Coverage tools project direction [GSOC]
Cillian O'Donnell
cpodonnell8 at gmail.com
Sat Jun 3 12:14:02 UTC 2017
Hi,
I've just realised that I've been fixing problems with the RTEMS
Tester work that has already been done to convert bash scripts to
python, but I probably should of first been trying to get the old
sim-scripts method working from rtems-testing repo because this will
give me more bsps to test qemu with. So I'm now trying to fix the
do_coverage runtime errors due to covoar and its related files being
moved to RTEMS Tester.
I just want to confirm if I'm heading in the right direction. First
get the old sim-scripts method working. Test qemu against
couverture-qemu for bsps common to both. Then do the RSB support for
couverture-qemu. Then get the RTEMS Tester work running and convert
the rest of the sim-scripts. Is that right, or should I continue with
the RTEMS Tester work?
Thanks,
Cillian.
