HiFive1 BSP current state
Thu Jul 20 09:42:39 UTC 2017
https://docs.rtems.org/branches/master/c-user/configuring_a_system.html
The source is here in case you need to submit a patch:
https://git.rtems.org/rtems-docs/tree/c-user/configuring_a_system.rst
--joel
On Thu, Jul 20, 2017 at 4:34 AM, Denis Obrezkov <denisobrezkov at gmail.com>
wrote:
> 2017-07-18 14:10 GMT+02:00 Joel Sherrill <joel.sherrill at gmail.com>:
>> I am not near a computer to check but is there a section in the
>> Configuring a System chapter with a low memory example? I know the
>> individual options are documented but an example configuration with the
>> safer ones to use might help users.
> Could you point me to the documentation with the Configuration a System
> chapter?
> Regards, Denis Obrezkov
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170720/b46ea92a/attachment-0002.html>
