Optimization issue in RISC-V BSP
    Hesham Almatary
    heshamelmatary at gmail.com
    Sun Jul 30 23:08:22 UTC 2017
On Mon, Jul 31, 2017 at 5:03 AM, Denis Obrezkov <denisobrezkov at gmail.com> wrote:
> 2017-07-30 20:40 GMT+02:00 Joel Sherrill <joel at rtems.org>:
>> On Jul 30, 2017 12:19 PM, "Denis Obrezkov" <denisobrezkov at gmail.com>
>> wrote:
>> 2017-07-30 3:10 GMT+02:00 Joel Sherrill <joel at rtems.org>:
>>> On Jul 29, 2017 8:02 PM, "Denis Obrezkov" <denisobrezkov at gmail.com>
>>> wrote:
>>> 2017-07-30 2:34 GMT+02:00 Joel Sherrill <joel at rtems.org>:
>>>> Sorry to top post but this thread is very deep to answer on a phone.
>>>> Try looking at the same code on the erc32 bsp and see how it is done.
>>>> Also you could disable the atexit() call and see how.much further you
>>>> get.
>>> Ok, I will look at erc32 bsp.
>>> I have removed atexit call, now I can proceed further, till the while(1)
>>> loop in the low ticker test.
>>> But the Dummy Clock doesn't tick.
>>> So, I again get the output:
>>> *** LOW MEMORY CLOCK TICK TEST ***
>>> TA1  - rtems_clock_get_tod - 09:00:00   12/31/1988
>>> TA2  - rtems_clock_get_tod - 09:00:00   12/31/1988
>>> TA3  - rtems_clock_get_tod - 09:00:00   12/31/1988
>>> Low ticker has its Init task become the idle task. Your clock driver
>>> simulator thread is likely never running.
>>> Try turning that option off in the test
>>> Regards, Denis Obrezkov
>> I tried it, but I had an error
>> ../../../../../hifive1/lib/include/rtems/confdefs.h:3586:2: error: #error
>> "CONFIGURATION ERROR: No initialization tasks or threads configured!!"
>>  #error "CONFIGURATION ERROR: No initialization tasks or threads
>> configured!!"
>> You have to configure an Init task.
> Yes, I understand that, but I can't find proper configuration options.
#define CONFIGURE_INIT
There might be other #ifdefs needed as well like:
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
Have a look at the existing hello and ticker examples (not low ticker).
> devel mailing list
> devel at rtems.org
Hesham
