How interrupts are handled in RTEMS
Wed Jul 26 13:19:48 UTC 2017
On 26/07/17 15:01, Denis Obrezkov wrote:
> Hello all,
> I have read RTEMS manuals but still can't fully  understand how interrupts
> are handled.
The manuals will be of no help here.
> For example, when an interrupt occurs pc is set to an IRQ handler address.
> So, the program's execution continued from that place.
> And my question is: how do set_vector and rtems_interrupt_catch relate
> to each other and to that IRQ function address installed in a processor
> during initialization?
The set_vector() and rtems_interrupt_catch() are legacy functions. They
should not be used for new ports. The set_vector() is not documented.
The rtems_interrupt_catch() lacks important features like an argument
pointer for the handler.
For RISC like machines the ARM
cpukit/score/cpu/arm/arm_exc_interrupt.S
and PowerPC
c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/ppc_exc_async_normal.S
sources are a good reference. The SPARC is too complicated due to its
register windows. The ARM is also a bit complicated due to the different
processor modes. I would start with a look at the PowerPC code.
In general you do the following:
Save volatile registers
Increment thread dispatch and ISR nest level
Switch to interrupt stack if necessary
Call high level handler (installed via rtems_interrupt_handler_install())
Decrement thread dispatch and ISR nest level
Do a thread dispatch if necessary and allowed
Restore volatile registers
Return from interrupt
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
