[rtems commit] bsp/motorola_powerpc: Fix for Binutils 2.28+
Fri Jun 2 05:16:12 UTC 2017
On 02/06/2017 15:11, Sebastian Huber wrote:
> Module:    rtems
> Branch:    master
> Commit:    7203b70be0266cdb4830537dfc8fd6189851708c
> Changeset: http://git.rtems.org/rtems/commit/?id=7203b70be0266cdb4830537dfc8fd6189851708c
> Author:    Sebastian Huber <sebastian.huber at embedded-brains.de>
> Date:      Thu Jun  1 19:04:05 2017 +0200
> There are mismatched sections in the bootloader input:
> ld: Warning: ticker.exe uses hard float, ticker.ralf uses soft float
> ld: ticker.exe: compiled normally and linked with modules compiled with -mrelocatable
> ld: failed to merge target specific data of file ticker.exe
> Suppress this error explicitly.
Thank you for fixing this. A binutils observation ...
Yes an error cause the build fails so ....
>  c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mcp750.cfg         | 1 +
>  c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mtx603e.cfg        | 1 +
>  c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mvme2100.cfg       | 1 +
>  c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mvme2307.cfg       | 1 +
>  .../lib/libbsp/powerpc/motorola_powerpc/make/custom/qemuprep-altivec.cfg | 1 +
>  c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/qemuprep.cfg       | 1 +
>  6 files changed, 6 insertions(+)
> diff --git a/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mcp750.cfg b/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mcp750.cfg
> index 98e8fd9..67d1766 100644
> --- a/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mcp750.cfg
> +++ b/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mcp750.cfg
> @@ -25,6 +25,7 @@ define bsp-post-link
>   	$(LD) -o $(basename $@)$(DOWNEXT) \
>  	    $ $(PROJECT_RELEASE)/lib/bootloader.o \
>  	    --just-symbols=$(basename $@)$(EXEEXT) \
> +	    --no-warn-mismatch \
... is this option poorly named because it is an error?
