[PATCH] implementation of inttypes.h and test related to its methods
aadit0402
aadit0402 at gmail.com
Thu Jun 1 23:35:37 UTC 2017
cpukit/Makefile.am | 1 +
cpukit/configure.ac | 1 +
cpukit/inttypes/Makefile.am | 14 +++
cpukit/inttypes/imaxabs.c | 40 +++++++++
cpukit/inttypes/imaxdiv.c | 50 +++++++++++
cpukit/inttypes/strtoimax.c | 117 +++++++++++++++++++++++++
cpukit/inttypes/strtoumax.c | 116 +++++++++++++++++++++++++
cpukit/inttypes/wcstoimax.c | 125 +++++++++++++++++++++++++++
cpukit/inttypes/wcstoumax.c | 119 +++++++++++++++++++++++++
testsuites/samples/Makefile.am | 1 +
testsuites/samples/configure.ac | 1 +
testsuites/samples/psxinttypes01/Makefile.am | 22 +++++
testsuites/samples/psxinttypes01/init.c | 69 +++++++++++++++
testsuites/samples/psxinttypes01/psxid01.doc | 35 ++++++++
testsuites/samples/psxinttypes01/psxid01.scn | 38 ++++++++
15 files changed, 749 insertions(+)
create mode 100644 cpukit/inttypes/Makefile.am
create mode 100644 cpukit/inttypes/imaxabs.c
create mode 100644 cpukit/inttypes/imaxdiv.c
create mode 100644 cpukit/inttypes/strtoimax.c
create mode 100644 cpukit/inttypes/strtoumax.c
create mode 100644 cpukit/inttypes/wcstoimax.c
create mode 100644 cpukit/inttypes/wcstoumax.c
create mode 100644 testsuites/samples/psxinttypes01/Makefile.am
create mode 100644 testsuites/samples/psxinttypes01/init.c
create mode 100644 testsuites/samples/psxinttypes01/psxid01.doc
create mode 100644 testsuites/samples/psxinttypes01/psxid01.scn
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index ae5ed9b..045017e 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -7,6 +7,7 @@ include $(top_srcdir)/automake/multilib.am
_SUBDIRS = . score rtems sapi posix
_SUBDIRS += dev
_SUBDIRS += dtc/libfdt
+_SUBDIRS += inttypes
_SUBDIRS += libcrypt
_SUBDIRS += libcsupport libblock libfs
_SUBDIRS += libdrvmgr
diff --git a/cpukit/configure.ac b/cpukit/configure.ac
index b0aa9a0..ad0865b 100644
--- a/cpukit/configure.ac
+++ b/cpukit/configure.ac
@@ -461,6 +461,7 @@ score/cpu/sparc64/Makefile
score/cpu/v850/Makefile
score/cpu/no_cpu/Makefile
posix/Makefile
+inttypes/Makefile
libblock/Makefile
libdrvmgr/Makefile
libfs/Makefile
diff --git a/cpukit/inttypes/Makefile.am b/cpukit/inttypes/Makefile.am
new file mode 100644
index 0000000..c90b872
--- /dev/null
+++ b/cpukit/inttypes/Makefile.am
@@ -0,0 +1,14 @@
+include $(top_srcdir)/automake/multilib.am
+include $(top_srcdir)/automake/compile.am
+noinst_LIBRARIES = libinttypes.a
+libinttypes_a_SOURCES = imaxdiv.c imaxabs.c strtoimax.c strtoumax.c wcstoimax.c wcstoumax.c
+libinttypes_a_CPPFLAGS = $(AM_CPPFLAGS)
+#include $(srcdir)/preinstall.am
+include $(top_srcdir)/automake/subdirs.am
+include $(top_srcdir)/automake/local.am
diff --git a/cpukit/inttypes/imaxabs.c b/cpukit/inttypes/imaxabs.c
index 0000000..525e9c0
--- /dev/null
+++ b/cpukit/inttypes/imaxabs.c
@@ -0,0 +1,40 @@
+ * Copyright (c) 2001 Mike Barcroft <mike at FreeBSD.org>
+ * All rights reserved.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <stdint.h>
+#include <stdio.h>
+#include <rtems/inttypes.h>
+intmax_t
+imaxabs(intmax_t j)
+ return (j < 0 ? -j : j);
diff --git a/cpukit/inttypes/imaxdiv.c b/cpukit/inttypes/imaxdiv.c
index 0000000..7992caa
--- /dev/null
+++ b/cpukit/inttypes/imaxdiv.c
@@ -0,0 +1,50 @@
+ * are met:
+ * SUCH DAMAGE.
+#if HAVE_CONFIG_H
+#endif
+/* See comments in div.c for implementation details. */
+imaxdiv_t
+imaxdiv(intmax_t numer, intmax_t denom)
+ imaxdiv_t retval;
+ retval.quot = numer / denom;
+ retval.rem = numer % denom;
+#if !defined(__STDC_VERSION__) || (__STDC_VERSION__ < 199901L)
+ if (numer >= 0 && retval.rem < 0) {
+ retval.quot++;
+ retval.rem -= denom;
+#endif
+ return (retval);
diff --git a/cpukit/inttypes/strtoimax.c b/cpukit/inttypes/strtoimax.c
index 0000000..9971f73
--- /dev/null
+++ b/cpukit/inttypes/strtoimax.c
@@ -0,0 +1,117 @@
+ * This file has no copyright assigned and is placed in the Public Domain.
+ * This file is part of the mingw-w64 runtime package.
+ * No warranty is given; refer to the file DISCLAIMER.PD within this package.
+ This source code was extracted from the Q8 package created and
+ placed in the PUBLIC DOMAIN by Doug Gwyn <gwyn at arl.mil>
+ last edit: 1999/11/05 gwyn at arl.mil
+ Implements subclause 7.8.2 of ISO/IEC 9899:1999 (E).
+ This particular implementation requires the matching <inttypes.h>.
+ It also assumes that character codes for A..Z and a..z are in
+ contiguous ascending order; this is true for ASCII but not EBCDIC.
+#include <stdlib.h>
+#include <errno.h>
+#include <ctype.h>
+#include <inttypes.h>
+/* Helper macros */
+/* convert digit character to number, in any base */
+#define ToNumber(c) (isdigit(c) ? (c) - '0' : \
+ isupper(c) ? (c) - 'A' + 10 : \
+ islower(c) ? (c) - 'a' + 10 : \
+ -1 /* "invalid" flag */ \
+/* validate converted digit character for specific base */
+#define valid(n, b) ((n) >= 0 && (n) < (b))
+intmax_t
+strtoimax(nptr, endptr, base)
+ register const char * __restrict__ nptr;
+ char ** __restrict__ endptr;
+ register int base;
+ register uintmax_t accum; /* accumulates converted value */
+ register int n; /* numeral from digit character */
+ int minus; /* set iff minus sign seen */
+ int toobig; /* set iff value overflows */
+ if ( endptr != NULL )
+ *endptr = (char *)nptr; /* in case no conversion's performed */
+ if ( base < 0 || base == 1 || base > 36 )
+ errno = EDOM;
+ return 0; /* unspecified behavior */
+ /* skip initial, possibly empty sequence of white-space characters */
+ while ( isspace(*nptr) )
+ ++nptr;
+ /* process subject sequence: */
+ /* optional sign */
+ if ( (minus = *nptr == '-') || *nptr == '+' )
+ ++nptr;
+ if ( base == 0 ) {
+ if ( *nptr == '0' ) {
+ if ( nptr[1] == 'X' || nptr[1] == 'x' )
+ base = 16;
+ else
+ base = 8;
+ else
+ base = 10;
+ /* optional "0x" or "0X" for base 16 */
+ if ( base == 16 && *nptr == '0' && (nptr[1] == 'X' || nptr[1] == 'x') )
+ nptr += 2; /* skip past this prefix */
+ /* check whether there is at least one valid digit */
+ n = ToNumber(*nptr);
+ ++nptr;
+ if ( !valid(n, base) )
+ return 0; /* subject seq. not of expected form */
+ accum = n;
+ for ( toobig = 0; n = ToNumber(*nptr), valid(n, base); ++nptr )
+ if ( accum > (uintmax_t)(INTMAX_MAX / base + 2) ) /* major wrap-around */
+ toobig = 1; /* but keep scanning */
+ else
+ accum = base * accum + n;
+ *endptr = (char *)nptr; /* points to first not-valid-digit */
+ if ( minus )
+ if ( accum > (uintmax_t)INTMAX_MAX + 1 )
+ toobig = 1;
+ else
+ if ( accum > (uintmax_t)INTMAX_MAX )
+ toobig = 1;
+ if ( toobig )
+ errno = ERANGE;
+ return minus ? INTMAX_MIN : INTMAX_MAX;
+ else
+ return (intmax_t)(minus ? -accum : accum);
+long long __attribute__ ((alias ("strtoimax")))
+strtoll (const char* __restrict__ nptr, char ** __restrict__ endptr, int base);
diff --git a/cpukit/inttypes/strtoumax.c b/cpukit/inttypes/strtoumax.c
index 0000000..3612a23
--- /dev/null
+++ b/cpukit/inttypes/strtoumax.c
@@ -0,0 +1,116 @@
+#include <errno.h>
+#include <ctype.h>
+uintmax_t
+strtoumax(nptr, endptr, base)
+ register uintmax_t next; /* for computing next value of accum */
+ int minus; /* set iff minus sign seen (yes!) */
+ errno = EDOM;
+ ++nptr;
+ /* optional sign (yes!) */
+ ++nptr;
+ if ( base == 0 )
+ base = 16;
+ else
+ base = 8;
+ else
+ base = 10;
+ ++nptr;
+ accum = n;
+ if ( accum > UINTMAX_MAX / base + 1 /* major wrap-around */
+ || (next = base * accum + n) < accum /* minor wrap-around */
+ else
+ accum = next;
+ if ( toobig )
+ errno = ERANGE;
+ return UINTMAX_MAX;
+ else
+ return minus ? -accum : accum; /* (yes!) */
+unsigned long long __attribute__ ((alias ("strtoumax")))
+strtoull (const char* __restrict__ nptr, char ** __restrict__ endptr, int base);
diff --git a/cpukit/inttypes/wcstoimax.c b/cpukit/inttypes/wcstoimax.c
index 0000000..24667bd
--- /dev/null
+++ b/cpukit/inttypes/wcstoimax.c
@@ -0,0 +1,125 @@
+#include <wchar.h>
+#include <errno.h>
+#include <ctype.h>
+/* convert digit wide character to number, in any base */
+#define ToWNumber(c) (iswdigit(c) ? (c) - L'0' : \
+ iswupper(c) ? (c) - L'A' + 10 : \
+ iswlower(c) ? (c) - L'a' + 10 : \
+intmax_t
+wcstoimax(nptr, endptr, base)
+ register const wchar_t * __restrict__ nptr;
+ wchar_t ** __restrict__ endptr;
+ printf("In wcstoimax function \n");
+ *endptr = (wchar_t *)nptr; /* in case no conv performed */
+ errno = EDOM;
+ /* skip initial, possibly empty sequence of white-space w.characters */
+ while ( iswspace(*nptr) )
+ ++nptr;
+ if ( (minus = *nptr == L'-') || *nptr == L'+' )
+ ++nptr;
+ if ( base == 0 )
+ if ( *nptr == L'0' )
+ if ( nptr[1] == L'X' || nptr[1] == L'x' )
+ base = 16;
+ else
+ base = 8;
+ else
+ base = 10;
+ if ( base == 16 && *nptr == L'0'
+ && (nptr[1] == L'X' || nptr[1] == L'x')
+ n = ToWNumber(*nptr);
+ ++nptr;
+ accum = n;
+ for ( toobig = 0; n = ToWNumber(*nptr), valid(n, base); ++nptr )
+ else
+ *endptr = (wchar_t *)nptr; /* -> first not-valid-digit */
+ if ( minus )
+ toobig = 1;
+ else
+ toobig = 1;
+ if ( toobig )
+ errno = ERANGE;
+ else
+long long __attribute__ ((alias ("wcstoimax")))
+wcstoll (const wchar_t* __restrict__ nptr, wchar_t ** __restrict__ endptr, int base);
diff --git a/cpukit/inttypes/wcstoumax.c b/cpukit/inttypes/wcstoumax.c
index 0000000..a796a62
--- /dev/null
+++ b/cpukit/inttypes/wcstoumax.c
@@ -0,0 +1,119 @@
+#include <wchar.h>
+#include <errno.h>
+#include <ctype.h>
+uintmax_t
+wcstoumax(nptr, endptr, base)
+ errno = EDOM;
+ ++nptr;
+ ++nptr;
+ if ( base == 0 )
+ base = 16;
+ else
+ base = 8;
+ else
+ base = 10;
+ ++nptr;
+ accum = n;
+ else
+ accum = next;
+ if ( toobig )
+ errno = ERANGE;
+ else
+unsigned long long __attribute__ ((alias ("wcstoumax")))
+wcstoull (const wchar_t* __restrict__ nptr, wchar_t ** __restrict__ endptr, int base);
diff --git a/testsuites/samples/Makefile.am b/testsuites/samples/Makefile.am
index 85e89a5..fd16f57 100644
--- a/testsuites/samples/Makefile.am
+++ b/testsuites/samples/Makefile.am
@@ -8,6 +8,7 @@ _SUBDIRS += hello
_SUBDIRS += minimum
_SUBDIRS += nsecs
_SUBDIRS += paranoia
+_SUBDIRS += psxinttypes01
_SUBDIRS += ticker
_SUBDIRS += unlimited
diff --git a/testsuites/samples/configure.ac b/testsuites/samples/configure.ac
index ffe1bad..3d0ef5b 100644
--- a/testsuites/samples/configure.ac
+++ b/testsuites/samples/configure.ac
@@ -74,6 +74,7 @@ minimum/Makefile
nsecs/Makefile
paranoia/Makefile
pppd/Makefile
+psxinttypes01/Makefile
ticker/Makefile
unlimited/Makefile
diff --git a/testsuites/samples/psxinttypes01/Makefile.am b/testsuites/samples/psxinttypes01/Makefile.am
index 0000000..56a85aa
--- /dev/null
+++ b/testsuites/samples/psxinttypes01/Makefile.am
@@ -0,0 +1,22 @@
+AUTOMAKE_OPTIONS = subdir-objects
+rtems_tests_PROGRAMS = psxinttypes01
+psxinttypes01_SOURCES = init.c
+##dist_rtems_tests_DATA = psxinttypes01.scn
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/include
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(psxinttypes01_OBJECTS) $(psxinttypes01_LDADD)
+LINK_LIBS = $(psxinttypes01_LDLIBS) /home/aditya/development/b-sparc/sparc-rtems4.12/c/erc32/cpukit/inttypes/libinttypes.a
+psxinttypes01$(EXEEXT): $(psxinttypes01_OBJECTS) $(psxinttypes01_DEPENDENCIES)
+ @rm -f psxinttypes01$(EXEEXT)
+ $(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/samples/psxinttypes01/init.c b/testsuites/samples/psxinttypes01/init.c
index 0000000..bda6879
--- /dev/null
+++ b/testsuites/samples/psxinttypes01/init.c
@@ -0,0 +1,69 @@
+/*This is the test for inttypes library. It covers these functions :
+imaxabs(), imaxdiv(), strtoimax(), strtoumax(), wcstoimax(), wcstoumax().
+#ifdef HAVE_CONFIG_H
+#endif
+#include <rtems/printer.h>
+#include <rtems/test.h>
+/* forward declarations to avoid warnings */
+rtems_task Init(rtems_task_argument argument);
+const char rtems_test_name[] = "PSXINTTYPE 01";
+rtems_printer rtems_test_printer;
+ * RTEMS Startup Task
+rtems_task Init(
+ rtems_task_argument ignored
+ rtems_print_printer_printf(&rtems_test_printer);
+ rtems_test_begin();
+ char* endptr;
+ uintmax_t j,k;
+ int base = 10;
+ char *nptr;
+ wchar_t *nptr1, *endptr1;
+ intmax_t m;
+ nptr1 = L"10110134932";
+ nptr = "20690239864abc";
+ m = wcstoimax(nptr1, &endptr1, base);
+ printf("string = %s\n", nptr);
+ j = strtoumax(nptr, &endptr, base);
+ printf("wcstoimax = %jd\n", m);
+ k = wcstoumax(nptr1, &endptr1, base);
+ printf("wcstoumax = %ju\n", k);
+ printf("strtoumax = %ju (base %d)\n", j, base);
+ printf("Stopped scan at %s\n\n", endptr);
+ imaxdiv_t retrival = imaxdiv(27, 4);
+ printf(" Strtoimax values \n");
+ printf("%jd\n", strtoimax(" -123junk",&endptr,10)); /* base 10 */
+ printf("%jd\n", strtoimax("11111111",&endptr,2)); /* base 2 */
+ printf("%jd\n", strtoimax("XyZ",&endptr,36)); /* base 36 */
+ printf("%jd\n", strtoimax("010",&endptr,0)); /* octal auto-detection */
+ printf("%jd\n", strtoimax("10",&endptr,0)); /* decimal auto-detection */
+ printf("%jd\n", strtoimax("0x10",&endptr,0)); /* hexadecimal auto-detection */
+ printf( "imaxabs_value = %jd\n", imaxabs(-1234));
+ printf("strtoimax value = %jd\n", strtoimax("11111111",&endptr,2));
+ printf( "imax div value = %jd\n", retrival.rem);
+ rtems_test_end();
+ exit( 0 );
+/* NOTICE: the clock driver is explicitly disabled */
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#include <rtems/confdefs.h>
diff --git a/testsuites/samples/psxinttypes01/psxid01.doc b/testsuites/samples/psxinttypes01/psxid01.doc
index 0000000..a8ce42a
--- /dev/null
+++ b/testsuites/samples/psxinttypes01/psxid01.doc
@@ -0,0 +1,35 @@
+# COPYRIGHT (c) 1989-2010.
+# On-Line Applications Research Corporation (OAR).
+# The license and distribution terms for this file may be
+# found in the file LICENSE in this distribution or at
+# http://www.rtems.org/license/LICENSE.
+This file describes the directives and concepts tested by this test set.
+test set name: psxid01
+directives:
+ getegid
+ getgid
+ setgid
+ setpgid
+ geteuid
+ getuid
+ setuid
+ geteuid
+ getuid
+ getpid
+ __getpid
+ getppid
+ setsid
+ getpgrp
+ getgroups
+ getlogin
+ getlogin_r
+concepts:
++ Fully exercise the above listed methods
diff --git a/testsuites/samples/psxinttypes01/psxid01.scn b/testsuites/samples/psxinttypes01/psxid01.scn
index 0000000..e0ea2a0
--- /dev/null
+++ b/testsuites/samples/psxinttypes01/psxid01.scn
@@ -0,0 +1,38 @@
+*** BEGIN OF TEST PSXID 1 ***
+getegid = 0
+getgid = 0
+setgid(5)
+getegid = 0
+getgid = 5
+setegid(5)
+getegid = 5
+getgid = 5
+setgid(0)
+setegid(0)
+setpgid(getpid(), 10) - ENOSYS
+geteuid = 0
+getuid = 0
+setuid(5)
+geteuid = 0
+getuid = 5
+seteuid(5)
+geteuid = 5
+getuid = 5
+seteuid(0)
+setuid(0)
+getpid = 1
+__getpid = 1
+getppid = 0
+setsid - EPERM
+getpgrp - return local node - OK
+getpgrp returned 1
+setuid(5)
+getlogin() -- ()
+setuid(0)
+getlogin() -- (root)
+getlogin_r(NULL, LOGIN_NAME_MAX) -- EFAULT
+getlogin_r(buffer, 0) -- ERANGE
+*** END OF TEST PSXID 1 ***
2.7.4
