RTEMS 4.12 gcc-7.1.0/binutils-2.28 test results
Thu Jun 1 03:40:05 UTC 2017
On 01/06/2017 10:43, Chris Johns wrote:
> On 01/06/2017 07:33, Sebastian Huber wrote:
>> Could you please use Binutils 2.28 for PowerPC. I will fix the bootloader
>> after the RSB update.
> Oops, I pushed the patch while taking with Joel before I saw this. Can you
> please undo the change when fixing the problem in the bootloader?
> I am sorry about this, it is my mistake.
Fix on the RSB master. Tested with:
$ rtems-bsp-builder --rtems-tools=/build/rtems/tools/4.12-7.1 \
  --rtems=/opt/work/chris/rtems/kernel/rtems.git --log=powerpc-7.1 \
  --arch=powerpc --build=standard --jobs=7/6
Results summary:
Total: Warnings:2410  exes:582  objs:74236  libs:3500
Failures:
   1 standard powerpc/mcp750 build:
      configure: /opt/work/chris/rtems/kernel/rtems.git/configure --target\
      =powerpc-rtems4.12 --enable-rtemsbsp=mcp750 --prefix=/opt/rtems/4.12
   2 standard powerpc/mtx603e build:
      =powerpc-rtems4.12 --enable-rtemsbsp=mtx603e\
   3 standard powerpc/mvme2100 build:
      =powerpc-rtems4.12 --enable-rtemsbsp=mvme2100\
   4 standard powerpc/mvme2307 build:
      =powerpc-rtems4.12 --enable-rtemsbsp=mvme2307\
   5 standard powerpc/qemuprep-altivec build:
      =powerpc-rtems4.12 --enable-rtemsbsp=qemuprep-altivec\
   6 standard powerpc/qemuprep build:
      =powerpc-rtems4.12 --enable-rtemsbsp=qemuprep\
Average BSP Build Time: 0:00:19.086596
Total Time 0:15:16.156621
Passes: 42   Failures: 6
