIN_OUTPUT_PULLDOWN
+#undef PIN_INPUT
+#undef PIN_INPUT_PULLUP
+#undef PIN_INPUT_PULLDOWN
+#define PIN_OUTPUT		(PULL_DISABLE)
+#define PIN_OUTPUT_PULLUP	(PULL_UP)
+#define PIN_OUTPUT_PULLDOWN	0
+#define PIN_INPUT		(INPUT_EN | PULL_DISABLE)
+#define PIN_INPUT_PULLUP	(INPUT_EN | PULL_UP)
+#define PIN_INPUT_PULLDOWN	(INPUT_EN)
+/* undef non-existing modes */
+#undef PIN_OFF_NONE
+#undef PIN_OFF_OUTPUT_HIGH
+#undef PIN_OFF_OUTPUT_LOW
+#undef PIN_OFF_INPUT_PULLUP
+#undef PIN_OFF_INPUT_PULLDOWN
+#undef PIN_OFF_WAKEUPENABLE
+#endif
diff --git a/c/src/lib/libbsp/arm/beagle/simscripts/dt-bindings/pinctrl/omap.h b/c/src/lib/libbsp/arm/beagle/simscripts/dt-bindings/pinctrl/omap.h
index 0000000..fbd6f72
--- /dev/null
+++ b/c/src/lib/libbsp/arm/beagle/simscripts/dt-bindings/pinctrl/omap.h
@@ -0,0 +1,90 @@
+ * This header provides constants for OMAP pinctrl bindings.
+ * Copyright (C) 2009 Nokia
+ * Copyright (C) 2009-2010 Texas Instruments
+#ifndef _DT_BINDINGS_PINCTRL_OMAP_H
+#define _DT_BINDINGS_PINCTRL_OMAP_H
+/* 34xx mux mode options for each pin. See TRM for options */
+#define MUX_MODE0	0
+#define MUX_MODE1	1
+#define MUX_MODE2	2
+#define MUX_MODE3	3
+#define MUX_MODE4	4
+#define MUX_MODE5	5
+#define MUX_MODE6	6
+#define MUX_MODE7	7
+/* 24xx/34xx mux bit defines */
+#define PULL_ENA		(1 << 3)
+#define PULL_UP			(1 << 4)
+#define ALTELECTRICALSEL	(1 << 5)
+/* omap3/4/5 specific mux bit defines */
+#define INPUT_EN		(1 << 8)
+#define OFF_EN			(1 << 9)
+#define OFFOUT_EN		(1 << 10)
+#define OFFOUT_VAL		(1 << 11)
+#define OFF_PULL_EN		(1 << 12)
+#define OFF_PULL_UP		(1 << 13)
+#define WAKEUP_EN		(1 << 14)
+#define WAKEUP_EVENT		(1 << 15)
+/* Active pin states */
+#define PIN_OUTPUT		0
+#define PIN_OUTPUT_PULLUP	(PIN_OUTPUT | PULL_ENA | PULL_UP)
+#define PIN_OUTPUT_PULLDOWN	(PIN_OUTPUT | PULL_ENA)
+#define PIN_INPUT		INPUT_EN
+#define PIN_INPUT_PULLUP	(PULL_ENA | INPUT_EN | PULL_UP)
+#define PIN_INPUT_PULLDOWN	(PULL_ENA | INPUT_EN)
+/* Off mode states */
+#define PIN_OFF_NONE		0
+#define PIN_OFF_OUTPUT_HIGH	(OFF_EN | OFFOUT_EN | OFFOUT_VAL)
+#define PIN_OFF_OUTPUT_LOW	(OFF_EN | OFFOUT_EN)
+#define PIN_OFF_INPUT_PULLUP	(OFF_EN | OFFOUT_EN | OFF_PULL_EN | OFF_PULL_UP)
+#define PIN_OFF_INPUT_PULLDOWN	(OFF_EN | OFFOUT_EN | OFF_PULL_EN)
+#define PIN_OFF_WAKEUPENABLE	WAKEUP_EN
+ * Macros to allow using the absolute physical address instead of the
+ * padconf registers instead of the offset from padconf base.
+#define OMAP_IOPAD_OFFSET(pa, offset)	(((pa) & 0xffff) - (offset))
+#define OMAP2420_CORE_IOPAD(pa, val)	OMAP_IOPAD_OFFSET((pa), 0x0030) (val)
+#define OMAP2430_CORE_IOPAD(pa, val)	OMAP_IOPAD_OFFSET((pa), 0x2030) (val)
+#define OMAP3_CORE1_IOPAD(pa, val)	OMAP_IOPAD_OFFSET((pa), 0x2030) (val)
+#define OMAP3430_CORE2_IOPAD(pa, val)	OMAP_IOPAD_OFFSET((pa), 0x25d8) (val)
+#define OMAP3630_CORE2_IOPAD(pa, val)	OMAP_IOPAD_OFFSET((pa), 0x25a0) (val)
+#define OMAP3_WKUP_IOPAD(pa, val)	OMAP_IOPAD_OFFSET((pa), 0x2a00) (val)
+#define DM814X_IOPAD(pa, val)		OMAP_IOPAD_OFFSET((pa), 0x0800) (val)
+#define DM816X_IOPAD(pa, val)		OMAP_IOPAD_OFFSET((pa), 0x0800) (val)
+#define AM33XX_IOPAD(pa, val)		OMAP_IOPAD_OFFSET((pa), 0x0800) (val)
+ * Macros to allow using the offset from the padconf physical address
+ * instead  of the offset from padconf base.
+#define OMAP_PADCONF_OFFSET(offset, base_offset)	((offset) - (base_offset))
+#define OMAP4_IOPAD(offset, val)	OMAP_PADCONF_OFFSET((offset), 0x0040) (val)
+#define OMAP5_IOPAD(offset, val)	OMAP_PADCONF_OFFSET((offset), 0x0040) (val)
+ * Define some commonly used pins configured by the boards.
+ * Note that some boards use alternative pins, so check
+ * the schematics before using these.
+#define OMAP3_UART1_RX		0x152
+#define OMAP3_UART2_RX		0x14a
+#define OMAP3_UART3_RX		0x16e
+#define OMAP4_UART2_RX		0xdc
+#define OMAP4_UART3_RX		0x104
+#define OMAP4_UART4_RX		0x11c
+#endif
diff --git a/c/src/lib/libbsp/arm/beagle/simscripts/sdcard.sh b/c/src/lib/libbsp/arm/beagle/simscripts/sdcard.sh
index 83e3807..ce7df5f 100644
--- a/c/src/lib/libbsp/arm/beagle/simscripts/sdcard.sh
+++ b/c/src/lib/libbsp/arm/beagle/simscripts/sdcard.sh
@@ -6,6 +6,7 @@ SIZE=65536
 OFFSET=2048
 FATSIZE=`expr $SIZE - $OFFSET`
 UENV=uEnv.txt
+dtb=am335x-boneblack.dtb
 rm -rf $TMPDIR
 mkdir -p $TMPDIR
@@ -50,6 +51,10 @@ set -e
 IMG=${imgtype}_`basename $2`-sdcard.img
+#Generate dtb file
+$PREFIX/bin/arm-rtems4.12-cpp -P -x assembler-with-cpp -I ./ am335x-boneblack.dts am335x-boneblack-processed.dts
+$PREFIX/bin/dtc -I dts -O dtb -o $dtb am335x-boneblack-processed.dts
 # Make an empty image
 dd if=/dev/zero of=$IMG bs=512 seek=`expr $SIZE - 1` count=1
 dd if=/dev/zero of=$FATIMG bs=512 seek=`expr $FATSIZE - 1` count=1
@@ -61,14 +66,15 @@ $PREFIX/bin/newfs_msdos -r 1 -m 0xf8 -c 4 -F16  -h 64 -u 32 -S 512 -s $FATSIZE -
 base=`basename $executable`
 $PREFIX/bin/arm-rtems4.12-objcopy $executable -O binary $TMPDIR/$base.bin
 gzip -9 $TMPDIR/$base.bin
-$PREFIX/bin/mkimage -A arm -O rtems -T kernel -a 0x80000000 -e 0x80000000 -n RTEMS -d $TMPDIR/$base.bin.gz $TMPDIR/$app
+$PREFIX/bin/mkimage -A arm -O linux -T kernel -a 0x80000000 -e 0x80000000 -n RTEMS -d $TMPDIR/$base.bin.gz $TMPDIR/$app
 echo "setenv bootdelay 5
 uenvcmd=run boot
-boot=fatload mmc 0 0x80800000 $app ; bootm 0x80800000" >$TMPDIR/$UENV
+boot=fatload mmc 0 0x80800000 $app ; fatload mmc 0 0x88000000 $dtb ; bootm 0x80800000 - 0x88000000" >$TMPDIR/$UENV
 # Copy the uboot and app image onto the FAT image
 $PREFIX/bin/mcopy -bsp -i $FATIMG $PREFIX/uboot/$ubootcfg/MLO ::MLO
 $PREFIX/bin/mcopy -bsp -i $FATIMG $PREFIX/uboot/$ubootcfg/u-boot.img ::u-boot.img
+$PREFIX/bin/mcopy -bsp -i $FATIMG $dtb ::$dtb
 $PREFIX/bin/mcopy -bsp -i $FATIMG $TMPDIR/$app ::$app
 $PREFIX/bin/mcopy -bsp -i $FATIMG $TMPDIR/$UENV ::$UENV
diff --git a/c/src/lib/libbsp/arm/beagle/simscripts/tps65217.dtsi b/c/src/lib/libbsp/arm/beagle/simscripts/tps65217.dtsi
index 0000000..02de56b
--- /dev/null
+++ b/c/src/lib/libbsp/arm/beagle/simscripts/tps65217.dtsi
@@ -0,0 +1,68 @@
+ * Integrated Power Management Chip
+ * http://www.ti.com/lit/ds/symlink/tps65217.pdf
+&tps {
+	compatible = "ti,tps65217";
+	charger {
+		compatible = "ti,tps65217-charger";
+	pwrbutton {
+		compatible = "ti,tps65217-pwrbutton";
+	regulators {
+			reg = <0>;
+			regulator-compatible = "dcdc1";
+			reg = <1>;
+			regulator-compatible = "dcdc2";
+			reg = <2>;
+			regulator-compatible = "dcdc3";
+			reg = <3>;
+			regulator-compatible = "ldo1";
+			reg = <4>;
+			regulator-compatible = "ldo2";
+			reg = <5>;
+			regulator-compatible = "ldo3";
+			reg = <6>;
+			regulator-compatible = "ldo4";
2.7.4
