[PATCH 1/7] rtems: Add rtems_scheduler_ident_by_processor()
Sebastian Huber
Tue Jul 11 13:41:09 UTC 2017
Update #3069.
cpukit/rtems/Makefile.am | 1 +
cpukit/rtems/include/rtems/rtems/tasks.h | 17 ++++++++++
cpukit/rtems/src/scheduleridentbyprocessor.c | 49 ++++++++++++++++++++++++++++
testsuites/smptests/smpfatal04/init.c | 6 ++++
testsuites/sptests/spscheduler01/init.c | 12 +++++++
5 files changed, 85 insertions(+)
create mode 100644 cpukit/rtems/src/scheduleridentbyprocessor.c
diff --git a/cpukit/rtems/Makefile.am b/cpukit/rtems/Makefile.am
index ada1f83510..e9ad2deb5d 100644
--- a/cpukit/rtems/Makefile.am
+++ b/cpukit/rtems/Makefile.am
@@ -108,6 +108,7 @@ librtems_a_SOURCES += src/taskwakewhen.c
librtems_a_SOURCES += src/scheduleraddprocessor.c
librtems_a_SOURCES += src/schedulergetprocessorset.c
librtems_a_SOURCES += src/schedulerident.c
+librtems_a_SOURCES += src/scheduleridentbyprocessor.c
librtems_a_SOURCES += src/schedulerremoveprocessor.c
## RATEMON_C_FILES
diff --git a/cpukit/rtems/include/rtems/rtems/tasks.h b/cpukit/rtems/include/rtems/rtems/tasks.h
index 88e43556ce..e68c78989d 100644
--- a/cpukit/rtems/include/rtems/rtems/tasks.h
+++ b/cpukit/rtems/include/rtems/rtems/tasks.h
@@ -560,6 +560,23 @@ rtems_status_code rtems_scheduler_ident(
+ * @brief Identifies a scheduler by a processor index.
+ * @param[in] cpu_index The processor index.
+ * @param[out] id The scheduler identifier associated with the processor index.
+ * @retval RTEMS_SUCCESSFUL Successful operation.
+ * @retval RTEMS_INVALID_ADDRESS The @a id parameter is @c NULL.
+ * @retval RTEMS_INVALID_NAME Invalid processor index.
+ * @retval RTEMS_INCORRECT_STATE The processor index is valid, however, this
+ * processor is not owned by a scheduler.
+rtems_status_code rtems_scheduler_ident_by_processor(
+ uint32_t cpu_index,
+ rtems_id *id
* @brief Gets the set of processors owned by the specified scheduler instance.
* @param[in] scheduler_id Identifier of the scheduler instance.
diff --git a/cpukit/rtems/src/scheduleridentbyprocessor.c b/cpukit/rtems/src/scheduleridentbyprocessor.c
new file mode 100644
index 0000000000..2bc64d77d3
--- /dev/null
+++ b/cpukit/rtems/src/scheduleridentbyprocessor.c
@@ -0,0 +1,49 @@
+ * Copyright (c) 2017 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/rtems/tasks.h>
+#include <rtems/score/assert.h>
+#include <rtems/score/schedulerimpl.h>
+ rtems_id *id
+ const Scheduler_Control *scheduler;
+ if ( id == NULL ) {
+ return RTEMS_INVALID_ADDRESS;
+ if ( cpu_index >= _SMP_Get_processor_count() ) {
+ return RTEMS_INVALID_NAME;
+ scheduler = _Scheduler_Get_by_CPU( _Per_CPU_Get_by_index( cpu_index ) );
+#if defined(RTEMS_SMP)
+ if ( scheduler == NULL ) {
+ return RTEMS_INCORRECT_STATE;
+#else
+ _Assert( scheduler != NULL );
+#endif
+ *id = _Scheduler_Build_id( _Scheduler_Get_index( scheduler ) );
+ return RTEMS_SUCCESSFUL;
diff --git a/testsuites/smptests/smpfatal04/init.c b/testsuites/smptests/smpfatal04/init.c
index 0215914ce8..73ef701c70 100644
--- a/testsuites/smptests/smpfatal04/init.c
+++ b/testsuites/smptests/smpfatal04/init.c
@@ -45,6 +45,12 @@ static void fatal_extension(
&& !always_set_to_false
&& code == SMP_FATAL_BOOT_PROCESSOR_NOT_ASSIGNED_TO_SCHEDULER
+ rtems_status_code sc;
+ rtems_id id;
+ sc = rtems_scheduler_ident_by_processor(0, &id);
+ assert(sc == RTEMS_INCORRECT_STATE);
TEST_END();
diff --git a/testsuites/sptests/spscheduler01/init.c b/testsuites/sptests/spscheduler01/init.c
index 9bdfacc8db..2415ace803 100644
--- a/testsuites/sptests/spscheduler01/init.c
+++ b/testsuites/sptests/spscheduler01/init.c
@@ -355,6 +355,18 @@ static void test_scheduler_ident(void)
rtems_test_assert(sc == RTEMS_SUCCESSFUL);
rtems_test_assert(scheduler_id == expected_id);
+ sc = rtems_scheduler_ident_by_processor(1, NULL);
+ rtems_test_assert(sc == RTEMS_INVALID_ADDRESS);
+ sc = rtems_scheduler_ident_by_processor(1, &scheduler_id);
+ rtems_test_assert(sc == RTEMS_INVALID_NAME);
+ scheduler_id = 0;
+ sc = rtems_scheduler_ident_by_processor(0, &scheduler_id);
+ rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+ rtems_test_assert(scheduler_id == expected_id);
static void test_scheduler_get_processors(void)
2.12.3
