HiFive1 BSP current state
Mon Jul 17 16:59:47 UTC 2017
See if you can produce a further stripped down version of hello world,
although I'm not sure there is much else that can be removed...
Maybe some more tweaking needs to be done to the CPU specific feature
macros in cpukit/score/cpu/riscv/rtems/score/cpu.h and similar?
What does riscv-rtems4.12-size report about your executable?
Gedare
On Mon, Jul 17, 2017 at 11:31 AM, Denis Obrezkov
<denisobrezkov at gmail.com> wrote:
> I have some bad and good news.
> First of all, I was able to receive a message from hello example:
> Fatal Error 0.2 Halted
> So, uart now works (transmitting), but hello application complains that
> there is not
> enough workspace.
> Low ticker example, doesn't work neither, and hangs during clock
> initialization
> routine.
> Regards, Denis Obrezkov
> devel mailing list
> devel at rtems.org
