[PATCH v3] User Manual: Added rtems-tester in the docs
Chris Johns
chrisj at rtems.org
Thu Jun 1 01:40:01 UTC 2017
Thanks for patch. Comments in the email.
Note, I seem to have broken the section headings and will fix soon.
On 31/05/2017 23:33, Tanu Hari Dixit wrote:
> Adds as part of Tools
> user/tools/index.rst | 1 +
> user/tools/rtems-tester.rst | 636 ++++++++++++++++++++++++++++++++++++++++++++
> 2 files changed, 637 insertions(+)
> create mode 100644 user/tools/rtems-tester.rst
> diff --git a/user/tools/index.rst b/user/tools/index.rst
> index d77a7ca..9e2ca89 100644
> --- a/user/tools/index.rst
> +++ b/user/tools/index.rst
> @@ -21,3 +21,4 @@ executables.
> .. include:: exeinfo.rst
> .. include:: trace-linker.rst
> .. include:: bsp-builder.rst
> +.. include:: rtems-tester.rst
Please call the file 'tester.rst'. This makes the naming consistent with the
other commands (hint: git mv ...).
> diff --git a/user/tools/rtems-tester.rst b/user/tools/rtems-tester.rst
> new file mode 100644
> index 0000000..425a1fb
> --- /dev/null
> +++ b/user/tools/rtems-tester.rst
> @@ -0,0 +1,636 @@
> +.. comment SPDX-License-Identifier: CC-BY-SA-4.0
> +.. comment: Copyright (c) 2017 Chris Johns <chrisj at rtems.org>
> +.. comment: All rights reserved.
> +RTEMS Tester
> +.. index:: Tools, rtems-tester
> +The RTEMS Tester is a test framework. It includes a command line interface to
> +run tests on supported targets. The framework provides back-end support for
> +common simulators and debuggers. The board support package (BSP) configurations
> +for RTEMS are provided and can be used to run all the tests provided with
> +RTEMS. The framework is not specific to RTEMS and can be configured to run any
> +suitable application.
> +RTEMS is an embedded operating system and is cross-compiled on a range of host
> +machines. The executables run on the target hardware and this can vary widely
> +from open source simulators, commercial simulators, debuggers with simulators,
> +to debuggers with hardware specific pods and devices. Testing RTEMS requires
> +the cross-compiled test executable is transferred to the target hardware,
> +executed and the output returned to the host where it is analyzed to determine
> +the test result. The RTEMS Tester provides a framework to do this.
> +Running all the RTEMS tests on your target is very important. It provides you
> +with a traceable record showing that your RTEMS version and its tools are
> +working at the level the RTEMS development team expect when releasing
> +RTEMS. Being able to easily run the tests and verify the results is critical in
> +maintaining a high standard.
> +The RTEMS Tester contains:
> +* Command line tool (``rtems-test``)
Please use ":program:`rtems-test`". There are other places that need updating.
> +* BSP Configuration scripts
> +* Back-end Configuration scripts
> +* Back-end Python classes
> +* Python based framework
> +This document is for users of the RTEMS Tester as well as those wanting to
> +develop, extend and investigate the RTEMS Tester.
I think "The RTEMS Tester contains:" ... here can be removed.
> +License
> +The RTEMS Tester is part of the RTEMS Tools Project. The code is released under
> +the OSI approved "The BSD 2-Clause License". It is free to use and we encourage
> +this, including on operating systems other than RTEMS.
> +The code and command line tools must retain the same names and always reference
> +the RTEMS Tools Project.
This section can be removed.
> +Quick Start
> +The quick start will show you how to run the test suite for a BSP. It will
> +explain how to get the RTEMS Tester, set it up and run the tests for the erc32
> +BSP. It assumes you have a valid SPARC tool chain and have built the erc32 BSP
> +version of RTEMS 4.12.
> +Setup
> +Set up a development work space:
> +.. code-block:: shell
> + $ cd
> + $ mkdir -p development/rtems/test
> + $ cd development/rtems/test
> +First fetch the RTEMS tester from the RTEMS Tools repository:
> + $ git clone git://git.rtems.org/rtems-tools.git rtems-tools.git
> + $ cd rtems-tools.git/tester
This section is not needed anymore. The User Manual should have covered this
already.
> +Available BSP testers
> +You can list the available BSP testers with:
> + $ ./rtems-test --list-bsps
$ rtems-test --list-bsps
> + arm920
> + beagleboardxm
> + jmr3904-run
> + jmr3904
> + mcf5235
> + psim-run
> + psim
> + realview_pbx_a9_qemu
> + sis-run
> + sis
> + xilinx_zynq_a9_qemu
> + xilinx_zynq_a9_qemu_smp
> + xilinx_zynq_zc706
> + xilinx_zynq_zc706_qemu
> +.. note:: The list is growing all the time and if your BSP is not supported we
> + encourage you to add it and submit the configuration back to the project.
Over 80 columns. Please make sure all text is wraps at 80 columns.
project.
> +Some of the BSPs may appear more than once in the list. These are aliased BSP
> +configurations that may use a different back-end. An example is the SPARC
> +Instruction Simulator (SIS) BSP. There is the 'sis' tester which uses the GDB
> +back-end and the 'sis-run' tester which uses the command line version of the SIS
> +simulator. We will show how to use ``rtems-test`` command with the SIS BSP
> +because it is easy to build an use.
> +Adding support for a BSP to the tester
> +To add support for a BSP, one should add a configuration file in
> +``rtems-tools.git/tester/rtems/testing/bsps``. The configuration files
> +should be specified in an INI file. The configuration files provide a
> +means to the backend of `rtems-tester` to automate the running of tests.
> +There is the ``<bsp>`` tester which uses the GDB back-end and the ``<bsp>-run``
> +tester which uses the command line version of the respective simulator.
> +The general format for specifying an INI configuration file is as follows:
> +<bsp>.ini:
Should this be ``<bsp>.ini``: ?
> + [<bsp_name>]
> + bsp = '<bsp_name>'
> + gdb = '%{_rtscripts}/gdb.cfg'
> + arch = '<arch_name>'
> + [gdb_script]
> + gdb_script ='<bsp>_gdb_script'
> + <bsp>_gdb_script = '<Instructions for gdb
> +<bsp>-run.ini:
Same?
> + [<bsp_name>]
> + [run]
> + run = '%{_rtscripts}/run.cfg'
> + bsp_run_cmd = '%{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-run'
> + bsp_run_opts = '<options>'
> +Here is an example:
> +arm7tdmi.ini:
And again?
> + [arm7tdmi]
> + bsp = 'arm7tdmi'
> + arch = 'arm'
> + [gdb_script]
> + gdb_script ='arm7tdmi_gdb_script'
> + arm7tdmi_gdb_script = 'target sim
> + load
> + run'
> +arm7tdmi-run.ini:
> + [arm7tdmi]
> + bsp = 'arm7tdmi'
> + [run]
> + arch = 'arm'
> + bsp_run_opts = '-a -nouartrx'
> +If the tester should run the tests on qemu for a bsp, the given pattern can
> +be followed:
> + [<bsp_name>]
> + [qemu-script]
> + run = '%{_rtscripts}/qemu.cfg'
> + opts = '%{qemu_opts_base} %{qemu_opts_no_net} -m 32M'
> +For instance,
> +generic_or1k.ini:
> + [generic_or1k]
> + bsp = 'generic_or1k'
> + [qemu-script]
> + arch = 'or32'
> +User can also provide a "settings.ini" file in case a configuration file needs
> +a path to, for instance, a first stage bootloader (fsbl) that is placed
> +somewhere in the host machine. The settings.ini file can be passed with
> +``rtems-test --with-settings = /path/to/settings/file`` option. The
> +<bsp_name>.ini can contain defaults and the settings file can contain the
> +user-specified configuration.
> +xilinx_zynq_zc706.ini:
> + [<xilinx_zynq_zc706>]
Is the <> needed here?
> + bsp = 'xilinx_zynq_zc706'
Is the extra whitespace needed ater the '=' ?
> + jobs = '1'
> + [gdb-script]
> + arch = 'arm'
> + bsp_tty_dev = ${settings:bsp_tty_dev}
> + gdb_script = 'xilinx_zynq_zc706_gdb_script'
> + xilinx_zynq_zc706_gdb_script = 'target remote kaka:3333
> + mon load_image ${settings:path_to_fsbl} 0 elf
> + mon resume 0
> + mon sleep 4000
> + mon halt
> + load
> + b bsp_reset
> + continue'
> +settings.ini:
> + [settings]
> + bsp_tty_dev = '/dev/cu.SLAB_USBtoUART'
> + path_to_fsbl = '/home/chris/development/si/work/hydra/boot/xilinx-zynq-fsbl/build/arm-rtems4.11-xilinx_zynq_zc706/hydra-fsbl.elf'
Please remove this. We should not document the hard coded paths. This can be
added later once we have figure this out.
> +Building RTEMS Tests
> +Build RTEMS with a configuration command line something similar to:
> +.. note:: The following assumes a Unix-type host and that the tools have been
> + built with a prefix of ``$HOME/development/rtems/4.12``.
> + $ cd
> + $ export PATH=$HOME/development/rtems/4.12/bin:$PATH
> + $ mkdir -p development/rtems/kernel
> + $ cd development/rtems/kernel
> + $ git clone git://git.rtems.org/rtems.git rtems.git
> + $ cd rtems.git
> + $ ./bootstrap -c && ./bootstrap -p && ./bootstrap
> + $ cd ..
> + $ mkdir -p builds/erc32
> + $ cd builds/erc32
> + $ ../../rtems.git/configure --target=sparc-rtems4.12 \
> + --enable-tests --enable-rtemsbsp=erc32
> + $ make
> +Add the -j option to the make command with the number of cores to run the
> +build parallel where it can.
I think this can he made simpler by reducing it to documenting the
``--enable-tests`` option. A reference to the kernel building sections of this
manual would help.
> +Building all the tests takes time and it uses more disk so be patient. When
> +finished all the tests will be built and ready to run. Before running all the
> +tests it is a good idea to run the ``hello`` test. The ``hello`` test is an
> +RTEMS version of the classic "Hello World" example and running it shows you
> +have a working tool chain and build of RTEMS ready to run the tests. Using the
> +run command:
> + $ sparc-rtems4.12-run sparc-rtems4.12/c/erc32/testsuites/samples/hello/hello.exe
> + *** BEGIN OF TEST HELLO WORLD ***
> + Hello World
> + *** END OF TEST HELLO WORLD ***
> +The run command is the GDB simulator without the GDB part.
> +Running the example using GDB:
> + $ sparc-rtems4.12-gdb sparc-rtems4.12/c/erc32/testsuites/samples/hello/hello.exe
> + GNU gdb (GDB) 7.12
> + Copyright (C) 2016 Free Software Foundation, Inc.
> + License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
> + This is free software: you are free to change and redistribute it.
> + There is NO WARRANTY, to the extent permitted by law. Type "show copying"
> + and "show warranty" for details.
> + This GDB was configured as "--host=x86_64-linux-gnu --target=sparc-rtems4.12".
> + Type "show configuration" for configuration details.
> + For bug reporting instructions, please see:
> + <http://www.gnu.org/software/gdb/bugs/>.
> + Find the GDB manual and other documentation resources online at:
> + <http://www.gnu.org/software/gdb/documentation/>.
> + For help, type "help".
> + Type "apropos word" to search for commands related to "word"...
> + Reading symbols from
> + sparc-rtems4.12/c/erc32/testsuites/samples/hello/hello.exe...done.
> + (gdb) target sim
> + Connected to the simulator.
> + (gdb) load
> + (gdb) r
> + Starting program: sparc-rtems4.12/c/erc32/testsuites/samples/hello/hello.exe
> + Hello World
> + [Inferior 1 (process 42000) exited normally]
> + (gdb) q
> +The command r is used to debug set break points before issuing the GDB run
> +command.
The command ``r`` ... ``run`` ..
> +There are currently close to 500 separate tests and you can run them all with a
> +single RTEMS Tester command.
> +.. note:: Use a recent RSB version to build a SPARC tool chain. A recent patch
> + fixes issues with the GDB simulator and it improves the test results.
> + It is also recommended you use a recent RTEMS 4.11 version as the
> + tests have been cleaned up to improve the results.
Please remove the note.
> +Running the Tests
> +The ``rtems-test`` command line accepts a range of options. These are discussed
> +later in the manual. Any command line argument without a `--` prefix is a test
> +executable. You can pass more than one executable on the command line. If the
> +executable is a path to a directory the directories under that path are
> +searched for any file with a ``.exe`` extension. This is the default extension
> +for RTEMS executables built within RTEMS.
> +To run the erc32 tests enter the following command from the top of the erc32 BSP
> +build tree:
> + $ ~/development/rtems/test/rtems-tools.git/tester/rtems-test \
> + --log=log_erc32_run \
> + --rtems-bsp=erc32-run \
> + --rtems-tools=$HOME/development/rtems/4.12 \
> + RTEMS Testing - Tester, 4.12.not_released
> + [ 1/13] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 | sparc/erc32: base_sp.exe
> + [ 2/13] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 | sparc/erc32: capture.exe
> + [ 3/13] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 | sparc/erc32: cdtest.exe
> + [ 4/13] p:0 f:0 u:0 e:0 I:0 B:0 t:0 i:0 | sparc/erc32: fileio.exe
> + [ 5/13] p:2 f:0 u:0 e:0 I:0 B:0 t:0 i:0 | sparc/erc32: hello.exe
> + [ 6/13] p:2 f:0 u:0 e:0 I:0 B:0 t:0 i:0 | sparc/erc32: cxx_iostream.exe
> + [ 8/13] p:2 f:0 u:0 e:0 I:0 B:0 t:2 i:0 | sparc/erc32: minimum.exe
> + [ 7/13] p:2 f:0 u:0 e:0 I:0 B:0 t:2 i:0 | sparc/erc32: loopback.exe
> + [ 9/13] p:3 f:0 u:0 e:0 I:0 B:0 t:3 i:0 | sparc/erc32: nsecs.exe
> + [10/13] p:3 f:0 u:0 e:0 I:0 B:0 t:3 i:0 | sparc/erc32: paranoia.exe
> + [11/13] p:4 f:0 u:0 e:0 I:0 B:0 t:3 i:0 | sparc/erc32: pppd.exe
> + [12/13] p:6 f:0 u:0 e:0 I:0 B:0 t:3 i:0 | sparc/erc32: ticker.exe
> + [13/13] p:6 f:0 u:0 e:0 I:0 B:0 t:3 i:0 | sparc/erc32: unlimited.exe
> + Passed: 7
> + Failed: 0
> + User Input: 0
> + Expected Fail: 0
> + Indeterminate: 0
> + Benchmark: 0
> + Timeout: 5
> + Invalid: 1
> + Total: 13
> + Average test time: 0:00:27.963000
> + Testing time : 0:06:03.519012
> +* The RTEMS Tester's test command. In this example we are using an absolute
> + path.
> +* The ``--log`` option sends the output to a log file. By default only failed
> + tests log the complete output.
> +* Select the erc32 BSP and use GDB.
> +* Path to the RTEMS tools so GDB can be found.
> +* Path to the erc32 BSP built with all tests to run. If you add subdirectories
> + to the path specific tests can be run.
> +* The output has been shortened so it fits nicely here.
> +* The test results shows passes, fails, timeouts, and invalid results. In
> + this run 13 tests passed and 5 tests timed out and 1 is invalid. The
> + timeouts are probably due to the tests not having enough execute time to
> + complete. The default timeout is 180 seconds and some of the interrupt tests
> + need longer. The amount of time depends on the performance of your host CPU
> + running the simulations.
> +* The output shows the average time per test and the total time taken to run
> + all the tests.
> +* If the path to the testsuites was put to
> + ``sparc-rtems4.12/c/erc32/testsuites`` instead of
> + ``sparc-rtems4.12/c/erc32/testsuites/samples`` then all the executables
> + would have been tested and not just those in samples.
> +This BSP requires the ``--rtems-tools`` option because the SPARC GDB is the
> +``sparc-rtems4.11-gdb`` command that is part of the RTEMS tools. Not every BSP
> +will require this option so you will need to check the specifics of the BSP
> +configuration to determine if it is needed.
> +The output you see is each test starting to run. The ``rtems-test`` command by
> +default runs multiple tests in parallel so you will see a number start quickly
> +and then new tests start as others finish. The output shown here is from an
> +8 core processor so the first 8 are started in parallel and the status shows
> +the order in which they actually started, which is not 1 to 8.
> +The test start line shows the current status of the tests. The status reported
> +is when the test starts and not the result of that test. A fail, timeout or
> +invalid count changing means a test running before this test started failed,
> +not the starting test. The status here has 7 tests passed, no failures, 5
> +timeouts and 1 invalid test.
> +* [ 5/13] indicates the test number, in this case test 5 of 13 tests.
> +* p is the passed test count (2 in this case)
* ``p`` is the ...
and for the others below ..
> +* f is the failed test count (0 in this case)
> +* u is the count for test marked as "user-input" as they expect input from user
> +* e is the expected-fail count (tests that are expected to fail)
> +* I is the count for tests the results of which are indeterminate
> +* B is the count for benchmarked tests
> +* t is the timeout test count
> +* i is the invalid test count.
> +* sparc/erc32 is the architecture and BSP names.
``sparc/erc32`` ..
> +* hello.exe is the executable name.
``hello.exe`` ...
> +The test log records all the tests and results. The reporting mode by default
> +only provides the output history if a test fails, times out, or is invalid. The
> +time taken by each test is also recorded.
> +The tests must complete in a specified time or the test is marked as timed
> +out. The default timeout is 3 minutes and can be globally changed using the
> +``--timeout`` command line option. The time required to complete a test can
> +vary. When simulators are run in parallel the time taken depends on the
> +specifics of the host machine being used. A test per core is the most stable
> +method even though more tests can be run than available cores. If your machine
> +needs longer or you are using a VM you may need to lengthen the timeout.
> +Test Status
> +Tests can be marked with one of the following:
> +* Pass
> +* Fail
> +* Timeout
> +* Invalid
This needs updating.
> +The RTEMS console or stdout output from the test is needed to determine the
... ``staout`` ...
> +result of the test.
> +Pass
> +A test passes if the start and end markers are seen in the test output. The
> +start marker is ``***`` and the end mark is ``*** END OF TEST``. All tests in
> +the RTEMS test suite have these markers.
> +Fail
> +A test fails if the start marker is seen and there is no end marker.
> +Timeout
> +If the test does not complete within the timeout setting the test is marked as
> +having timed out.
> +Invalid
> +If no start marker is seen the test is marked as invalid. If you are testing on
> +real target hardware things can sometimes go wrong and the target may not
> +initialize or respond to the debugger in an expected way.
> +Reporting
> +The report written to the log has the following modes:
> +* All (``all``)
> +* Failures (``failures``)
> +* None (``none``)
> +The mode is controlled using the command line option ``--report-mode`` using
> +the values listed above.
> +All
> +The output of all tests is written to the log.
> +Failures
> +The output of the all tests that do not pass is written to the log.
> +None
> +No output is written to the log.
> +The output is tagged so you can determine where it comes from. The following is
> +the complete output for the In Memory File System test ``imfs_fslink.exe``
> +running on a Coldfire MCF5235 using GDB and a BDM pod:
> + [ 11/472] p:9 f:0 t:0 i:1 | m68k/mcf5235: imfs_fslink.exe
> + > gdb: ..../bin/m68k-rtems4.11-gdb -i=mi --nx --quiet ..../imfs_fslink.exe
> + > Reading symbols from ..../fstests/imfs_fslink/imfs_fslink.exe...
> + > done.
> + > target remote | m68k-bdm-gdbserver pipe 003-005
> + > Remote debugging using | m68k-bdm-gdbserver pipe 003-005
> + > m68k-bdm: debug module version 0
> + > m68k-bdm: detected MCF5235
> + > m68k-bdm: architecture CF5235 connected to 003-005
> + > m68k-bdm: Coldfire debug module version is 0 (5206(e)/5235/5272/5282)
> + > Process 003-005 created; pid = 0
> + > 0x00006200 in ?? ()
> + > thb *0xffe254c0
> + > Hardware assisted breakpoint 1 at 0xffe254c0
> + > continue
> + > Continuing.
> + ] External Reset
> + ] ColdFire MCF5235 on the BCC
> + ] Firmware v3b.1a.1a (Built on Jul 21 2004 17:31:28)
> + ] Copyright 1995-2004 Freescale Semiconductor, Inc. All Rights Reserved.
> + ] Enter 'help' for help.
> + > Temporary breakpoint
> + > 1, 0xffe254c0 in ?? ()
> + > load
> + > Loading section .text, size 0x147e0 lma 0x40000
> + > Loading section .data, size 0x5d0 lma 0x547e0
> + > Start address 0x40414, load size 85424
> + > Transfer rate: 10 KB/sec, 1898 bytes/write.
> + > b bsp_reset
> + > Breakpoint 2 at 0x41274: file ..../shared/bspreset_loop.c, line 14.
> + > continue
> + > Continuing.
> + ] dBUG>
> + ] *** FILE SYSTEM TEST ( IMFS ) ***
> + ] Initializing filesystem IMFS
> + ] *** LINK TEST ***
> + ] link creates hardlinks
> + ] test if the stat is the same
> + ] chmod and chown
> + ] unlink then stat the file
> + ] *** END OF LINK TEST ***
> + ] Shutting down filesystem IMFS
> + ] *** END OF FILE SYSTEM TEST ( IMFS ) ***
> + > Breakpoint
> + > 2, bsp_reset () at ..../m68k/mcf5235/../../shared/bspreset_loop.c:14
> + > 14 {
> + Result: passed Time: 0:00:10.045447
> +* GDB command line (Note: paths with \'....' have been shortened)
> +* Lines starting with ``>`` are from GDB's console.
> +* Line starting with ``]`` are from the target's console.
> +* The result with the test time.
> +Running Tests in Parallel
> +The RTEMS Tester supports parallel execution of tests by default. This only
> +makes sense if the test back-end can run in parallel without resulting in
> +resource contention. Simulators are an example of back-ends that can run in
> +parallel. A hardware debug tool like a BDM or JTAG pod can manage only a
> +single test at once so the tests need to be run one at a time.
> +The test framework manages the test jobs and orders the output in the report
> +log in test order. Output is held for completed tests until the next test to be
> +reported has finished.
> +Command Line Help
> +The ``rtems-test`` command line accepts a range of options. You can review the
> +available option by the ``--help`` option:
> + RTEMS Tools Project (c) 2012-2014 Chris Johns
> + Options and arguments:
> + --always-clean : Always clean the build tree, even with an error
> + --debug-trace : Debug trace based on specific flags
> + --dry-run : Do everything but actually run the build
> + --force : Force the build to proceed
> + --jobs=[0..n,none,half,full] : Run with specified number of jobs, default: num CPUs.
> + --keep-going : Do not stop on an error.
> + --list-bsps : List the supported BSPs
> + --log file : Log file where all build output is written to
> + --macros file[,file] : Macro format files to load after the defaults
> + --no-clean : Do not clean up the build tree
> + --quiet : Quiet output (not used)
> + --report-mode : Reporting modes, failures (default),all,none
> + --rtems-bsp : The RTEMS BSP to run the test on
> + --rtems-tools : The path to the RTEMS tools
> + --target : Set the target triplet
> + --timeout : Set the test timeout in seconds (default 180 seconds)
> + --trace : Trace the execution
> + --warn-all : Generate warnings
This should really be updated to the command formatting for the other commands.
It can wait will we agree it has to be done.
> +Development
> +The RTEMS Tester framework and command line tool is under active
> +development. These are changing, being fixed, broken and generally improved. If
> +you want to help please see the Wiki page for open items.
Remove this section.
> +History
> +The RTEMS Tester is based on a refactored base of Python code used in the RTEMS
> +Source Builder. This code provided a working tested base that has been extended
> +and expanded to meet the requirements for the RTEMS Tester. The tester uses the
> +specifics found in the various scripts and configurations in the
> +rtems-testing.git repo that has been accumulated over many years. The shell
> +script implementation is restricted in what it can do and, per BSP script, is a
> +maintenance burden. For example the command lines and options vary between each
> +script.
This section can also go.
Thanks
