Optimization issue in RISC-V BSP
Denis Obrezkov denisobrezkov at gmail.com
Sun Jul 30 19:03:39 UTC 2017
2017-07-30 20:40 GMT+02:00 Joel Sherrill <joel at rtems.org>:
> On Jul 30, 2017 12:19 PM, "Denis Obrezkov" <denisobrezkov at gmail.com>
> wrote:
> 2017-07-30 3:10 GMT+02:00 Joel Sherrill <joel at rtems.org>:
>> On Jul 29, 2017 8:02 PM, "Denis Obrezkov" <denisobrezkov at gmail.com>
>> wrote:
>> 2017-07-30 2:34 GMT+02:00 Joel Sherrill <joel at rtems.org>:
>>> Sorry to top post but this thread is very deep to answer on a phone.
>>> Try looking at the same code on the erc32 bsp and see how it is done.
>>> Also you could disable the atexit() call and see how.much further you
>>> get.
>>> Ok, I will look at erc32 bsp.
>> I have removed atexit call, now I can proceed further, till the while(1)
>> loop in the low ticker test.
>> But the Dummy Clock doesn't tick.
>> So, I again get the output:
>> *** LOW MEMORY CLOCK TICK TEST ***
>> TA1  - rtems_clock_get_tod - 09:00:00   12/31/1988
>> TA2  - rtems_clock_get_tod - 09:00:00   12/31/1988
>> TA3  - rtems_clock_get_tod - 09:00:00   12/31/1988
>> Low ticker has its Init task become the idle task. Your clock driver
>> simulator thread is likely never running.
>> Try turning that option off in the test
>> Regards, Denis Obrezkov
> I tried it, but I had an error
> ../../../../../hifive1/lib/include/rtems/confdefs.h:3586:2: error: #error
> "CONFIGURATION ERROR: No initialization tasks or threads configured!!"
>  #error "CONFIGURATION ERROR: No initialization tasks or threads
> configured!!"
> You have to configure an Init task.
> Yes, I understand that, but I can't find proper configuration options.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170730/1962793a/attachment-0002.html>
