LIBBSD
Wed Jul 19 12:41:49 UTC 2017
On 29/06/17 20:02, Kirspel, Kevin wrote:
> For those who run a RTEMS 4.12 single processor application with
> LIBBSD, what percentage of time does your application spend in the
> timer server task?  My NXP LPC3250 application spends about 13% of the
> processor time processing the timer server.  Most of that time is
> spent processing LIBBSD’s kernel callouts.  I am wondering if there is
> an advantage to only call the FreeBSD’s callout_process() function
> when we know a callout needs to be processed.  This would reduce the
> number of RTEMS timer fires (which currently fire every tick).
I observed a similar problem a 96MHz LPC4088. The main issue is that
callout_process() loads a lot of data (64-bit integers). So, on slow
memory target, you have a performance issue with 1000 ticks per second.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
