[PATCH] sparc: Rename NGMP to GR740 and add configs for UT699, UT700, and GR712RC
Daniel Cederman cederman at gaisler.com
Fri Jul 14 12:00:35 UTC 2017
On 2017-07-14 12:01, Sebastian Huber wrote:
> Its not good that you patch RTEMS to get something useful for the users
> of RTEMS on your chips. Why can't you add this probing stuff to RTEMS
> mainline?
As I understood it we have tried to push this patch to mainline before,
but it was not accepted. We could make a new attempt after the vacation
period.
> We should probably
> 1. remove the -msoft-float,
> 2. enable SPARC_USE_SAFE_FP_SUPPORT for all configurations (see also
> test case spcontext01), and
> 3. add a deferred floating-point save for uniprocessor configurations.
Sounds like a good idea. I will revise my patch and remove -msoft-float.
Daniel Cederman
Software Engineer
Cobham Gaisler
