Can't enable a dummy clock driver
Denis Obrezkov denisobrezkov at gmail.com
Mon Jul 24 18:28:55 UTC 2017
2017-07-24 8:56 GMT+02:00 Denis Obrezkov <denisobrezkov at gmail.com>:
> 2017-07-24 8:27 GMT+02:00 Hesham Almatary <heshamelmatary at gmail.com>:
>> On Mon, Jul 24, 2017 at 8:27 AM, Joel Sherrill <joel at rtems.org> wrote:
>> > On Jul 23, 2017 5:15 PM, "Denis Obrezkov" <denisobrezkov at gmail.com>
>> wrote:
>> > 2017-07-23 22:30 GMT+02:00 Joel Sherrill <joel at rtems.org>:
>> >> Increasing the stack size effectively eliminated a data corruption
>> issue.
>> >> The memory corrupted likely was an RTEMS internal object structure.
>> >> What is the stack frame size required by each subroutine call?
>> > How can I determine it?
>> > If it isn't directly in the CPU's ABI definition, then what is pushed
>> to the
>> > stack or reserved on each subroutine call. You may see it in terms of
>> stack
>> > pointer, frame pointer, reserved space, etc.
>> > For example, the m68k had a minimum of 4 registers saved and the return
>> > address. More registers could be saved for complicated methods.
>> > I think some risc CPU has a number like 172 bytes reserved for possible
>> > register saves.
>> > So the scheme varies
>> >> How much stack to call printf()?
>> >> The minimum is an educated guess by the porter that is large enough to
>> run
>> >> many/most small applications. You should be able to call RTEMS
>> services and
>> >> do a context switch.
>> >> Hope that helps pick one. :)
>> > As for now, I have increased the minimum stack size and get the
>> following
>> > output:
>> > *** LOW MEMORY CLOCK TICK TEST ***
>> > TA1 - rtems_clock_get_tod - 09:00:00 12/31/1988
>> > TA2 - rtems_clock_get_tod - 09:00:00 12/31/1988
>> > TA3 - rtems_clock_get_tod - 09:00:00 12/31/1988
>> > I will try to determine how to proceed further.
>> Do you configure RISC-V to get timer (or any) interrupts? You might
>> want to disable all sources of interrupts, and make sure no interrupts
>> are generated at all, just to figure out if the problem is with
>> interrupt handling (including context save/restore).
>> > Regards, Denis Obrezkov
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
>> Hesham
> Interrupts are disabled.
Also, though I did almost everything like in v850sim and RISC-V generic
examples, my dummy clock driver
doesn't tick. It seems to me that clock_driver_sim_idle_body just never
runs.
Should I try to implement an interrupt driven clock?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170724/e4dbaee6/attachment.html>
