Optimization issue in RISC-V BSP
Denis Obrezkov denisobrezkov at gmail.com
Mon Jul 31 10:23:34 UTC 2017
2017-07-31 11:56 GMT+02:00 Denis Obrezkov <denisobrezkov at gmail.com>:
> 2017-07-31 1:08 GMT+02:00 Hesham Almatary <heshamelmatary at gmail.com>:
>> On Mon, Jul 31, 2017 at 5:03 AM, Denis Obrezkov <denisobrezkov at gmail.com>
>> wrote:
>> > 2017-07-30 20:40 GMT+02:00 Joel Sherrill <joel at rtems.org>:
>> >> On Jul 30, 2017 12:19 PM, "Denis Obrezkov" <denisobrezkov at gmail.com>
>> >> wrote:
>> >> 2017-07-30 3:10 GMT+02:00 Joel Sherrill <joel at rtems.org>:
>> >>> On Jul 29, 2017 8:02 PM, "Denis Obrezkov" <denisobrezkov at gmail.com>
>> >>> wrote:
>> >>> 2017-07-30 2:34 GMT+02:00 Joel Sherrill <joel at rtems.org>:
>> >>>> Sorry to top post but this thread is very deep to answer on a phone.
>> >>>> Try looking at the same code on the erc32 bsp and see how it is done.
>> >>>> Also you could disable the atexit() call and see how.much further you
>> >>>> get.
>> >>> Ok, I will look at erc32 bsp.
>> >>> I have removed atexit call, now I can proceed further, till the
>> while(1)
>> >>> loop in the low ticker test.
>> >>> But the Dummy Clock doesn't tick.
>> >>> So, I again get the output:
>> >>> *** LOW MEMORY CLOCK TICK TEST ***
>> >>> TA1  - rtems_clock_get_tod - 09:00:00   12/31/1988
>> >>> TA2  - rtems_clock_get_tod - 09:00:00   12/31/1988
>> >>> TA3  - rtems_clock_get_tod - 09:00:00   12/31/1988
>> >>> Low ticker has its Init task become the idle task. Your clock driver
>> >>> simulator thread is likely never running.
>> >>> Try turning that option off in the test
>> >>> Regards, Denis Obrezkov
>> >> I tried it, but I had an error
>> >> ../../../../../hifive1/lib/include/rtems/confdefs.h:3586:2: error:
>> #error
>> >> "CONFIGURATION ERROR: No initialization tasks or threads configured!!"
>> >>  #error "CONFIGURATION ERROR: No initialization tasks or threads
>> >> configured!!"
>> >> You have to configure an Init task.
>> > Yes, I understand that, but I can't find proper configuration options.
>> #define CONFIGURE_INIT
>> There might be other #ifdefs needed as well like:
>> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>> Have a look at the existing hello and ticker examples (not low ticker).
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
>> Hesham
> I was trying to implement interrupt-driven clock driver. In bspstart.c I
> added bsp_interrupt_initialize() and
> added an interrupt initialization code
> static void FE310_clock_driver_support_install_isr(
>   rtems_isr_entry Clock_isr
>   rtems_status_code sc = RTEMS_SUCCESSFUL;
>   sc = rtems_interrupt_handler_install(
>     1,
>     "Clock",
>     RTEMS_INTERRUPT_UNIQUE,
>     (rtems_interrupt_handler) Clock_isr,
>     NULL
>   if ( sc != RTEMS_SUCCESSFUL ) {
>     rtems_fatal_error_occurred(0xdeadbeef);
> Also, I added a call in IRQ handler:
> bsp_interrupt_handler_table[1].handler(bsp_interrupt_handler
> _table[1].arg);
> This way I was able to generate one tick and get an exception on the
> second with -O0 and
> I wasn't able to generate any interrupts with -Os option with the same
> code.
> With -O0 code behaves differently, I think I am missing something.
I think I have an error during context switching/context saving.
Hesham, can you check it:
https://github.com/embeddedden/rtems-riscv/blob/hifive1/cpukit/score/cpu/riscv32/riscv-context-switch.S
https://github.com/embeddedden/rtems-riscv/blob/hifive1/c/src/lib/libbsp/riscv32/hifive1/start/start.S#L196
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170731/a8c80c0e/attachment-0002.html>
