Optimization issue in RISC-V BSP
Denis Obrezkov
denisobrezkov at gmail.com
Sun Jul 30 01:02:39 UTC 2017
2017-07-30 2:34 GMT+02:00 Joel Sherrill <joel at rtems.org>:
> Sorry to top post but this thread is very deep to answer on a phone.
> Try looking at the same code on the erc32 bsp and see how it is done.
> Also you could disable the atexit() call and see how.much further you get.
> Ok, I will look at erc32 bsp.
I have removed atexit call, now I can proceed further, till the while(1)
loop in the low ticker test.
But the Dummy Clock doesn't tick.
So, I again get the output:
*** LOW MEMORY CLOCK TICK TEST ***
TA1 - rtems_clock_get_tod - 09:00:00 12/31/1988
TA2 - rtems_clock_get_tod - 09:00:00 12/31/1988
TA3 - rtems_clock_get_tod - 09:00:00 12/31/1988
Regards, Denis Obrezkov
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170730/ff3b12b6/attachment.html>
