Building RISC-V BSP
Hesham Almatary heshamelmatary at gmail.com
Sun Jun 4 21:36:17 UTC 2017
Hi Denis,
Yes, I'm willing to fix these, just need time. Shouldn't be that difficult.
You can get more details on RISC-V assembly reading RISC-V specs
(especially user-level spec) [1]. For example/references, you may have
a look at the riscv-linux and/or seL4 ports [2, 3] (though, you've to
be aware of 64-bit vs 32-bit differences).
You shouldn't need to write lots of assembly code though.
[1] https://riscv.org/specifications/
[2] https://github.com/riscv/riscv-linux/tree/priv-1.10/arch/riscv/kernel
[3] https://github.com/heshamelmatary/seL4/tree/RISCVUnofficialRelease-03062017/src/arch/riscv
On Mon, Jun 5, 2017 at 7:21 AM, Denis Obrezkov <denisobrezkov at gmail.com> wrote:
> 2017-06-05 0:14 GMT+03:00 Hesham Almatary <heshamelmatary at gmail.com>:
>> Hi Denis,
>> Yes, the Host-Target-Interface (HTIF) has been refactored/removed in
>> RISC-V. Also, it was meant to work with riscv front-end server
>> (riscv-fesvr) which is not the case for your HiFive BSP I guess.
>> I believe now it's the good time for you to start creating your own
>> HiFive BSP. You'll have to read/know how to output data over the
>> HiFive serial port or so, and develop your own console driver for the
>> board. You might find this link useful [1] when creating a new BSP,
>> and also use other BSPs as a reference (e.g. riscv_generic). Main
>> things to be aware of when creating a new BSP are: 1) startup code, 2)
>> console driver, and 3) timer driver. To make things easier for you,
>> and to give you credit for your contributions when merged upstream,
>> you'd want to create a new branch for your HiFive BSP based on
>> priv-1.10, and rebase against it when/if I make changes to it.
>> Keep the good work up.
>> [1] https://devel.rtems.org/wiki/TBR/UserManual/Submitting_a_BSP
>> Best,
>> Hesham
>> On Mon, Jun 5, 2017 at 7:00 AM, Denis Obrezkov <denisobrezkov at gmail.com>
>> wrote:
>> > 2017-06-04 16:17 GMT+03:00 Denis Obrezkov <denisobrezkov at gmail.com>:
>> >> Now I have a problem with console-io.c file.
>> >> The problem is with csr macros - there is no more such a register
>> >> "tohost".
>> >> Here it is described a little:
>> >> https://github.com/riscv/riscv-pk/issues/25
>> >> Could you explain what should be done here and what for was mtohost
>> >> register?
>> > I have built riscv-generic bsp. Though there are a lot of warnings.
>> > The current issue is that asm functions should be reimplemented (there
>> > is no
>> > more
>> > such a register 'mtohost' in csr).
>> > Regards, Denis Obrezkov
>> Hesham
> Thanks Hasham,
> will you be able to fix these asm functions to make BSP work in SPIKE
> simulator?
> Could you also point me to the good reference on risc-v assembler and about
> assembler writing in general (for RISC) - I am not really good in it.
Hesham
