undefined reference to `xz_crc64'
Jiri Gaisler jiri at gaisler.se
Tue Jul 25 21:19:46 UTC 2017
My fault, the file cpukit/libmisc/xz/xz_config.h had somehow been
changed to enable XZ_USE_CRC64. A new checkout and regeneration of
makefiles with bootstrap solved the problem ...
Jiri.
On 07/25/2017 10:11 PM, Jiri Gaisler wrote:
> I updated RSB and RTEMS to git head. RSB built fine for sparc, but
> building the libtests/tar01 RTEMS test now fails with:
> mv -f .deps/initial_filesystem_tar_xz.Tpo .deps/initial_filesystem_tar_xz.Po
> sparc-rtems4.12-gcc -B../../../../../leon3/lib/ -specs bsp_specs -qrtems
> -mcpu=leon3 -O2 -g -ffunction-sections -fdata-sections -Wall
> -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes
> -Wnested-externs  -Wl,--gc-sections  -mcpu=leon3 -DHAVE_XZ=1  -o
> tar01.exe init.o test_cat.o initial_filesystem_tar.o
> initial_filesystem_tar_gz.o initial_filesystem_tar_xz.o -lrtemscpu -lz
> ../../../../../leon3/lib/librtemscpu.a(xz_dec_stream.o): In function
> `dec_block':
> /home/jiri/ibm/src/rtems/rtems.git/c/src/../../cpukit/libmisc/xz/xz_dec_stream.c:260:
> collect2: error: ld returned 1 exit status
> Makefile:699: recipe for target 'tar01.exe' failed
> gmake[6]: *** [tar01.exe] Error 1
> gmake[6]: Leaving directory
> '/home/jiri/src/rtems/b1/sparc-rtems4.12/c/leon3/testsuites/libtests/tar01'
> Makefile:637: recipe for target 'tar01' failed
> gmake[5]: *** [tar01] Error 2
> tar01 used to build without issues, any ideas ...?
> Jiri.
> devel mailing list
> devel at rtems.org
