LIBBSD
Kirspel, Kevin Kevin-Kirspel at idexx.com
Mon Jul 3 19:00:50 UTC 2017
The MMU is disabled right now because I am tracking down a problem (not related to LIBBSD).  I was going to turn it back on after I solve that issue.
I'm using a 1ms tick.
Kevin Kirspel
Electrical Engineer - Sr. Staff
Idexx Roswell
235 Hembree Park Drive
Roswell GA 30076
Tel: (770)-510-4444 ext. 81642
Direct: (770)-688-1642
Fax: (770)-510-4445
-----Original Message-----
From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
Sent: Monday, July 03, 2017 1:47 AM
To: Kirspel, Kevin <Kevin-Kirspel at idexx.com>; devel at rtems.org
Subject: Re: LIBBSD
On 30/06/17 20:08, Kirspel, Kevin wrote:
> Case #2: Enable the RTEMS callout timer but do not call "callout_process()" (the timer service routine just resets the timer and quits) .
> IDLE Task CPUUSE: 93.144%
> TIME Task CPUUSE: 6.282%
In this case you have some low-level problem on your target. Is the cache enabled and properly set up in the MMU? How many ticks per second do you use?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
