parallel make failure?
Kirspel, Kevin Kevin-Kirspel at idexx.com
Fri Jul 21 16:55:54 UTC 2017
I have seen similar things as well.  In my case it fails in different places randomly.  Sometimes it will get all the way through.
Kevin Kirspel
Electrical Engineer - Sr. Staff
Idexx Roswell
235 Hembree Park Drive
Roswell GA 30076
Tel: (770)-510-4444 ext. 81642
Direct: (770)-688-1642
Fax: (770)-510-4445
-----Original Message-----
From: devel [mailto:devel-bounces at rtems.org] On Behalf Of Gedare Bloom
Sent: Friday, July 21, 2017 11:24 AM
To: devel at rtems.org
Subject: parallel make failure?
I'm building a clean master with current tools and observed the following using make -j4:
/usr/bin/install -c -m 644
../../../../../../rtems/c/src/libchip/i2c/i2c-ds1621.h
../../../erc32/lib/include/libchip/i2c-ds1621.h
/usr/bin/install: cannot create regular file
'../../../erc32/lib/include/libchip/ds1375-rtc.h': File exists
Makefile:2147: recipe for target
'../../../erc32/lib/include/libchip/ds1375-rtc.h' failed
make[5]: *** [../../../erc32/lib/include/libchip/ds1375-rtc.h] Error 1
make[5]: Leaving directory
'/home/gedare/work/rtems/builds/b-erc32/sparc-rtems4.12/c/erc32/libchip'
Makefile:916: recipe for target 'preinstall-libchip' failed
make[4]: *** [preinstall-libchip] Error 1
With just 'make' it passes this step.
devel mailing list
devel at rtems.org
https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_devel&d=DwICAg&c=2do6VJGs3LvEOe4OFFM1bA&r=HDiJ93ANMEQ32G5JGdpyUxbdebuwKHBbeiHMr3RbR74&m=H9XvezTNiH4W-H2EFj7UpeWTK8A3pj_g9545ys--tXQ&s=NK5spqMDGykOoOeFKNlO88-8y9mrj6y9saEinGMqxkw&e=
