LIBBSD TCPDUMP
Kirspel, Kevin
Kevin-Kirspel at idexx.com
Sat Jul 1 21:34:09 UTC 2017
No. I fixed that after I noticed the data was invalid during testing. I moved the variable declaration outside of the if statement and now the data is correct.
Kevin Kirspel
Electrical Engineer - Sr. Staff
Idexx Roswell
235 Hembree Park Drive
Roswell GA 30076
Tel: (770)-510-4444 ext. 81642
Direct: (770)-688-1642
Fax: (770)-510-4445
-----Original Message-----
From: gedare at gwmail.gwu.edu [mailto:gedare at gwmail.gwu.edu] On Behalf Of Gedare Bloom
Sent: Saturday, July 01, 2017 1:30 PM
To: Kirspel, Kevin <Kevin-Kirspel at idexx.com>
Cc: joel at rtems.org; rtems-devel at rtems.org <devel at rtems.org>
Subject: Re: LIBBSD TCPDUMP
On Sat, Jul 1, 2017 at 11:49 AM, Kirspel, Kevin <Kevin-Kirspel at idexx.com> wrote:
> This is how I fixed it. I did similar things for EXTRACT_32BITS and
> EXTRACT_64BITS.
> static inline u_int16_t
> EXTRACT_16BITS(const void *p)
> #if defined(__arm__) && defined(__rtems__)
> if(((uint32_t)p % 2) != 0) {
> u_int16_t value;
> u_int8_t *ptr = (u_int8_t *)&value;
> ptr[0] = ((const u_int8_t *)p)[0];
> ptr[1] = ((const u_int8_t *)p)[1];
> p = &value;
Is it correct to assign a pointer to a block-scoped variable here? It looks suspect to me. I'd at least put the declaration of 'value'
before the block here.
> #endif /* __rtems__ */
> return ((u_int16_t)ntohs(*(const u_int16_t *)(p)));
> Kevin Kirspel
> Idexx Roswell
> Roswell GA 30076
> Fax: (770)-510-4445
> From: Joel Sherrill [mailto:joel at rtems.org]
> Sent: Saturday, July 01, 2017 11:39 AM
> To: Gedare Bloom <gedare at rtems.org>
> Cc: rtems-devel at rtems.org <devel at rtems.org>; Kirspel, Kevin
> On Jul 1, 2017 10:34 AM, "Gedare Bloom" <gedare at rtems.org> wrote:
> On Sat, Jul 1, 2017 at 10:01 AM, Kirspel, Kevin
> wrote:
>> I get a crash when running the tcpdump command in LIBBSD. It is due
>> to the following structure
>> struct stp_bpdu_ {
>> u_int8_t protocol_id[2];
>> u_int8_t protocol_version;
>> u_int8_t bpdu_type;
>> u_int8_t flags;
>> u_int8_t root_id[8];
>> u_int8_t root_path_cost[4];
>> u_int8_t bridge_id[8];
>> u_int8_t port_id[2];
>> u_int8_t message_age[2];
>> u_int8_t max_age[2];
>> u_int8_t hello_time[2];
>> u_int8_t forward_delay[2];
>> u_int8_t v1_length;
>> In the code, there is an access to the port_id field as follows:
>> EXTRACT_16BITS(&stp_bpdu->port_id). EXTRACT_16BITS calls ntohs() .
>> Since the address of “&stp_bpdu->port_id” is at an odd word (16 bit)
>> boundary, an exception is generated. What is the correct way to fix
>> this? I was going to update EXTRACT_16BITS to check for an odd
>> boundary and fix it up before calling ntohs().
> That would probably be a more portable fix than allowing unaligned
> accesses. I think the alignment should be made to the CPU_ALIGNMENT
> macro.
> Can't you also just pull it out a byte at a time, form the net version
> and then ntohs()?
> That's what I coded recently in some marahalling code.
>> Kevin Kirspel
>> Idexx Roswell
>> Roswell GA 30076
>> Fax: (770)-510-4445
>> devel mailing list
>> devel at rtems.org
>> https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_m
>> ailman_listinfo_devel&d=DwIFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=HDiJ93ANMEQ
>> 32G5JGdpyUxbdebuwKHBbeiHMr3RbR74&m=ZD1dtkTMUak_NH2kvhh9fcWsBvl09av5rA
>> xPKDDt1ac&s=QxnRQLVQGW81f8ARsKfj1Hd7M4JNXV0oc_WjhT5dOHw&e=
> devel mailing list
> devel at rtems.org
> https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_ma
> ilman_listinfo_devel&d=DwIFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=HDiJ93ANMEQ32
> G5JGdpyUxbdebuwKHBbeiHMr3RbR74&m=ZD1dtkTMUak_NH2kvhh9fcWsBvl09av5rAxPKDDt1ac&s=QxnRQLVQGW81f8ARsKfj1Hd7M4JNXV0oc_WjhT5dOHw&e=
