Trace Block Inconsistent with Coverage Map
Cillian O'Donnell cpodonnell8 at gmail.com
Wed Jul 12 17:13:28 UTC 2017
I just want to give an update to my understanding of this problem as
I'm not sure I was clear enough in the IRC meeting. We ended up
talking about nops but I think the problem is something else.
So when there is a successful covoar run, it will generate a report
but also finish with this message.
*** Trace block is inconsistent with coverage map
*** Trace block (0x4000c2cc - 0x4000c2ec) for 36 bytes
*** Coverage map /home/cpod/coverage_test/leon3/coverage/base_sp.exe.cov
The coverage map is 24 bytes:
(gdb) p/x *entry
$2 = {pc = 0x4000c2cc, size = 0x24, op = 0x12}
The disassembly block in question is:
4000c2cc <_Objects_Get_information_id>:
4000c2cc:   83 32 20 18     srl  %o0, 0x18, %g1
Objects_Information *_Objects_Get_information_id(
  Objects_Id  id
  return _Objects_Get_information(
4000c2d0:   93 32 20 1b     srl  %o0, 0x1b, %o1
4000c2d4:   90 08 60 07     and  %g1, 7, %o0
4000c2d8:   82 13 c0 00     mov  %o7, %g1
4000c2dc:   40 00 00 02     call  4000c2e4 <_Objects_Get_information>
4000c2e0:   9e 10 40 00     mov  %g1, %o7
4000c2e4 <_Objects_Get_information>:
Objects_Information *_Objects_Get_information(
  Objects_APIs   the_api,
  uint16_t       the_class
4000c2e4:   9d e3 bf a0     save  %sp, -96, %sp
  Objects_Information *info;
  int the_class_api_maximum;
  if ( !the_class )
4000c2e8:   80 a6 60 00     cmp  %i1, 0
4000c2ec:   02 80 00 19     be  4000c350 <_Objects_Get_information+0x6c>
4000c2f0:   01 00 00 00     nop
I have checked this out on base_sp.exe and ticker.exe where the same
inconsistency appears in both. Couverture-QEMU decides the trace block
encompasses that entire block
Whereas from the covoar side the objdump is always processed line by
line and a regex is checked to determine what kind of line it is.
408       items = sscanf(
409         inputBuffer,
410         "%x <%[^>]>%c",
411         &offset, symbol, &terminator1
412       );
If there is a match for all 3 items then this is a new function
415       if ((items == 3) && (terminator1 == ':')) {
416
417         endAddress = executableInformation->getLoadAddress() + offset - 1;
So the objdump above is always processed as 2 seperate sections.
One for:
And one for:
The size from Objects_Get_information_id to Objects_Get_information is
24 bytes which is the coverage map.
The size of both functions combined is 36 bytes which is the
Couverture trace block.
Couverture could possibly be doing something more sophisticated to
determine the end of the block or it could just be wrong. So the next
thing I'm doing is figuring out exactly how Couverture is processing
this.
For both cases the trace op code is 0x12 which means 'Branch fully
executed' and 'Branch not taken'. I'm trying to find one with op code
0x11 which would mean the 'branch is taken' and possibly it might be
processed differently in this case. The only place both these
functions appear in the source is libtests/dl04 and dl05. I'm checking
those out at the moment.
Thanks,
Cillian.
