[PATCH 0/2] *** Docs Update ***
Cillian O'Donnell cpodonnell8 at gmail.com
Thu Jun 1 15:42:52 UTC 2017
*** Just to note the rsb quick-start is all updated except for the output of --list-bsets because my setup only ever finds output for ../bare/config and not ../source-builder/config so I left that bit out just in case. Maybe someone else can update that section to 4.12. ***
Cillian O'Donnell (2):
  rtems-docs/user/../quick.rst: Fix typo, hard coded path, code layout.
  docs/rsb/quick-start.rst: Fix typos, hard coded paths, version
 rsb/quick-start.rst  | 242 +++++++++++++++++++++++++--------------------------
 user/start/quick.rst |  15 ++--
 2 files changed, 129 insertions(+), 128 deletions(-)
2.7.4
