[PATCH-v2] sparc: Rename NGMP to GR740 and add configs for UT699, UT700, and GR712RC
Daniel Cederman cederman at gaisler.com
Fri Jul 14 12:12:07 UTC 2017
The UT699 requires -mcpu=leon as it does not support the CAS instruction
provided by -mcpu=leon3. It also requires -mfix-ut699 for errata fixes.
UT700 and GR712RC requires the -mfix-ut700 and -mfix-gr712rc flags that
have been recently added to GCC's master and 7-branch.
Remove -msoft-float from the leon3 config to make the more common case
of using the FPU the default.
 c/src/lib/libbsp/sparc/leon3/Makefile.am             |  5 ++++-
 c/src/lib/libbsp/sparc/leon3/make/custom/gr712rc.cfg | 18 ++++++++++++++++++
 .../sparc/leon3/make/custom/{ngmp.cfg => gr740.cfg}  |  0
 c/src/lib/libbsp/sparc/leon3/make/custom/leon3.cfg   |  2 +-
 c/src/lib/libbsp/sparc/leon3/make/custom/ut699.cfg   | 18 ++++++++++++++++++
 c/src/lib/libbsp/sparc/leon3/make/custom/ut700.cfg   | 18 ++++++++++++++++++
 c/src/lib/libbsp/sparc/leon3/preinstall.am           | 18 +++++++++++++++---
 .../lib/libbsp/sparc/leon3/startup/linkcmds.gr712rc  | 20 ++++++++++++++++++++
 .../leon3/startup/{linkcmds.ngmp => linkcmds.gr740}  |  0
 c/src/lib/libbsp/sparc/leon3/startup/linkcmds.ut699  | 20 ++++++++++++++++++++
 c/src/lib/libbsp/sparc/leon3/startup/linkcmds.ut700  | 20 ++++++++++++++++++++
 11 files changed, 134 insertions(+), 5 deletions(-)
 create mode 100644 c/src/lib/libbsp/sparc/leon3/make/custom/gr712rc.cfg
 rename c/src/lib/libbsp/sparc/leon3/make/custom/{ngmp.cfg => gr740.cfg} (100%)
 create mode 100644 c/src/lib/libbsp/sparc/leon3/make/custom/ut699.cfg
 create mode 100644 c/src/lib/libbsp/sparc/leon3/make/custom/ut700.cfg
 create mode 100644 c/src/lib/libbsp/sparc/leon3/startup/linkcmds.gr712rc
 rename c/src/lib/libbsp/sparc/leon3/startup/{linkcmds.ngmp => linkcmds.gr740} (100%)
 create mode 100644 c/src/lib/libbsp/sparc/leon3/startup/linkcmds.ut699
 create mode 100644 c/src/lib/libbsp/sparc/leon3/startup/linkcmds.ut700
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index 52f6b56..cd591dd 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -26,7 +26,10 @@ project_lib_DATA = start.$(OBJEXT)
 dist_project_lib_DATA += ../shared/startup/linkcmds.base
 dist_project_lib_DATA += startup/linkcmds
 dist_project_lib_DATA += startup/linkcmds.leon3
-dist_project_lib_DATA += startup/linkcmds.ngmp
+dist_project_lib_DATA += startup/linkcmds.ut699
+dist_project_lib_DATA += startup/linkcmds.gr712rc
+dist_project_lib_DATA += startup/linkcmds.ut700
+dist_project_lib_DATA += startup/linkcmds.gr740
 noinst_LIBRARIES += libbsp.a
 libbsp_a_SOURCES =
diff --git a/c/src/lib/libbsp/sparc/leon3/make/custom/gr712rc.cfg b/c/src/lib/libbsp/sparc/leon3/make/custom/gr712rc.cfg
new file mode 100644
index 0000000..40c6d12
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/leon3/make/custom/gr712rc.cfg
@@ -0,0 +1,18 @@
+#  Config file for the GR712RC LEON3 SPARC processor.
+include $(RTEMS_ROOT)/make/custom/default.cfg
+RTEMS_CPU=sparc
+RTEMS_CPU_MODEL=leon3
+#  This contains the compiler options necessary to select the CPU model
+#  and (hopefully) optimize for it.
+CPU_CFLAGS = -mcpu=leon3 -mfix-gr712rc
+# optimize flag: typically -O2
+CFLAGS_OPTIMIZE_V = -O2 -g
+CFLAGS_OPTIMIZE_V += -ffunction-sections -fdata-sections
+LDFLAGS = -Wl,--gc-sections
diff --git a/c/src/lib/libbsp/sparc/leon3/make/custom/ngmp.cfg b/c/src/lib/libbsp/sparc/leon3/make/custom/gr740.cfg
similarity index 100%
rename from c/src/lib/libbsp/sparc/leon3/make/custom/ngmp.cfg
rename to c/src/lib/libbsp/sparc/leon3/make/custom/gr740.cfg
diff --git a/c/src/lib/libbsp/sparc/leon3/make/custom/leon3.cfg b/c/src/lib/libbsp/sparc/leon3/make/custom/leon3.cfg
index 34ad967..ef9a868 100644
--- a/c/src/lib/libbsp/sparc/leon3/make/custom/leon3.cfg
+++ b/c/src/lib/libbsp/sparc/leon3/make/custom/leon3.cfg
@@ -9,7 +9,7 @@ RTEMS_CPU_MODEL=leon3
-CPU_CFLAGS = -mcpu=leon3 -msoft-float
diff --git a/c/src/lib/libbsp/sparc/leon3/make/custom/ut699.cfg b/c/src/lib/libbsp/sparc/leon3/make/custom/ut699.cfg
index 0000000..2150428
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/leon3/make/custom/ut699.cfg
@@ -0,0 +1,18 @@
+#  Config file for the UT699 LEON3 SPARC processor.
+RTEMS_CPU=sparc
+CPU_CFLAGS = -mcpu=leon -mfix-ut699
diff --git a/c/src/lib/libbsp/sparc/leon3/make/custom/ut700.cfg b/c/src/lib/libbsp/sparc/leon3/make/custom/ut700.cfg
index 0000000..9ee473e
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/leon3/make/custom/ut700.cfg
@@ -0,0 +1,18 @@
+#  Config file for the UT699e/UT700 LEON3 SPARC processor.
+RTEMS_CPU=sparc
+CPU_CFLAGS = -mcpu=leon3 -mfix-ut700
diff --git a/c/src/lib/libbsp/sparc/leon3/preinstall.am b/c/src/lib/libbsp/sparc/leon3/preinstall.am
index 273a52d..70d58c8 100644
--- a/c/src/lib/libbsp/sparc/leon3/preinstall.am
+++ b/c/src/lib/libbsp/sparc/leon3/preinstall.am
@@ -81,9 +81,21 @@ $(PROJECT_LIB)/linkcmds.leon3: startup/linkcmds.leon3 $(PROJECT_LIB)/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.leon3
 PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds.leon3
-$(PROJECT_LIB)/linkcmds.ngmp: startup/linkcmds.ngmp $(PROJECT_LIB)/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.ngmp
-PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds.ngmp
+$(PROJECT_LIB)/linkcmds.ut699: startup/linkcmds.ut699 $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.ut699
+PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds.ut699
+$(PROJECT_LIB)/linkcmds.gr712rc: startup/linkcmds.gr712rc $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.gr712rc
+PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds.gr712rc
+$(PROJECT_LIB)/linkcmds.ut700: startup/linkcmds.ut700 $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.ut700
+PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds.ut700
+$(PROJECT_LIB)/linkcmds.gr740: startup/linkcmds.gr740 $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.gr740
+PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds.gr740
 $(PROJECT_INCLUDE)/bsp/gnatcommon.h: ../shared/include/gnatcommon.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/gnatcommon.h
diff --git a/c/src/lib/libbsp/sparc/leon3/startup/linkcmds.gr712rc b/c/src/lib/libbsp/sparc/leon3/startup/linkcmds.gr712rc
index 0000000..30f2b68
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/leon3/startup/linkcmds.gr712rc
@@ -0,0 +1,20 @@
+/*  linkcmds
+/* Default values, can be overridden */
+_PROM_SIZE = DEFINED (_PROM_SIZE) ? _PROM_SIZE : 2M;
+_PROM_START = DEFINED (_PROM_START) ? _PROM_START : 0x00000000;
+_RAM_SIZE = DEFINED (_RAM_SIZE) ? _RAM_SIZE : 4M;
+_RAM_START = DEFINED (_RAM_START) ? _RAM_START : 0x40000000;
+/* these are the maximum values */
+MEMORY
+  rom     : ORIGIN = 0x00000000, LENGTH = 256M
+  ram     : ORIGIN = 0x40000000, LENGTH = 1024M
+INCLUDE linkcmds.base
diff --git a/c/src/lib/libbsp/sparc/leon3/startup/linkcmds.ngmp b/c/src/lib/libbsp/sparc/leon3/startup/linkcmds.gr740
rename from c/src/lib/libbsp/sparc/leon3/startup/linkcmds.ngmp
rename to c/src/lib/libbsp/sparc/leon3/startup/linkcmds.gr740
diff --git a/c/src/lib/libbsp/sparc/leon3/startup/linkcmds.ut699 b/c/src/lib/libbsp/sparc/leon3/startup/linkcmds.ut699
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/leon3/startup/linkcmds.ut699
@@ -0,0 +1,20 @@
+/*  linkcmds
+MEMORY
diff --git a/c/src/lib/libbsp/sparc/leon3/startup/linkcmds.ut700 b/c/src/lib/libbsp/sparc/leon3/startup/linkcmds.ut700
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/leon3/startup/linkcmds.ut700
@@ -0,0 +1,20 @@
+/*  linkcmds
+MEMORY
2.9.3
