Optimization issue in RISC-V BSP
Denis Obrezkov denisobrezkov at gmail.com
Fri Jul 28 19:50:01 UTC 2017
>> I can see that during task initialization I have a call:
>>  _Thread_Initialize_information (information=information at entry=0x80000ad4
>> <_RTEMS_tasks_Information>, the_api=the_api at entry=OBJECTS_CLASSIC_API,
>> the_class=the_class at entry=1, maximum=124,
>>     is_string=is_string at entry=false, maximum_name_length=maximum_na
>> me_length at entry=4)
>> And maximum is 124, but I have a configuration parameter:
>> #define CONFIGURE_MAXIMUM_TASKS             4
> I can't imagine any standard RTEMS test configuring that many tasks.
> Is there a data corruption issue?
> 124 = 0x7c which doesn't ring any bells for me on odd memory issues.
> What is the contents of "Configuration_RTEMS_API"?
Oh, I change my configuration options a bit, they are:
  #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
  #define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
  #define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
  #define CONFIGURE_TERMIOS_DISABLED
  #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 0
  #define CONFIGURE_MINIMUM_TASK_STACK_SIZE 512
  #define CONFIGURE_MAXIMUM_PRIORITY 3
  #define CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS
  #define CONFIGURE_IDLE_TASK_BODY Init
  #define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
  #define CONFIGURE_TASKS 4
  #define CONFIGURE_UNIFIED_WORK_AREAS
Also it is the test from a lower ticker example.
Configuration_RTEMS_API with -O0 option:
{maximum_tasks = 5, maximum_timers = 0, maximum_semaphores = 7,
maximum_message_queues = 0, maximum_partitions = 0, maximum_regions = 0,
maximum_ports = 0, maximum_periods = 0,
  maximum_barriers = 0, number_of_initialization_tasks = 0,
User_initialization_tasks_table = 0x0}
with -Os option:
{maximum_tasks = 124, maximum_timers = 0, maximum_semaphores = 7,
>> It seems that other tasks are LIBBLOCK tasks.
>> Also, this is my Configuration during run:
>> (gdb) p Configuration.stack_space_size
>> $1 = 2648
>> (gdb) p Configuration.work_space_size
>> $2 = 4216
>> (gdb) p Configuration.interrupt_stack_size
>> $3 = 512
>> (gdb) p Configuration.idle_task_stack_size
>> $4 = 512
> That looks reasonable. Add CONFIGURE_MAXIMUM_PRIORITY and set it to 4.
> That should
> reduce the workspace.
>  long term, we might want to consider lowering it permanently like one of
> the Coldfires
> had to. Or change the default scheduler to the Simple one to save memory.
I haven't dealt with the Scheduler option yet.
Regards, Denis Obrezkov
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170728/b6bd076e/attachment-0002.html>
