[PATCH-v2] sparc: Rename NGMP to GR740 and add configs for UT699, UT700, and GR712RC
Wed Jul 19 14:04:54 UTC 2017
Hello Jiri,
I fixed a couple of tests. One remaining failure on the leon2 is mathf:
*** BEGIN OF TEST MATHF ***
acosf          : 1.570796
acoshf         : -nan
asinf          : 1.570796
asinhf         : 0.881374
atanf          : 0.665774
atan2f         : 0.785398
atanhf         : inf
cbrtf          : 3.000000
ceilf          : 4.000000
copysignf      : -3.500000
cosf           : -0.000000
coshf          : 2.509179
erff           : 1.000000
erfcf          : 0.000000
expf           : 1.521962
exp2f          : 1.337928
expm1f         : 0.000420
fabsf          : 1.123000
fdimf          : 0.000000
floorf         : 0.000000
floorf         : -1.000000
Breakpoint 1, 0x40004044 in fmaf (x=x at entry=2.0999999, y=2.20000005,
z=3.00999999) at
/home/EB/sebastian_h/archive/gcc-git/newlib/libm/common/sf_fma.c:25
25        return (float) (((double) x * (double) y) + (double) z);
(gdb) disas 0x40004044
Dump of assembler code for function fmaf:
    0x40004024 <+0>:     add  %sp, -80, %sp
    0x40004028 <+4>:     st  %o1, [ %sp + 0x4c ]
    0x4000402c <+8>:     ld  [ %sp + 0x4c ], %f8
    0x40004030 <+12>:    st  %o0, [ %sp + 0x4c ]
    0x40004034 <+16>:    ld  [ %sp + 0x4c ], %f9
    0x40004038 <+20>:    st  %o2, [ %sp + 0x4c ]
    0x4000403c <+24>:    fsmuld  %f8, %f9, %f0
    0x40004040 <+28>:    ld  [ %sp + 0x4c ], %f8
=> 0x40004044 <+32>:    fstod  %f8, %f8
    0x40004048 <+36>:    add  %sp, 0x50, %sp
    0x4000404c <+40>:    faddd  %f0, %f8, %f0
    0x40004050 <+44>:    retl
    0x40004054 <+48>:    fdtos  %f0, %f0
End of assembler dump.
(gdb) p/x $fsr
$1 = 0xe660
Is fstod implemented on the SIS?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
