Optimization issue in RISC-V BSP
Denis Obrezkov
denisobrezkov at gmail.com
Fri Jul 28 20:20:50 UTC 2017
2017-07-28 22:16 GMT+02:00 Joel Sherrill <joel at rtems.org>:
> On Fri, Jul 28, 2017 at 2:50 PM, Denis Obrezkov <denisobrezkov at gmail.com>
> wrote:
>>>> I can see that during task initialization I have a call:
>>>> _Thread_Initialize_information (information=information at entry=0x80000ad4
>>>> <_RTEMS_tasks_Information>, the_api=the_api at entry=OBJECTS_CLASSIC_API,
>>>> the_class=the_class at entry=1, maximum=124,
>>>> is_string=is_string at entry=false, maximum_name_length=maximum_na
>>>> me_length at entry=4)
>>>> And maximum is 124, but I have a configuration parameter:
>>>> #define CONFIGURE_MAXIMUM_TASKS 4
>>> I can't imagine any standard RTEMS test configuring that many tasks.
>>> Is there a data corruption issue?
>>> 124 = 0x7c which doesn't ring any bells for me on odd memory issues.
>>> What is the contents of "Configuration_RTEMS_API"?
>> Oh, I change my configuration options a bit, they are:
>> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>> #define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
>> #define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
>> #define CONFIGURE_TERMIOS_DISABLED
>> #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 0
>> #define CONFIGURE_MINIMUM_TASK_STACK_SIZE 512
>> #define CONFIGURE_MAXIMUM_PRIORITY 3
>> #define CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS
>> #define CONFIGURE_IDLE_TASK_BODY Init
>> #define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
>> #define CONFIGURE_TASKS 4
>> #define CONFIGURE_UNIFIED_WORK_AREAS
>> Also it is the test from a lower ticker example.
>> Configuration_RTEMS_API with -O0 option:
>> {maximum_tasks = 5, maximum_timers = 0, maximum_semaphores = 7,
>> maximum_message_queues = 0, maximum_partitions = 0, maximum_regions = 0,
>> maximum_ports = 0, maximum_periods = 0,
>> maximum_barriers = 0, number_of_initialization_tasks = 0,
>> User_initialization_tasks_table = 0x0}
>> with -Os option:
>> {maximum_tasks = 124, maximum_timers = 0, maximum_semaphores = 7,
> Hmmm.. If you look at this structure in gdb without attaching to the
> target, what
> is maximum_tasks?
> --joel
>>>> It seems that other tasks are LIBBLOCK tasks.
>>>> Also, this is my Configuration during run:
>>>> (gdb) p Configuration.stack_space_size
>>>> $1 = 2648
>>>> (gdb) p Configuration.work_space_size
>>>> $2 = 4216
>>>> (gdb) p Configuration.interrupt_stack_size
>>>> $3 = 512
>>>> (gdb) p Configuration.idle_task_stack_size
>>>> $4 = 512
>>> That looks reasonable. Add CONFIGURE_MAXIMUM_PRIORITY and set it to 4.
>>> That should
>>> reduce the workspace.
>>> long term, we might want to consider lowering it permanently like one
>>> of the Coldfires
>>> had to. Or change the default scheduler to the Simple one to save memory.
>> I haven't dealt with the Scheduler option yet.
>> Regards, Denis Obrezkov
> maximum_tasks = 4
So, is it a linker file issue?
This is it:
https://github.com/embeddedden/rtems-riscv/blob/hifive1/c/src/lib/libbsp/riscv32/hifive1/startup/linkcmds
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170728/dce214b3/attachment.html>
