Optimization issue in RISC-V BSP
    Joel Sherrill
    joel at rtems.org
    Sun Jul 30 01:10:06 UTC 2017
On Jul 29, 2017 8:02 PM, "Denis Obrezkov" <denisobrezkov at gmail.com> wrote:
2017-07-30 2:34 GMT+02:00 Joel Sherrill <joel at rtems.org>:
> Sorry to top post but this thread is very deep to answer on a phone.
> Try looking at the same code on the erc32 bsp and see how it is done.
> Also you could disable the atexit() call and see how.much further you get.
> Ok, I will look at erc32 bsp.
I have removed atexit call, now I can proceed further, till the while(1)
loop in the low ticker test.
But the Dummy Clock doesn't tick.
So, I again get the output:
*** LOW MEMORY CLOCK TICK TEST ***
TA1  - rtems_clock_get_tod - 09:00:00   12/31/1988
TA2  - rtems_clock_get_tod - 09:00:00   12/31/1988
TA3  - rtems_clock_get_tod - 09:00:00   12/31/1988
Low ticker has its Init task become the idle task. Your clock driver
simulator thread is likely never running.
Try turning that option off in the test
Regards, Denis Obrezkov
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170729/8ec00099/attachment-0002.html>
