Interrupts strange behavior on RISC-V
Denis Obrezkov denisobrezkov at gmail.com
Sun Jul 9 00:30:33 UTC 2017
I found the problem, I made a mistake in my code, instead of:
if ((cause & MCAUSE_MTIME) == MCAUSE_MTIME) {
I have written:
if (cause & MCAUSE_MTIME) {
now local interrupts work.
2017-07-08 19:18 GMT+02:00 Denis Obrezkov <denisobrezkov at gmail.com>:
> 2017-07-08 18:05 GMT+02:00 Joel Sherrill <joel at rtems.org>:
>> On Jul 8, 2017 10:09 AM, "Denis Obrezkov" <denisobrezkov at gmail.com>
>> wrote:
>> Hello all,
>> I worked with local interrupts last few days and found some strange
>> behavior:
>> I am trying to handle local interrupts.
>> That's what I do, in my handler for timer interrupts:
>> * disable timer interrupts in mie
>> * read a current value from mtime
>> * copy it to mtimecmp (both are 64bit width types)
>> * add some big value to mtimecmp
>> * enable timer interrupts in mie.
>> And I have two boards and the problem is that on one of them interrupts
>> are permanently generated because mip register is always 1 in mtip
>> position, though mtimecmp is greater than mtime, and are not generated at
>> all on the other.
>> Is there a procedure for clearing the interrupt?
> Yes, it is written that external interrupts are cleared by PLIC (external
> interrupt controller),
> software interrupts are cleared I think by the main thread (I didn't find
> it in docs), and timer
> interrupts are cleared by writing the value in mtimecmp memory-mapped
> register greater
> than in mtime  (memory mapped register too.) [2, p.28]
>> In this piece of code, I turn on interrupts:
>> la t0, RISCV_Exception_default
>> csrs mtvec, t0
>> li t0, 0x88
>> csrs mie, t0
>> csrsi mstatus, 0x8
>> Can you point us to the documentation and section where this timer
>> behavior is defined? Sometimes having someone else read it can provide a
>> different interpretation.
>> And is there other code like Linux which deals with this timer? There may
>> be a magic sequence you are missing
> I wasn't able to find a magic sequence and didn't look at Linux code, but
> I initialized it like in hifive1 example provided with FreedomStudio (IDE
> for HiFive1).:
> https://github.com/sifive/freedom-e-sdk/tree/master/bsp
> But these are the docs:
> Description of mstatus register, which contains mie field for global
> interrupt enabling (Ch 3.1.6):
> [1] https://riscv.org/specifications/privileged-isa/
> Description of the core, on which SoC is based (Ch 6 is about interrupts):
> [2] https://www.sifive.com/documentation/coreplex/e31-coreplex-manual/
> There are also description of the SoC:
> https://www.sifive.com/documentation/freedom-soc/freedom-e300-platform-
> reference-manual/
> and description of the chip:
> https://www.sifive.com/documentation/chips/freedom-e310-g000-manual/
> Regards, Denis Obrezkov
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170709/96540430/attachment-0002.html>
