[PATCH v2 2/2] Add dts file to generate dtb binary file for Beaglebone black.
Thu Jul 13 06:05:33 UTC 2017
On 13/07/2017 15:09, Christian Mauderer wrote:
> Am 13.07.2017 um 04:33 schrieb Chris Johns:
>> On 13/07/2017 12:22, Sichen Zhao wrote:
>>> 在 2017年07月12日 21:52, Gedare Bloom 写道:
>>>> On Tue, Jul 11, 2017 at 6:51 AM, Sichen Zhao <1473996754 at qq.com> wrote:
>>>>> +These files are imported from FreeBSD.
>>>>> +These files is licensed under the terms of the GNU General Public License * version 2.
>>>> We should not pollute the RTEMS sources with GPL2 code. Is there an
>>>> alternative approach to use?
>>> The another way is to directly use dtb binary file, but bin file also
>>> has a gpl2 license. So this way is not acceptable.
>>> Gedare said the scripts directory may be appropriate for rtems-tools.git
>>> or something. So i can provide a default one that can be used, it may be
>>> downloadable from somewhere e.g. in rtems-tools or from a FTP.
>>> And this is the way to keep GPL code from RTEMS sources.
>>> What do you think about?
>> The ftp site is ok but please make sure you have the source with any binary file
>> and all copyright details are valid.
>> We should keep the rtems-tools.git repo as free of GPL as possible.
>> Chris
> Seems like no one wants the device tree files in any rtems repo. Do we
> need an extra rtems-devicetree repository for all BSPs that support
> device trees (currently two)?
Yeah, I do not really know. It is a sort of gray area and not only for the
licenses but how we integrate it. It is sort of like boot loaders and how they
fit in. I hope this discussion can finding a way we can make this work.
My concern with rtems-tool.git is the license for it 2-clause BSD and then we
place some GPL code in it and users do not know and are caught out with
compliance issues. For example I have some GPL code in the rtemstoolkit which is
from libiberty [1]. I included as a way to get something working on all hosts
quickly. I would like to change this but need the time to do that. At the moment
rtems-tools is only on hosts so a bit simpler for users to manage.
> Maybe one that just takes over the scripts
> from FreeBSD to import the device tree sources from Linux?
Does FreeBSD import the files into it's source tree from Linux?
Can I assume loading a GPL DTB does not pollute the application?
[1] https://git.rtems.org/rtems-tools/tree/rtemstoolkit/libiberty/pex-common.c
