Optimization issue in RISC-V BSP
Fri Jul 28 11:11:23 UTC 2017
On Thu, Jul 27, 2017 at 7:43 PM, Denis Obrezkov <denisobrezkov at gmail.com> wrote:
> I didn't want to enable optimization because I was afraid of new mistakes.
> So, I enabled -Os and now I have:
> _Terminate (the_source=the_source at entry=INTERNAL_ERROR_CORE,
> the_error=the_error at entry=3)
>     at
> /home/reprofy/Projects/riscv/rtems/development/rtems/kernel/rtems-riscv/c/src/../../cpukit/score/src/interr.c:44
> 44        _CPU_Fatal_halt( the_source, the_error );
> (gdb) i s
> #0  _Terminate (the_source=the_source at entry=INTERNAL_ERROR_CORE,
>     at
> #1  0x20401672 in _Internal_error
> (core_error=core_error at entry=INTERNAL_ERROR_WORKSPACE_ALLOCATION)
>     at
> /home/reprofy/Projects/riscv/rtems/development/rtems/kernel/rtems-riscv/c/src/../../cpukit/score/src/interr.c:51
> #2  0x20404968 in _Workspace_Allocate_or_fatal_error (size=<optimized out>)
> at ../../cpukit/../../../hifive1/lib/include/rtems/score/heapimpl.h:137
> #3  0x20401f76 in _Objects_Extend_information (information=0x80000ad4
> <_RTEMS_tasks_Information>)
>     at
> /home/reprofy/Projects/riscv/rtems/development/rtems/kernel/rtems-riscv/c/src/../../cpukit/score/src/objectextendinformation.c:70
> #4  0x20402110 in _Objects_Do_initialize_information
> (information=information at entry=0x80000ad4 <_RTEMS_tasks_Information>,
> the_api=the_api at entry=OBJECTS_CLASSIC_API,
>     the_class=<optimized out>, maximum=maximum at entry=124, size=<optimized
> out>, is_string=<optimized out>,
> maximum_name_length=maximum_name_length at entry=4)
>     at
> /home/reprofy/Projects/riscv/rtems/development/rtems/kernel/rtems-riscv/c/src/../../cpukit/score/src/objectinitializeinformation.c:118
> #5  0x20402e3a in _Thread_Initialize_information
>     the_class=the_class at entry=1, maximum=124,
> is_string=is_string at entry=false,
>     at
> /home/reprofy/Projects/riscv/rtems/development/rtems/kernel/rtems-riscv/c/src/../../cpukit/score/src/thread.c:57
> #6  0x20400ff8 in _RTEMS_tasks_Manager_initialization () at
> /home/reprofy/Projects/riscv/rtems/development/rtems/kernel/rtems-riscv/c/src/../../cpukit/rtems/src/tasks.c:72
> #7  0x2040112e in rtems_initialize_executive () at
> /home/reprofy/Projects/riscv/rtems/development/rtems/kernel/rtems-riscv/c/src/../../cpukit/sapi/src/exinit.c:92
> #8  0x20400496 in boot_card (cmdline=<optimized out>) at
> /home/reprofy/Projects/riscv/rtems/development/rtems/kernel/rtems-riscv/c/src/lib/libbsp/riscv32/hifive1/../../shared/bootcard.c:78
> Though, the size of executable is much lower (almost two times),
> but I get this mistake. And as for now I can't understand do I have the
> error
> due to optimization or has the optimization revealed another issue?
Most likely it has revealed another issue. It appears that the
workspace is out of room and the allocate request fails. This could be
a problem in the application's configuration (CONFIGURE_XXX macros) or
is another side-effect of the memory constraints on your device. How
much workspace is there available in your linker script, can you tell?
Are you using unified heap and workspace?
> Regards, Denis Obrezkov
> devel mailing list
> devel at rtems.org
