[PATCH v2 1/2] Import am335x usb driver file from FreeBSD.
Thu Jul 13 05:07:25 UTC 2017
The patches are all right, but I was not able to apply them:
Applying: Import am335x usb driver file from FreeBSD.
.git/rebase-apply/patch:1266: trailing whitespace.
          * For now set frequency to 2*VGA_PIXEL_CLOCK
.git/rebase-apply/patch:1510: trailing whitespace.
.git/rebase-apply/patch:1769: trailing whitespace.
  *      ti_*_clk_devmap - Array of clock devices, should be defined one
per SoC
.git/rebase-apply/patch:1783: trailing whitespace.
  *      to the clock device if found.
.git/rebase-apply/patch:1795: trailing whitespace.
error: corrupt patch at line 7336
Patch failed at 0001 Import am335x usb driver file from FreeBSD.
The copy of the patch that failed is found in: .git/rebase-apply/patch
When you have resolved this problem, run "git am --continue".
If you prefer to skip this patch, run "git am --skip" instead.
To restore the original branch and stop patching, run "git am --abort".
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
