[PATCH 2/7] rtems: Add rtems_scheduler_ident_by_processor_set
Tue Jul 11 14:59:34 UTC 2017
On Tue, Jul 11, 2017 at 9:41 AM, Sebastian Huber
> Update #3070.
>  cpukit/rtems/Makefile.am                        |  1 +
>  cpukit/rtems/include/rtems/rtems/tasks.h        | 25 +++++++++++
>  cpukit/rtems/src/scheduleridentbyprocessorset.c | 60 +++++++++++++++++++++++++
>  testsuites/smptests/smpscheduler02/init.c       | 11 +++++
>  testsuites/sptests/spscheduler01/init.c         | 19 ++++++++
>  5 files changed, 116 insertions(+)
>  create mode 100644 cpukit/rtems/src/scheduleridentbyprocessorset.c
> diff --git a/cpukit/rtems/Makefile.am b/cpukit/rtems/Makefile.am
> index e9ad2deb5d..da6e302e2e 100644
> --- a/cpukit/rtems/Makefile.am
> +++ b/cpukit/rtems/Makefile.am
> @@ -109,6 +109,7 @@ librtems_a_SOURCES += src/scheduleraddprocessor.c
>  librtems_a_SOURCES += src/schedulergetprocessorset.c
>  librtems_a_SOURCES += src/schedulerident.c
>  librtems_a_SOURCES += src/scheduleridentbyprocessor.c
> +librtems_a_SOURCES += src/scheduleridentbyprocessorset.c
>  librtems_a_SOURCES += src/schedulerremoveprocessor.c
>  ## RATEMON_C_FILES
> diff --git a/cpukit/rtems/include/rtems/rtems/tasks.h b/cpukit/rtems/include/rtems/rtems/tasks.h
> index e68c78989d..585f4c449c 100644
> --- a/cpukit/rtems/include/rtems/rtems/tasks.h
> +++ b/cpukit/rtems/include/rtems/rtems/tasks.h
> @@ -577,6 +577,31 @@ rtems_status_code rtems_scheduler_ident_by_processor(
> + * @brief Identifies a scheduler by a processor set.
> + * The scheduler is selected according to the highest numbered online processor
> + * in the specified processor set.
> + * @param[in] cpusetsize Size of the specified processor set buffer in
> + *   bytes.  This value must be positive.
> + * @param[out] cpuset The processor set to identify the scheduler.
> + * @param[out] id The scheduler identifier associated with the processor set.
> + * @retval RTEMS_SUCCESSFUL Successful operation.
> + * @retval RTEMS_INVALID_ADDRESS The @a id parameter is @c NULL.
> + * @retval RTEMS_INVALID_SIZE Invalid processor set size.
> + * @retval RTEMS_INVALID_NAME The processor set contains no online processor.
> + * @retval RTEMS_INCORRECT_STATE The processor set is valid, however, the
> + *   highest numbered online processor in the specified processor set is not
> + *   owned by a scheduler.
> +rtems_status_code rtems_scheduler_ident_by_processor_set(
> +  size_t           cpusetsize,
> +  const cpu_set_t *cpuset,
> +  rtems_id        *id
Also needs doc. I wonder if "identify" or "id" may be better. "ident"
seems a bit unusual.
>   * @brief Gets the set of processors owned by the specified scheduler instance.
>   * @param[in] scheduler_id Identifier of the scheduler instance.
> diff --git a/cpukit/rtems/src/scheduleridentbyprocessorset.c b/cpukit/rtems/src/scheduleridentbyprocessorset.c
> new file mode 100644
> index 0000000000..4988ed0fb8
> --- /dev/null
> +++ b/cpukit/rtems/src/scheduleridentbyprocessorset.c
> @@ -0,0 +1,60 @@
> + * Copyright (c) 2017 embedded brains GmbH.  All rights reserved.
> + *  embedded brains GmbH
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> + *  <rtems at embedded-brains.de>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.org/license/LICENSE.
> +#if HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <rtems/rtems/tasks.h>
> +#include <rtems/score/assert.h>
> +#include <rtems/score/schedulerimpl.h>
> +  rtems_id        *id
> +  Processor_mask              set;
> +  Processor_mask_Copy_status  status;
> +  uint32_t                    cpu_index;
> +  const Scheduler_Control    *scheduler;
> +  if ( id == NULL ) {
> +    return RTEMS_INVALID_ADDRESS;
> +  status = _Processor_mask_From_cpu_set_t( &set, cpusetsize, cpuset );
> +  if ( status == PROCESSOR_MASK_COPY_INVALID_SIZE ) {
> +    return RTEMS_INVALID_SIZE;
> +  _Processor_mask_And( &set, &set, _SMP_Get_online_processors() );
> +  cpu_index = _Processor_mask_Find_last_set( &set );
> +  if ( cpu_index == 0 ) {
> +    return RTEMS_INVALID_NAME;
> +  scheduler = _Scheduler_Get_by_CPU( _Per_CPU_Get_by_index( cpu_index - 1) );
> +#if defined(RTEMS_SMP)
> +  if ( scheduler == NULL ) {
> +    return RTEMS_INCORRECT_STATE;
> +#else
> +  _Assert( scheduler != NULL );
> +#endif
> +  *id = _Scheduler_Build_id( _Scheduler_Get_index( scheduler ) );
> +  return RTEMS_SUCCESSFUL;
> diff --git a/testsuites/smptests/smpscheduler02/init.c b/testsuites/smptests/smpscheduler02/init.c
> index 7dd60ec4c5..3975802d4a 100644
> --- a/testsuites/smptests/smpscheduler02/init.c
> +++ b/testsuites/smptests/smpscheduler02/init.c
> @@ -134,8 +134,10 @@ static void test_scheduler_add_remove_processors(void)
>    rtems_test_assert(sc == RTEMS_RESOURCE_IN_USE);
>    if (rtems_get_processor_count() > 1) {
> +    rtems_id scheduler_id;
>      rtems_id scheduler_b_id;
>      rtems_id task_id;
> +    cpu_set_t first_cpu;
>      sc = rtems_scheduler_ident(SCHED_B, &scheduler_b_id);
>      rtems_test_assert(sc == RTEMS_SUCCESSFUL);
> @@ -153,6 +155,15 @@ static void test_scheduler_add_remove_processors(void)
>      rtems_test_assert(rtems_get_current_processor() == 1);
> +    CPU_ZERO(&first_cpu);
> +    CPU_SET(0, &first_cpu);
> +    sc = rtems_scheduler_ident_by_processor_set(
> +      sizeof(first_cpu),
> +      &first_cpu,
> +      &scheduler_id
> +    rtems_test_assert(sc == RTEMS_INCORRECT_STATE);
>      sc = rtems_scheduler_add_processor(scheduler_a_id, 0);
> diff --git a/testsuites/sptests/spscheduler01/init.c b/testsuites/sptests/spscheduler01/init.c
> index 2415ace803..9840a3ebc4 100644
> --- a/testsuites/sptests/spscheduler01/init.c
> +++ b/testsuites/sptests/spscheduler01/init.c
> @@ -343,6 +343,7 @@ static void test_scheduler_ident(void)
>    rtems_name name = BLUE;
>    rtems_name invalid_name = RED;
> +  cpu_set_t s;
>    sc = rtems_scheduler_ident(name, NULL);
>    rtems_test_assert(sc == RTEMS_INVALID_ADDRESS);
> @@ -367,6 +368,24 @@ static void test_scheduler_ident(void)
>    rtems_test_assert(scheduler_id == expected_id);
> +  CPU_ZERO(&s);
> +  CPU_SET(1, &s);
> +  sc = rtems_scheduler_ident_by_processor_set(sizeof(s), &s, NULL);
> +  rtems_test_assert(sc == RTEMS_INVALID_ADDRESS);
> +  sc = rtems_scheduler_ident_by_processor_set(1, &s, &scheduler_id);
> +  rtems_test_assert(sc == RTEMS_INVALID_SIZE);
> +  sc = rtems_scheduler_ident_by_processor_set(sizeof(s), &s, &scheduler_id);
> +  rtems_test_assert(sc == RTEMS_INVALID_NAME);
> +  CPU_SET(0, &s);
> +  scheduler_id = 0;
> +  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
> +  rtems_test_assert(scheduler_id == expected_id);
>  static void test_scheduler_get_processors(void)
> 2.12.3
> devel mailing list
> devel at rtems.org
