[PATCH] sparc: Rename NGMP to GR740 and add configs for UT699, UT700, and GR712RC
Daniel Cederman
cederman at gaisler.com
Thu Jul 13 08:34:10 UTC 2017
The UT699 requires -mcpu=leon as it does not support the CAS instruction
provided by -mcpu=leon3. It also requires -mfix-ut699 for errata fixes.
UT700 and GR712RC requires the -mfix-ut700 and -mfix-gr712rc flags that
have been recently added to GCC's master and 7-branch.
c/src/lib/libbsp/sparc/leon3/Makefile.am | 5 ++++-
c/src/lib/libbsp/sparc/leon3/make/custom/gr712rc.cfg | 18 ++++++++++++++++++
.../sparc/leon3/make/custom/{ngmp.cfg => gr740.cfg} | 0
c/src/lib/libbsp/sparc/leon3/make/custom/ut699.cfg | 18 ++++++++++++++++++
c/src/lib/libbsp/sparc/leon3/make/custom/ut700.cfg | 18 ++++++++++++++++++
c/src/lib/libbsp/sparc/leon3/preinstall.am | 18 +++++++++++++++---
.../lib/libbsp/sparc/leon3/startup/linkcmds.gr712rc | 20 ++++++++++++++++++++
.../leon3/startup/{linkcmds.ngmp => linkcmds.gr740} | 0
c/src/lib/libbsp/sparc/leon3/startup/linkcmds.ut699 | 20 ++++++++++++++++++++
c/src/lib/libbsp/sparc/leon3/startup/linkcmds.ut700 | 20 ++++++++++++++++++++
10 files changed, 133 insertions(+), 4 deletions(-)
create mode 100644 c/src/lib/libbsp/sparc/leon3/make/custom/gr712rc.cfg
rename c/src/lib/libbsp/sparc/leon3/make/custom/{ngmp.cfg => gr740.cfg} (100%)
create mode 100644 c/src/lib/libbsp/sparc/leon3/make/custom/ut699.cfg
create mode 100644 c/src/lib/libbsp/sparc/leon3/make/custom/ut700.cfg
create mode 100644 c/src/lib/libbsp/sparc/leon3/startup/linkcmds.gr712rc
rename c/src/lib/libbsp/sparc/leon3/startup/{linkcmds.ngmp => linkcmds.gr740} (100%)
create mode 100644 c/src/lib/libbsp/sparc/leon3/startup/linkcmds.ut699
create mode 100644 c/src/lib/libbsp/sparc/leon3/startup/linkcmds.ut700
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index 52f6b56..cd591dd 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -26,7 +26,10 @@ project_lib_DATA = start.$(OBJEXT)
dist_project_lib_DATA += ../shared/startup/linkcmds.base
dist_project_lib_DATA += startup/linkcmds
dist_project_lib_DATA += startup/linkcmds.leon3
-dist_project_lib_DATA += startup/linkcmds.ngmp
+dist_project_lib_DATA += startup/linkcmds.ut699
+dist_project_lib_DATA += startup/linkcmds.gr712rc
+dist_project_lib_DATA += startup/linkcmds.ut700
+dist_project_lib_DATA += startup/linkcmds.gr740
noinst_LIBRARIES += libbsp.a
libbsp_a_SOURCES =
diff --git a/c/src/lib/libbsp/sparc/leon3/make/custom/gr712rc.cfg b/c/src/lib/libbsp/sparc/leon3/make/custom/gr712rc.cfg
new file mode 100644
index 0000000..0a20b2c
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/leon3/make/custom/gr712rc.cfg
@@ -0,0 +1,18 @@
+# Config file for the GR712RC LEON3 SPARC processor.
+include $(RTEMS_ROOT)/make/custom/default.cfg
+RTEMS_CPU=sparc
+RTEMS_CPU_MODEL=leon3
+# This contains the compiler options necessary to select the CPU model
+# and (hopefully) optimize for it.
+CPU_CFLAGS = -mcpu=leon3 -msoft-float -mfix-gr712rc
+# optimize flag: typically -O2
+CFLAGS_OPTIMIZE_V = -O2 -g
+CFLAGS_OPTIMIZE_V += -ffunction-sections -fdata-sections
+LDFLAGS = -Wl,--gc-sections
diff --git a/c/src/lib/libbsp/sparc/leon3/make/custom/ngmp.cfg b/c/src/lib/libbsp/sparc/leon3/make/custom/gr740.cfg
similarity index 100%
rename from c/src/lib/libbsp/sparc/leon3/make/custom/ngmp.cfg
rename to c/src/lib/libbsp/sparc/leon3/make/custom/gr740.cfg
diff --git a/c/src/lib/libbsp/sparc/leon3/make/custom/ut699.cfg b/c/src/lib/libbsp/sparc/leon3/make/custom/ut699.cfg
index 0000000..e1e4f84
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/leon3/make/custom/ut699.cfg
@@ -0,0 +1,18 @@
+# Config file for the UT699 LEON3 SPARC processor.
+RTEMS_CPU=sparc
+CPU_CFLAGS = -mcpu=leon -msoft-float -mfix-ut699
diff --git a/c/src/lib/libbsp/sparc/leon3/make/custom/ut700.cfg b/c/src/lib/libbsp/sparc/leon3/make/custom/ut700.cfg
index 0000000..3f0c016
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/leon3/make/custom/ut700.cfg
@@ -0,0 +1,18 @@
+# Config file for the UT699e/UT700 LEON3 SPARC processor.
+RTEMS_CPU=sparc
+CPU_CFLAGS = -mcpu=leon3 -msoft-float -mfix-ut700
diff --git a/c/src/lib/libbsp/sparc/leon3/preinstall.am b/c/src/lib/libbsp/sparc/leon3/preinstall.am
index 273a52d..70d58c8 100644
--- a/c/src/lib/libbsp/sparc/leon3/preinstall.am
+++ b/c/src/lib/libbsp/sparc/leon3/preinstall.am
@@ -81,9 +81,21 @@ $(PROJECT_LIB)/linkcmds.leon3: startup/linkcmds.leon3 $(PROJECT_LIB)/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.leon3
PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds.leon3
-$(PROJECT_LIB)/linkcmds.ngmp: startup/linkcmds.ngmp $(PROJECT_LIB)/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.ngmp
-PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds.ngmp
+$(PROJECT_LIB)/linkcmds.ut699: startup/linkcmds.ut699 $(PROJECT_LIB)/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.ut699
+PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds.ut699
+$(PROJECT_LIB)/linkcmds.gr712rc: startup/linkcmds.gr712rc $(PROJECT_LIB)/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.gr712rc
+PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds.gr712rc
+$(PROJECT_LIB)/linkcmds.ut700: startup/linkcmds.ut700 $(PROJECT_LIB)/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.ut700
+PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds.ut700
+$(PROJECT_LIB)/linkcmds.gr740: startup/linkcmds.gr740 $(PROJECT_LIB)/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.gr740
+PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds.gr740
$(PROJECT_INCLUDE)/bsp/gnatcommon.h: ../shared/include/gnatcommon.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/gnatcommon.h
diff --git a/c/src/lib/libbsp/sparc/leon3/startup/linkcmds.gr712rc b/c/src/lib/libbsp/sparc/leon3/startup/linkcmds.gr712rc
index 0000000..30f2b68
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/leon3/startup/linkcmds.gr712rc
@@ -0,0 +1,20 @@
+/* linkcmds
+/* Default values, can be overridden */
+_PROM_SIZE = DEFINED (_PROM_SIZE) ? _PROM_SIZE : 2M;
+_PROM_START = DEFINED (_PROM_START) ? _PROM_START : 0x00000000;
+_RAM_SIZE = DEFINED (_RAM_SIZE) ? _RAM_SIZE : 4M;
+_RAM_START = DEFINED (_RAM_START) ? _RAM_START : 0x40000000;
+/* these are the maximum values */
+MEMORY
+ rom : ORIGIN = 0x00000000, LENGTH = 256M
+ ram : ORIGIN = 0x40000000, LENGTH = 1024M
+INCLUDE linkcmds.base
diff --git a/c/src/lib/libbsp/sparc/leon3/startup/linkcmds.ngmp b/c/src/lib/libbsp/sparc/leon3/startup/linkcmds.gr740
rename from c/src/lib/libbsp/sparc/leon3/startup/linkcmds.ngmp
rename to c/src/lib/libbsp/sparc/leon3/startup/linkcmds.gr740
diff --git a/c/src/lib/libbsp/sparc/leon3/startup/linkcmds.ut699 b/c/src/lib/libbsp/sparc/leon3/startup/linkcmds.ut699
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/leon3/startup/linkcmds.ut699
@@ -0,0 +1,20 @@
+/* linkcmds
+MEMORY
diff --git a/c/src/lib/libbsp/sparc/leon3/startup/linkcmds.ut700 b/c/src/lib/libbsp/sparc/leon3/startup/linkcmds.ut700
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/leon3/startup/linkcmds.ut700
@@ -0,0 +1,20 @@
+/* linkcmds
+MEMORY
2.9.3
