[PATCH 2/7] rtems: Add rtems_scheduler_ident_by_processor_set
Wed Jul 12 12:10:12 UTC 2017
On Wed, Jul 12, 2017 at 1:36 AM, Sebastian Huber
> On 11/07/17 16:59, Gedare Bloom wrote:
>>> +rtems_status_code rtems_scheduler_ident_by_processor_set(
>>> +  size_t           cpusetsize,
>>> +  const cpu_set_t *cpuset,
>>> +  rtems_id        *id
>> Also needs doc. I wonder if "identify" or "id" may be better. "ident"
>> seems a bit unusual.
> All the object identification by name operations use rtems_class_ident().
> So, I made it rtems_class_ident_by_x().
You're right, that is good.
