[PATCH 2/6] jetson-tk1: Add start.S
andreas.koelbl at st.oth-regensburg.de andreas.koelbl at st.oth-regensburg.de
Mon Jul 31 22:27:19 UTC 2017
From: Andreas Kölbl <andreas.koelbl at st.oth-regensburg.de>
This own implementation allows for modifications like passing a cmdline
parameter.
 c/src/lib/libbsp/arm/jetson-tk1/Makefile.am   |   3 +-
 c/src/lib/libbsp/arm/jetson-tk1/configure.ac  |   3 +
 c/src/lib/libbsp/arm/jetson-tk1/start/start.S | 456 ++++++++++++++++++++++++++
 3 files changed, 461 insertions(+), 1 deletion(-)
 create mode 100644 c/src/lib/libbsp/arm/jetson-tk1/start/start.S
diff --git a/c/src/lib/libbsp/arm/jetson-tk1/Makefile.am b/c/src/lib/libbsp/arm/jetson-tk1/Makefile.am
index 4316e67957..9fc1695cba 100644
--- a/c/src/lib/libbsp/arm/jetson-tk1/Makefile.am
+++ b/c/src/lib/libbsp/arm/jetson-tk1/Makefile.am
@@ -50,7 +50,7 @@ include_bsp_HEADERS += include/mmu.h
 noinst_LIBRARIES = libbspstart.a
-libbspstart_a_SOURCES = ../shared/start/start.S
+libbspstart_a_SOURCES = start/start.S
 project_lib_DATA = start.$(OBJEXT)
@@ -79,6 +79,7 @@ libbsp_a_SOURCES += ../../shared/sbrk.c
 libbsp_a_SOURCES += ../../shared/src/stackalloc.c
 libbsp_a_SOURCES += ../shared/startup/bsp-start-memcpy.S
 libbsp_a_SOURCES += ../shared/arm-cp15-set-ttb-entries.c
+libbsp_a_SOURCES += ../shared/startup/bsp-start-in-hyp-support.S
 # Cache
 libbsp_a_SOURCES += ../../../libcpu/shared/src/cache_manager.c
diff --git a/c/src/lib/libbsp/arm/jetson-tk1/configure.ac b/c/src/lib/libbsp/arm/jetson-tk1/configure.ac
index 7d4dce3008..111118e9ed 100644
--- a/c/src/lib/libbsp/arm/jetson-tk1/configure.ac
+++ b/c/src/lib/libbsp/arm/jetson-tk1/configure.ac
@@ -21,6 +21,9 @@ use])
 RTEMS_BSPOPTS_SET([TEGRA_BASE],[*],[0x80000000])
 RTEMS_BSPOPTS_HELP([TEGRA_BASE],[Base load address])
+RTEMS_BSPOPTS_SET([BSP_START_IN_HYP_SUPPORT],[*],[1])
+RTEMS_BSPOPTS_HELP([BSP_START_IN_HYP_SUPPORT], [Support start of BSP in ARM HYP mode])
 AC_DEFUN([TEGRA_LINKCMD],[
 AC_ARG_VAR([$1],[$2; default $3])dnl
 [$1]=[$]{[$1]:-[$3]}
diff --git a/c/src/lib/libbsp/arm/jetson-tk1/start/start.S b/c/src/lib/libbsp/arm/jetson-tk1/start/start.S
new file mode 100644
index 0000000000..bb984189ba
--- /dev/null
+++ b/c/src/lib/libbsp/arm/jetson-tk1/start/start.S
@@ -0,0 +1,456 @@
+ * @file
+ * @brief Boot and system start code.
+ * Copyright (c) 2008, 2016 embedded brains GmbH.  All rights reserved.
+ * Authors:
+ *   Andreas Kölbl
+ *   OTH Regensburg
+ *   Seybothstraße 2
+ *   93053 Regensburg
+ *   embedded brains GmbH
+ *   Dornierstr. 4
+ *   82178 Puchheim
+ *   Germany
+ *   <rtems at embedded-brains.de>
+#include <rtems/asm.h>
+#include <rtems/system.h>
+#include <rtems/score/percpu.h>
+#include <bspopts.h>
+#include <bsp/irq.h>
+#include <bsp/linker-symbols.h>
+	/* External symbols */
+	.extern	bsp_reset
+	.extern	boot_card
+	.extern	bsp_start_hook_0
+	.extern	bsp_start_hook_1
+	.extern bsp_stack_irq_end
+	.extern bsp_stack_fiq_end
+	.extern bsp_stack_abt_end
+	.extern bsp_stack_und_end
+	.extern bsp_stack_svc_end
+#ifdef RTEMS_SMP
+	.extern bsp_stack_all_size
+#endif
+	.extern	_ARMV4_Exception_undef_default
+	.extern	_ARMV4_Exception_swi_default
+	.extern	_ARMV4_Exception_data_abort_default
+	.extern	_ARMV4_Exception_pref_abort_default
+	.extern	_ARMV4_Exception_reserved_default
+	.extern	_ARMV4_Exception_interrupt
+	.extern	_ARMV4_Exception_fiq_default
+	.extern	_ARMV7M_Exception_default
+#ifdef BSP_START_NEEDS_REGISTER_INITIALIZATION
+	.extern bsp_start_init_registers_core
+	.extern bsp_start_init_registers_banked_fiq
+	.extern bsp_start_init_registers_vfp
+#endif
+#ifdef BSP_START_IN_HYP_SUPPORT
+	.extern	bsp_start_arm_drop_hyp_mode
+	.globl	bsp_start_hyp_vector_table_begin
+#endif
+	/* Global symbols */
+	.globl	_start
+	.globl	bsp_start_vector_table_begin
+	.globl	bsp_start_vector_table_end
+	.globl	bsp_start_vector_table_size
+	.globl	bsp_vector_table_size
+	.globl	bsp_start_hook_0_done
+	.section	".bsp_start_text", "ax"
+#if defined(ARM_MULTILIB_ARCH_V4)
+	.arm
+ * This is the exception vector table and the pointers to the default
+ * exceptions handlers.
+bsp_start_vector_table_begin:
+	ldr	pc, handler_addr_reset
+	ldr	pc, handler_addr_undef
+	ldr	pc, handler_addr_swi
+	ldr	pc, handler_addr_prefetch
+	ldr	pc, handler_addr_abort
+	/* Program signature checked by boot loader */
+	.word	0xb8a06f58
+	ldr	pc, handler_addr_irq
+	ldr	pc, handler_addr_fiq
+handler_addr_reset:
+#ifdef BSP_START_RESET_VECTOR
+	.word	BSP_START_RESET_VECTOR
+#else
+	.word	_start
+#endif
+handler_addr_undef:
+	.word	_ARMV4_Exception_undef_default
+handler_addr_swi:
+	.word	_ARMV4_Exception_swi_default
+handler_addr_prefetch:
+	.word	_ARMV4_Exception_pref_abort_default
+handler_addr_abort:
+	.word	_ARMV4_Exception_data_abort_default
+handler_addr_reserved:
+	.word	_ARMV4_Exception_reserved_default
+handler_addr_irq:
+	.word	_ARMV4_Exception_interrupt
+handler_addr_fiq:
+	.word	_ARMV4_Exception_fiq_default
+bsp_start_vector_table_end:
+bsp_start_hyp_vector_table_begin:
+	ldr	pc, handler_addr_hyp_reset
+	ldr	pc, handler_addr_hyp_undef
+	ldr	pc, handler_addr_hyp_swi
+	ldr	pc, handler_addr_hyp_prefetch
+	ldr	pc, handler_addr_hyp_abort
+	ldr	pc, handler_addr_hyp_hyp
+	ldr	pc, handler_addr_hyp_irq
+	ldr	pc, handler_addr_hyp_fiq
+handler_addr_hyp_reset:
+handler_addr_hyp_undef:
+handler_addr_hyp_swi:
+handler_addr_hyp_prefetch:
+handler_addr_hyp_abort:
+handler_addr_hyp_hyp:
+handler_addr_hyp_irq:
+handler_addr_hyp_fiq:
+bsp_start_hyp_vector_table_end:
+#endif
+/* Start entry */
+_start:
+	 * We do not save the context since we do not return to the boot
+	 * loader but preserve r1 and r2 to allow access to bootloader parameters
+#ifndef BSP_START_NEEDS_REGISTER_INITIALIZATION
+	mov	r5, r1		/* machine type number or ~0 for DT boot */
+	mov	r6, r2		/* physical address of ATAGs or DTB */
+#else /* BSP_START_NEEDS_REGISTER_INITIALIZATION */
+	bl bsp_start_init_registers_core
+#endif
+#ifdef RTEMS_SMP
+	/* Read MPIDR and get current processor index */
+	mrc	p15, 0, r0, c0, c0, 5
+	and	r0, #0xff
+         * Get current per-CPU control and store it in PL1 only Thread ID
+         * Register (TPIDRPRW).
+	ldr	r1, =_Per_CPU_Information
+	add	r1, r1, r0, asl #PER_CPU_CONTROL_SIZE_LOG2
+	mcr	p15, 0, r1, c13, c0, 4
+	/* Calculate stack offset */
+	ldr	r1, =bsp_stack_all_size
+	mul	r1, r0
+#endif
+	mrs	r4, cpsr	/* save original procesor status value  */
+	orr	r0, r4, #(ARM_PSR_I | ARM_PSR_F)
+	msr	cpsr, r4
+	and	r0, r4, #ARM_PSR_M_MASK
+	cmp	r0, #ARM_PSR_M_HYP
+	bne	bsp_start_skip_hyp_svc_switch
+	/* Boot loader stats kernel in HYP mode, switch to SVC necessary */
+	ldr	sp, =bsp_stack_hyp_end
+#ifdef RTEMS_SMP
+	add	sp, r1
+#endif
+	bl	bsp_start_arm_drop_hyp_mode
+bsp_start_skip_hyp_svc_switch:
+#endif
+	 * Set SVC mode, disable interrupts and enable ARM instructions.
+	mov	r0, #(ARM_PSR_M_SVC | ARM_PSR_I | ARM_PSR_F)
+	msr	cpsr, r0
+	/* Initialize stack pointer registers for the various modes */
+	/* Enter IRQ mode and set up the IRQ stack pointer */
+	mov	r0, #(ARM_PSR_M_IRQ | ARM_PSR_I | ARM_PSR_F)
+	msr	cpsr, r0
+	ldr	sp, =bsp_stack_irq_end
+#ifdef RTEMS_SMP
+	add	sp, r1
+#endif
+	/* Enter FIQ mode and set up the FIQ stack pointer */
+	mov	r0, #(ARM_PSR_M_FIQ | ARM_PSR_I | ARM_PSR_F)
+	msr	cpsr, r0
+	ldr	sp, =bsp_stack_fiq_end
+#ifdef RTEMS_SMP
+	add	sp, r1
+#endif
+	bl bsp_start_init_registers_banked_fiq
+#endif
+	/* Enter ABT mode and set up the ABT stack pointer */
+	mov	r0, #(ARM_PSR_M_ABT | ARM_PSR_I | ARM_PSR_F)
+	msr	cpsr, r0
+	ldr	sp, =bsp_stack_abt_end
+#ifdef RTEMS_SMP
+	add	sp, r1
+#endif
+	/* Enter UND mode and set up the UND stack pointer */
+	mov	r0, #(ARM_PSR_M_UND | ARM_PSR_I | ARM_PSR_F)
+	msr	cpsr, r0
+	ldr	sp, =bsp_stack_und_end
+#ifdef RTEMS_SMP
+	add	sp, r1
+#endif
+	/* Enter SVC mode and set up the SVC stack pointer */
+	msr	cpsr, r0
+	ldr	sp, =bsp_stack_svc_end
+#ifdef RTEMS_SMP
+	add	sp, r1
+#endif
+	/* Stay in SVC mode */
+#ifdef ARM_MULTILIB_VFP
+#ifdef ARM_MULTILIB_HAS_CPACR
+	/* Read CPACR */
+	mrc p15, 0, r0, c1, c0, 2
+	/* Enable CP10 and CP11 */
+	orr r0, r0, #(1 << 20)
+	orr r0, r0, #(1 << 22)
+	 * Clear ASEDIS and D32DIS.  Writes to D32DIS are ignored for VFP-D16.
+	bic r0, r0, #(3 << 30)
+	/* Write CPACR */
+	mcr p15, 0, r0, c1, c0, 2
+	isb
+#endif
+	/* Enable FPU */
+	mov r0, #(1 << 30)
+	vmsr FPEXC, r0
+	bl bsp_start_init_registers_vfp
+#endif
+#endif /* ARM_MULTILIB_VFP */
+	 * Branch to start hook 0.
+	 * The previous code and parts of the start hook 0 may run with an
+	 * address offset.  This implies that only branches relative to the
+	 * program counter are allowed.  After the start hook 0 it is assumed
+	 * that the code can run at its intended position.  Thus the link
+	 * register will be loaded with the absolute address.  In THUMB mode
+	 * the start hook 0 must be within a 2kByte range due to the branch
+	 * instruction limitation.
+	ldr	lr, =bsp_start_hook_0_done
+#ifdef __thumb__
+	orr	lr, #1
+#endif
+	SWITCH_FROM_ARM_TO_THUMB	r0
+	mov	r0, r4		/* original cpsr value */
+	mov	r1, r5		/* machine type number or ~0 for DT boot */
+	mov	r2, r6		/* physical address of ATAGs or DTB */
+	b	bsp_start_hook_0
+bsp_start_hook_0_done:
+	SWITCH_FROM_THUMB_TO_ARM
+	 * Initialize the exception vectors.  This includes the exceptions
+	 * vectors and the pointers to the default exception handlers.
+	stmdb	sp!, {r4, r5, r6}
+	ldr	r0, =bsp_vector_table_begin
+	adr	r1, bsp_start_vector_table_begin
+	cmp	r0, r1
+	beq	bsp_vector_table_copy_done
+	ldmia	r1!, {r2-r9}
+	stmia	r0!, {r2-r9}
+bsp_vector_table_copy_done:
+	ldmia	sp!, {r0, r1, r2}
+	SWITCH_FROM_ARM_TO_THUMB	r3
+	/* Branch to start hook 1 */
+	bl	bsp_start_hook_1
+	/* Branch to boot card */
+	mov	r0, #0
+	bl	boot_card
+twiddle:
+	/* Branch to reset function */
+	bl	bsp_reset
+	b	twiddle
+#elif defined(ARM_MULTILIB_ARCH_V7M)
+#include <rtems/score/armv7m.h>
+	.syntax	unified
+	.extern	bsp_stack_main_end
+	.thumb
+	.word	bsp_stack_main_end
+	.word	_start /* Reset */
+	.word	_ARMV7M_Exception_default /* NMI */
+	.word	_ARMV7M_Exception_default /* Hard Fault */
+	.word	_ARMV7M_Exception_default /* MPU Fault */
+	.word	_ARMV7M_Exception_default /* Bus Fault */
+	.word	_ARMV7M_Exception_default /* Usage Fault */
+	.word	_ARMV7M_Exception_default /* Reserved */
+	.word	_ARMV7M_Exception_default /* SVC */
+	.word	_ARMV7M_Exception_default /* Debug Monitor */
+	.word	_ARMV7M_Exception_default /* PendSV */
+	.word	_ARMV7M_Exception_default /* SysTick */
+	.rept	BSP_INTERRUPT_VECTOR_MAX + 1
+	.word	_ARMV7M_Exception_default /* IRQ */
+	.endr
+	.thumb_func
+_start:
+#endif
+	 * Enable CP10 and CP11 coprocessors for privileged and user mode in
+	 * CPACR (bits 20-23).  Ensure that write to register completes.
+	ldr	r0, =ARMV7M_CPACR
+	ldr	r1, [r0]
+	orr	r1, r1, #(0xf << 20)
+	str	r1, [r0]
+	dsb
+	isb
+#endif
+#endif
+	ldr	sp, =bsp_stack_main_end
+	ldr	lr, =bsp_start_hook_0_done + 1
+	movs	r0, #0
+	bl	boot_card
+twiddle:
+	bl	bsp_reset
+	b	twiddle
+#endif /* defined(ARM_MULTILIB_ARCH_V7M) */
+	.set	bsp_start_vector_table_size, bsp_start_vector_table_end - bsp_start_vector_table_begin
+	.set	bsp_vector_table_size, bsp_start_vector_table_size
2.13.3
