libbsd include path issue
Mon Jul 24 06:59:29 UTC 2017
On 24/07/2017 00:20, Christian Mauderer wrote:
> Am 23.07.2017 um 15:57 schrieb Gedare Bloom:
>> On Sun, Jul 23, 2017 at 8:38 AM, Christian Mauderer <list at c-mauderer.de> wrote:
>>> The problem here is that the opensslv.h is in the directory
>>> freebsd/crypto/openssl/crypto. It seems that some makefile magic would
>>> install it to openssl/opensslv.h for the normal non-libbsd case (most
>>> likely the "link" rule in freebsd/crypto/openssl/crypto/Makefile).
>> ah, I see. Then I can't think of any better solution than to make a
>> rule something like you did that will copy the header file into an
>> appropriate location of the build tree. The other alternative would be
>> to create a softlink include/openssl in the source tree, effectively
>> doing what the freebsd makefile would do during a build.
> I have shortly thought about that too. I think I've seen some functions
> in waf that might could create that softlink. But I had two problems
> with that:
> 1. Like I said, I have seen some functions that _might_ could create a
> link but I'm not sure what would be the best and correctest way. Any hints?
Could a waf 'subst' target be made to work?
https://github.com/waf-project/waf/tree/master/demos/subst
> 2. I have no idea how well that would work on a Windows build host. I
> know that at least msys2 doesn't support soft links out of the box. They
> are replaced by a copy. Any experience regarding that?
I would avoid a symlink.
Either of these solutions are not great but I also cannot see another way
without effecting the upstream.
