Optimization issue in RISC-V BSP
Joel Sherrill
joel at rtems.org
Fri Jul 28 23:41:45 UTC 2017
On Jul 28, 2017 6:39 PM, "Denis Obrezkov" <denisobrezkov at gmail.com> wrote:
2017-07-29 1:28 GMT+02:00 Joel Sherrill <joel at rtems.org>:
> On Jul 28, 2017 6:14 PM, "Denis Obrezkov" <denisobrezkov at gmail.com> wrote:
> 2017-07-29 0:57 GMT+02:00 Joel Sherrill <joel at rtems.org>:
>> On Jul 28, 2017 5:55 PM, "Denis Obrezkov" <denisobrezkov at gmail.com>
>> wrote:
>> 2017-07-28 22:36 GMT+02:00 Joel Sherrill <joel at rtems.org>:
>>> Can you check the memory immediately after a download'?
>>> Then after the loop that copies initialized data into place?
>>> I suspect something off there. Could be a linker script issue or the
>>> copy gone crazy.
>>> --joel
>>> On Fri, Jul 28, 2017 at 3:20 PM, Denis Obrezkov <denisobrezkov at gmail.com
>>> > wrote:
>>>> 2017-07-28 22:16 GMT+02:00 Joel Sherrill <joel at rtems.org>:
>>>>> On Fri, Jul 28, 2017 at 2:50 PM, Denis Obrezkov <
>>>>>>>> I can see that during task initialization I have a call:
>>>>>>>> _Thread_Initialize_information (information=information at entry=0x80000ad4
>>>>>>>> <_RTEMS_tasks_Information>, the_api=the_api at entry=OBJECTS_CLASSIC_API,
>>>>>>>> the_class=the_class at entry=1, maximum=124,
>>>>>>>> is_string=is_string at entry=false, maximum_name_length=maximum_na
>>>>>>>> me_length at entry=4)
>>>>>>>> And maximum is 124, but I have a configuration parameter:
>>>>>>>> #define CONFIGURE_MAXIMUM_TASKS 4
>>>>>>> I can't imagine any standard RTEMS test configuring that many tasks.
>>>>>>> Is there a data corruption issue?
>>>>>>> 124 = 0x7c which doesn't ring any bells for me on odd memory issues.
>>>>>>> What is the contents of "Configuration_RTEMS_API"?
>>>>>> Oh, I change my configuration options a bit, they are:
>>>>>> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>>>>>> #define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
>>>>>> #define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
>>>>>> #define CONFIGURE_TERMIOS_DISABLED
>>>>>> #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 0
>>>>>> #define CONFIGURE_MINIMUM_TASK_STACK_SIZE 512
>>>>>> #define CONFIGURE_MAXIMUM_PRIORITY 3
>>>>>> #define CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS
>>>>>> #define CONFIGURE_IDLE_TASK_BODY Init
>>>>>> #define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
>>>>>> #define CONFIGURE_TASKS 4
>>>>>> #define CONFIGURE_UNIFIED_WORK_AREAS
>>>>>> Also it is the test from a lower ticker example.
>>>>>> Configuration_RTEMS_API with -O0 option:
>>>>>> {maximum_tasks = 5, maximum_timers = 0, maximum_semaphores = 7,
>>>>>> maximum_message_queues = 0, maximum_partitions = 0, maximum_regions = 0,
>>>>>> maximum_ports = 0, maximum_periods = 0,
>>>>>> maximum_barriers = 0, number_of_initialization_tasks = 0,
>>>>>> User_initialization_tasks_table = 0x0}
>>>>>> with -Os option:
>>>>>> {maximum_tasks = 124, maximum_timers = 0, maximum_semaphores = 7,
>>>>> Hmmm.. If you look at this structure in gdb without attaching to the
>>>>> target, what
>>>>> is maximum_tasks?
>>>>> --joel
>>>>>>>> It seems that other tasks are LIBBLOCK tasks.
>>>>>>>> Also, this is my Configuration during run:
>>>>>>>> (gdb) p Configuration.stack_space_size
>>>>>>>> $1 = 2648
>>>>>>>> (gdb) p Configuration.work_space_size
>>>>>>>> $2 = 4216
>>>>>>>> (gdb) p Configuration.interrupt_stack_size
>>>>>>>> $3 = 512
>>>>>>>> (gdb) p Configuration.idle_task_stack_size
>>>>>>>> $4 = 512
>>>>>>> That looks reasonable. Add CONFIGURE_MAXIMUM_PRIORITY and set it to
>>>>>>> 4. That should
>>>>>>> reduce the workspace.
>>>>>>> long term, we might want to consider lowering it permanently like
>>>>>>> one of the Coldfires
>>>>>>> had to. Or change the default scheduler to the Simple one to save
>>>>>>> memory.
>>>>>> I haven't dealt with the Scheduler option yet.
>>>>>> Regards, Denis Obrezkov
>>>>> maximum_tasks = 4
>>>> So, is it a linker file issue?
>>>> This is it:
>>>> https://github.com/embeddedden/rtems-riscv/blob/hifive1/c/sr
>>>> c/lib/libbsp/riscv32/hifive1/startup/linkcmds
>>> After download:
>> {maximum_tasks = 938162044, maximum_timers = 1270834941,
>> maximum_semaphores = 2534801264 <(253)%20480-1264>,
>> maximum_message_queues = 425684620, maximum_partitions = 1496738036,
>> maximum_regions = 3085560870 <(308)%20556-0870>, maximum_ports =
>> 4269782132, maximum_periods = 2362012542 <(236)%20201-2542>,
>> maximum_barriers = 1138223297, number_of_initialization_tasks = 4224313421,
>> User_initialization_tasks_table = 0x43bd1bd3}
>> right after data copying:
>> {maximum_tasks = 124, maximum_timers = 0, maximum_semaphores = 1,
>> But I found the mistake - I made it in .data initialization code
>> (https://github.com/embeddedden/rtems-riscv/blob/hifive1/c/s
>> rc/lib/libbsp/riscv32/hifive1/start/start.S#L116 - first byte in the
>> loop was uninitialized)
>> Awesome! Does that mean it is running?
>> Yes, it is running now. Not far, but running.
> Now I am having an exception during atexit( Clock_exit )
> Does it get to bsp_cleanup and bsp_reset? Are you seeing the Terminate?
> I think those are the names. Basically some BSPs deliberately throw an
> exception as the way to end.
> Unfortunately, I have an exception in the beginning during clock driver
initialization around this line:
0x204053a0 80 in ../../../../../gcc-7.1.0/
newlib/libc/stdlib/__atexit.c
No obvious suggestions from me right now except to debug.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170728/df056a76/attachment-0001.html>
