[PATCH v4 2/2] Add the i2c driver for Beaglebone Black
    Sichen Zhao
    1473996754 at qq.com
    Mon Jun  5 12:49:50 UTC 2017
Update ticket #2891 and my GSOC project
add c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
modify c/src/lib/libbsp/arm/beagle/include/i2c.h
modify c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h
modify c/src/lib/libcpu/arm/shared/include/am335x.h
modify c/src/lib/libbsp/arm/beagle/Makefile.am
Now can read the EEPROM by i2c, the test application link is: https://github.com/hahchenchen/GSOC-test-application
 c/src/lib/libbsp/arm/beagle/Makefile.am        |   1 +
 c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c      | 461 +++++++++++++++++++++++++
 c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h |   4 +-
 c/src/lib/libbsp/arm/beagle/include/i2c.h      | 304 ++++++++--------
 c/src/lib/libcpu/arm/shared/include/am335x.h   | 136 ++++++++
 5 files changed, 765 insertions(+), 141 deletions(-)
 create mode 100644 c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am b/c/src/lib/libbsp/arm/beagle/Makefile.am
index c14db49..8e10ee2 100644
--- a/c/src/lib/libbsp/arm/beagle/Makefile.am
+++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
@@ -114,6 +114,7 @@ libbsp_a_SOURCES += ../../shared/console.c \
         ../../shared/console_control.c
 # I2C
+libbsp_a_SOURCES += i2c/bbb-i2c.c
 # GPIO
 libbsp_a_SOURCES += gpio/bbb-gpio.c
diff --git a/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
new file mode 100644
index 0000000..3d7d820
--- /dev/null
+++ b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
@@ -0,0 +1,461 @@
+ * @file
+ * @ingroup arm_beagle
+ * @brief BeagleBoard I2C bus initialization and API Support.
+ * Copyright (c) 2017 Sichen Zhao <zsc19940506 at gmail.com>
+ * Modified on Punit Vara<punitvara at gmail.com> works, currently
+ * the i2c file is working on the Beaglebone Black board(AM335x)
+#include <stdio.h>
+#include <bsp/i2c.h>
+#include <libcpu/am335x.h>
+#include <rtems/irq-extension.h>
+#include <rtems/counter.h>
+#include <bsp/bbb-gpio.h>
+#include <rtems/score/assert.h>
+static void am335x_i2c0_pinmux( bbb_i2c_bus *bus )
+  REG( bus->regs + AM335X_CONF_I2C0_SDA ) =
+    ( BBB_RXACTIVE | BBB_SLEWCTRL | BBB_PU_EN );
+  REG( bus->regs + AM335X_CONF_I2C0_SCL ) =
+static void I2C0ModuleClkConfig( void )
+  /* Writing to MODULEMODE field of AM335X_CM_WKUP_I2C0_CLKCTRL register. */
+  REG( AM335X_SOC_CM_WKUP_REGS + AM335X_CM_WKUP_I2C0_CLKCTRL ) |=
+    AM335X_CM_WKUP_I2C0_CLKCTRL_MODULEMODE_ENABLE;
+  /* Waiting for MODULEMODE field to reflect the written value. */
+  while ( AM335X_CM_WKUP_I2C0_CLKCTRL_MODULEMODE_ENABLE !=
+          ( REG( AM335X_SOC_CM_WKUP_REGS + AM335X_CM_WKUP_I2C0_CLKCTRL ) &
+            AM335X_CM_WKUP_I2C0_CLKCTRL_MODULEMODE ) ) ;
+  ** Waiting for IDLEST field in AM335X_CM_WKUP_CONTROL_CLKCTRL
+  ** register to attain
+  ** desired value.
+  while ( ( AM335X_CM_WKUP_CONTROL_CLKCTRL_IDLEST_FUNC <<
+            AM335X_CM_WKUP_CONTROL_CLKCTRL_IDLEST_SHIFT ) !=
+          ( REG( AM335X_SOC_CM_WKUP_REGS + AM335X_CM_WKUP_CONTROL_CLKCTRL ) &
+            AM335X_CM_WKUP_CONTROL_CLKCTRL_IDLEST ) ) ;
+  ** Waiting for CLKACTIVITY_I2C0_GFCLK field in AM335X_CM_WKUP_CLKSTCTRL
+  ** register to attain desired value.
+  while ( AM335X_CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK !=
+          ( REG( AM335X_SOC_CM_WKUP_REGS + AM335X_CM_WKUP_CLKSTCTRL ) &
+            AM335X_CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK ) ) ;
+  ** Waiting for IDLEST field in AM335X_CM_WKUP_I2C0_CLKCTRL register to attain
+  ** desired value.
+  while ( ( AM335X_CM_WKUP_I2C0_CLKCTRL_IDLEST_FUNC <<
+            AM335X_CM_WKUP_I2C0_CLKCTRL_IDLEST_SHIFT ) !=
+            AM335X_CM_WKUP_I2C0_CLKCTRL_IDLEST ) ) ;
+static void am335x_i2c_reset( bbb_i2c_bus *bus )
+  volatile bbb_i2c_regs *regs = bus->regs;
+  int                    timeout = I2C_TIMEOUT;
+  if ( REG( ®s->BBB_I2C_CON ) & BBB_I2C_CON_EN ) {
+    REG( ®s->BBB_I2C_CON ) = BBB_I2C_CON_CLR;
+    udelay( 50000 );
+  REG( ®s->BBB_I2C_SYSC ) = BBB_I2C_SYSC_SRST; /* for ES2 after soft reset */
+  udelay( 1000 );
+  REG( ®s->BBB_I2C_CON ) = BBB_I2C_CON_EN;
+  while ( !( REG( ®s->BBB_I2C_SYSS ) & BBB_I2C_SYSS_RDONE ) && timeout-- ) {
+    if ( timeout <= 0 ) {
+      puts( "ERROR: Timeout in soft-reset\n" );
+      return;
+    udelay( 1000 );
+   Possible values for msg->flag
+ * - @ref I2C_M_TEN,
+ * - @ref I2C_M_RD,
+ * - @ref I2C_M_STOP,
+ * - @ref I2C_M_NOSTART,
+ * - @ref I2C_M_REV_DIR_ADDR,
+ * - @ref I2C_M_IGNORE_NAK,
+ * - @ref I2C_M_NO_RD_ACK, and
+ * - @ref I2C_M_RECV_LEN.
+static void am335x_i2c_set_address_size(
+  const i2c_msg         *msgs,
+  /*can be configured multiple modes here.
+   **Need to think about own address modes*/
+  if ( ( msgs->flags & I2C_M_TEN ) == 0 ) {
+    /* 7-bit mode slave address mode*/
+    REG( ®s->BBB_I2C_CON ) = AM335X_I2C_CFG_7BIT_SLAVE_ADDR;
+  } else {
+    /* 10-bit slave address mode*/
+    REG( ®s->BBB_I2C_CON ) = AM335X_I2C_CFG_10BIT_SLAVE_ADDR;
+static void am335x_i2c_next_byte( bbb_i2c_bus *bus )
+  i2c_msg *msg;
+  ++bus->msgs;
+  --bus->msg_todo;
+  msg = &bus->msgs[ 0 ];
+  bus->current_msg_todo = msg->len;
+  bus->current_msg_byte = msg->buf;
+static void am335x_i2c_masterint_enable(
+  volatile bbb_i2c_regs *regs,
+  unsigned int           flag
+  REG( ®s->BBB_I2C_IRQENABLE_SET ) |= flag;
+static void am335x_i2c_masterint_disable(
+  unsigned int           flag
+  REG( ®s->BBB_I2C_IRQENABLE_CLR ) = flag;
+static void am335x_int_clear(
+  unsigned int           flag
+  REG( ®s->BBB_I2C_IRQSTATUS ) = flag;
+static void am335x_clean_interrupts( volatile bbb_i2c_regs *regs )
+  am335x_i2c_masterint_enable( regs, BBB_I2C_ALL_FLAGS );
+  am335x_int_clear( regs, BBB_I2C_ALL_FLAGS );
+  am335x_i2c_masterint_disable( regs, BBB_I2C_ALL_FLAGS );
+static void am335x_i2c_setup_read_transfer(
+  bbb_i2c_bus           *bus,
+  bool                   send_stop
+  REG( ®s->BBB_I2C_CNT ) = bus->current_msg_todo;
+  REG( ®s->BBB_I2C_CON ) = AM335X_I2C_CFG_MST_RX | AM335X_I2C_CON_I2C_EN;
+  if ( send_stop ) {
+    REG( ®s->BBB_I2C_CON ) |= AM335X_I2C_CON_START | AM335X_I2C_CON_STOP;
+  } else {
+    REG( ®s->BBB_I2C_CON ) |= AM335X_I2C_CON_START;
+  am335x_i2c_masterint_enable( regs, AM335X_I2C_INT_RECV_READY |
+    AM335X_I2C_IRQSTATUS_ARDY );
+static void am335x_i2c_continue_read_transfer(
+  bbb_i2c_bus           *bus,
+  bus->current_msg_byte[ bus->already_transferred ] =
+    REG( ®s->BBB_I2C_DATA );
+  bus->already_transferred++;
+  REG( ®s->BBB_I2C_IRQSTATUS ) = AM335X_I2C_INT_RECV_READY;
+  if ( bus->already_transferred == bus->current_msg_todo - 1 ) {
+    REG( ®s->BBB_I2C_CON ) |= AM335X_I2C_CON_STOP;
+static void am335x_i2c_continue_write(
+  bbb_i2c_bus           *bus,
+  if ( bus->already_transferred == bus->msg_todo ) {
+    REG( ®s->BBB_I2C_DATA ) =
+      bus->current_msg_byte[ bus->already_transferred ];
+    REG( ®s->BBB_I2C_IRQSTATUS ) = AM335X_I2C_IRQSTATUS_XRDY;
+    am335x_i2c_masterint_disable( regs, AM335X_I2C_IRQSTATUS_XRDY );
+  } else {
+    writeb( bus->current_msg_byte[ bus->already_transferred ],
+      ®s->BBB_I2C_DATA );
+static void am335x_i2c_setup_write_transfer(
+  bbb_i2c_bus           *bus,
+  volatile unsigned int no_bytes;
+  no_bytes = REG( ®s->BBB_I2C_CNT );
+  REG( ®s->BBB_I2C_SA ) = msgs->addr;
+  REG( ®s->BBB_I2C_CON ) = AM335X_I2C_CFG_MST_TX | AM335X_I2C_CON_I2C_EN;
+  am335x_clean_interrupts( regs );
+  am335x_i2c_masterint_enable( regs, AM335X_I2C_IRQSTATUS_XRDY );
+static void am335x_i2c_setup_transfer(
+  bbb_i2c_bus           *bus,
+  const i2c_msg *msgs = bus->msgs;
+  uint32_t       msg_todo = bus->msg_todo;
+  bool           send_stop = false;
+  uint32_t       i;
+  bus->current_todo = msgs[ 0 ].len;
+  for ( i = 1; i < msg_todo && ( msgs[ i ].flags & I2C_M_NOSTART ) != 0;
+        ++i ) {
+    bus->current_todo += msgs[ i ].len;
+  regs = bus->regs;
+  REG( &bus->regs->BBB_I2C_BUF ) |= AM335X_I2C_BUF_TXFIFO_CLR;
+  REG( &bus->regs->BBB_I2C_BUF ) |= AM335X_I2C_BUF_RXFIFO_CLR;
+  am335x_i2c_set_address_size( msgs, regs );
+  bus->read = ( msgs->flags & I2C_M_RD ) != 0;
+  bus->already_transferred = ( bus->read == true ) ? 0 : 1;
+  if ( bus->read ) {
+    if ( bus->current_msg_todo == 1 ) {
+      send_stop = true;
+    am335x_i2c_setup_read_transfer( bus, regs, msgs, send_stop );
+  } else {
+    am335x_i2c_setup_write_transfer( bus, regs, msgs );
+static void am335x_i2c_interrupt( void *arg )
+  bbb_i2c_bus           *bus = arg;
+  /* get status of enabled interrupts */
+  uint32_t irqstatus = REG( ®s->BBB_I2C_IRQSTATUS );
+  bool     done = false;
+  /* Clear all enabled interrupt except receive ready
+     and transmit ready interrupt in status register */
+    ( irqstatus & ~( AM335X_I2C_IRQSTATUS_RRDY |
+                     AM335X_I2C_IRQSTATUS_XRDY ) );
+  if ( irqstatus & AM335X_I2C_INT_RECV_READY ) {
+    am335x_i2c_continue_read_transfer( bus, regs );
+  if ( irqstatus & AM335X_I2C_IRQSTATUS_XRDY ) {
+    am335x_i2c_continue_write( bus, regs );
+  if ( irqstatus & AM335X_I2C_IRQSTATUS_NACK ) {
+    done = true;
+    am335x_i2c_masterint_disable( regs, AM335X_I2C_IRQSTATUS_NACK );
+  if ( irqstatus & AM335X_I2C_IRQSTATUS_ARDY ) {
+    done = true;
+    REG( ®s->BBB_I2C_IRQSTATUS ) = BBB_I2C_STAT_ARDY;
+  if ( irqstatus & AM335X_I2C_IRQSTATUS_BF ) {
+    REG( ®s->BBB_I2C_IRQSTATUS ) = AM335X_I2C_IRQSTATUS_BF;
+  if ( done ) {
+    uint32_t err = irqstatus & BBB_I2C_IRQ_ERROR;
+    am335x_i2c_next_byte( bus );
+    if ( bus->msg_todo == 0 ) {
+      rtems_status_code sc;
+      am335x_i2c_masterint_disable( regs, ( AM335X_I2C_IRQSTATUS_RRDY |
+                                            AM335X_I2C_IRQSTATUS_XRDY |
+                                            AM335X_I2C_IRQSTATUS_BF ) );
+      REG( ®s->BBB_I2C_IRQSTATUS ) = err;
+      sc = rtems_event_transient_send( bus->task_id );
+      _Assert( sc == RTEMS_SUCCESSFUL );
+      (void) sc;
+    } else {
+      am335x_i2c_setup_transfer( bus, regs );
+static int am335x_i2c_transfer(
+  i2c_bus *base,
+  i2c_msg *msgs,
+  uint32_t msg_count
+  bbb_i2c_bus           *bus = (bbb_i2c_bus *) base;
+  volatile bbb_i2c_regs *regs;
+  uint32_t               i;
+  rtems_task_wake_after( 1 );
+  if ( msg_count < 1 ) {
+    return 1;
+  for ( i = 0; i < msg_count; ++i ) {
+    if ( ( msgs[ i ].flags & I2C_M_RECV_LEN ) != 0 ) {
+      return -EINVAL;
+  bus->msgs = &msgs[ 0 ];
+  bus->msg_todo = msg_count;
+  bus->current_msg_todo = msgs[ 0 ].len;
+  bus->current_msg_byte = msgs[ 0 ].buf;
+  bus->task_id = rtems_task_self();
+  regs = bus->regs;
+  REG( ®s->BBB_I2C_IRQENABLE_SET ) = BBB_I2C_IRQ_USED;
+  sc = rtems_event_transient_receive( RTEMS_WAIT, bus->base.timeout );
+  if ( sc != RTEMS_SUCCESSFUL ) {
+    am335x_i2c_reset( bus );
+    rtems_event_transient_clear();
+    return -ETIMEDOUT;
+  return 0;
+static int am335x_i2c_set_clock(
+  i2c_bus      *base,
+  unsigned long clock
+  uint32_t               prescaler, divider;
+  prescaler = ( BBB_I2C_SYSCLK / BBB_I2C_INTERNAL_CLK ) - 1;
+  REG( &bus->regs->BBB_I2C_PSC ) = prescaler;
+  divider = BBB_I2C_INTERNAL_CLK / ( 2 * clock );
+  REG( &bus->regs->BBB_I2C_SCLL ) = ( divider - 7 );
+  REG( &bus->regs->BBB_I2C_SCLH ) = ( divider - 5 );
+  return 0;
+static void am335x_i2c_destroy( i2c_bus *base )
+  sc = rtems_interrupt_handler_remove( bus->irq, am335x_i2c_interrupt, bus );
+  (void) sc;
+  i2c_bus_destroy_and_free( &bus->base );
+int am335x_i2c_bus_register(
+  const char         *bus_path,
+  uintptr_t           register_base,
+  uint32_t            input_clock,
+  rtems_vector_number irq
+  bbb_i2c_bus      *bus;
+  int               err;
+  /*check bus number is >0 & <MAX*/
+  bus = (bbb_i2c_bus *) i2c_bus_alloc_and_init( sizeof( *bus ) );
+  if ( bus == NULL ) {
+    return -1;
+  bus->regs = (volatile bbb_i2c_regs *) register_base;
+  I2C0ModuleClkConfig();
+  am335x_i2c0_pinmux( bus );
+  bus->input_clock = input_clock;
+  err = am335x_i2c_set_clock( &bus->base, I2C_BUS_CLOCK_DEFAULT );
+  if ( err != 0 ) {
+    ( *bus->base.destroy )( &bus->base );
+    rtems_set_errno_and_return_minus_one( -err );
+  bus->irq = irq;
+  REG( &bus->regs->BBB_I2C_IRQSTATUS ) = BBB_I2C_ALL_IRQ_FLAGS;
+  sc = rtems_interrupt_handler_install(
+    irq,
+    "BBB_I2C",
+    RTEMS_INTERRUPT_UNIQUE,
+    (rtems_interrupt_handler) am335x_i2c_interrupt,
+    bus
+    rtems_set_errno_and_return_minus_one( EIO );
+  bus->base.transfer = am335x_i2c_transfer;
+  bus->base.set_clock = am335x_i2c_set_clock;
+  bus->base.destroy = am335x_i2c_destroy;
+  return i2c_bus_register( &bus->base, bus_path );
\ No newline at end of file
diff --git a/c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h b/c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h
index 8cce556..ceb12a4 100644
--- a/c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h
+++ b/c/src/lib/libbsp/arm/beagle/include/bbb-gpio.h
@@ -35,9 +35,11 @@ extern "C" {
 #define BBB_PU_EN (1 << 4)
 #define BBB_PD_EN ~BBB_PU_EN
 #define BBB_MUXMODE(X) (X & 0x7)
+#define BBB_RXACTIVE (1 << 5)
+#define BBB_SLEWCTRL (1 << 6)
 #ifdef __cplusplus
 #endif /* __cplusplus */
-#endif /* LIBBSP_ARM_BEAGLE_BBB_GPIO_H */
+#endif /* LIBBSP_ARM_BEAGLE_BBB_GPIO_H */
diff --git a/c/src/lib/libbsp/arm/beagle/include/i2c.h b/c/src/lib/libbsp/arm/beagle/include/i2c.h
index 010fcee..3ada3c4 100644
--- a/c/src/lib/libbsp/arm/beagle/include/i2c.h
+++ b/c/src/lib/libbsp/arm/beagle/include/i2c.h
@@ -24,7 +24,7 @@
 #define LIBBSP_ARM_BEAGLE_I2C_H
+#include <dev/i2c/i2c.h>
 #include <bsp.h>
 #ifdef __cplusplus
@@ -34,151 +34,175 @@ extern "C" {
 /* I2C Configuration Register (I2C_CON): */
-#define I2C_CON_EN  (1 << 15)  /* I2C module enable */
-#define I2C_CON_BE  (1 << 14)  /* Big endian mode */
-#define I2C_CON_STB (1 << 11)  /* Start byte mode (master mode only) */
-#define I2C_CON_MST (1 << 10)  /* Master/slave mode */
-#define I2C_CON_TRX (1 << 9)   /* Transmitter/receiver mode */
+#define BBB_I2C_CON_EN  (1 << 15)  /* I2C module enable */
+#define BBB_I2C_CON_BE  (1 << 14)  /* Big endian mode */
+#define BBB_I2C_CON_STB (1 << 11)  /* Start byte mode (master mode only) */
+#define BBB_I2C_CON_MST (1 << 10)  /* Master/slave mode */
+#define BBB_I2C_CON_TRX (1 << 9)   /* Transmitter/receiver mode */
            /* (master mode only) */
-#define I2C_CON_XA  (1 << 8)   /* Expand address */
-#define I2C_CON_STP (1 << 1)   /* Stop condition (master mode only) */
-#define I2C_CON_STT (1 << 0)   /* Start condition (master mode only) */
+#define BBB_I2C_CON_XA  (1 << 8)   /* Expand address */
+#define BBB_I2C_CON_STP (1 << 1)   /* Stop condition (master mode only) */
+#define BBB_I2C_CON_STT (1 << 0)   /* Start condition (master mode only) */
+#define BBB_I2C_CON_CLR 0x0  /* Clear configuration register */
 /* I2C Status Register (I2C_STAT): */
-#define I2C_STAT_SBD  (1 << 15) /* Single byte data */
-#define I2C_STAT_BB (1 << 12) /* Bus busy */
-#define I2C_STAT_ROVR (1 << 11) /* Receive overrun */
-#define I2C_STAT_XUDF (1 << 10) /* Transmit underflow */
-#define I2C_STAT_AAS  (1 << 9)  /* Address as slave */
-#define I2C_STAT_GC (1 << 5)
-#define I2C_STAT_XRDY (1 << 4)  /* Transmit data ready */
-#define I2C_STAT_RRDY (1 << 3)  /* Receive data ready */
-#define I2C_STAT_ARDY (1 << 2)  /* Register access ready */
-#define I2C_STAT_NACK (1 << 1)  /* No acknowledgment interrupt enable */
-#define I2C_STAT_AL (1 << 0)  /* Arbitration lost interrupt enable */
+#define BBB_I2C_STAT_SBD  (1 << 15) /* Single byte data */
+#define BBB_I2C_STAT_BB (1 << 12) /* Bus busy */
+#define BBB_I2C_STAT_ROVR (1 << 11) /* Receive overrun */
+#define BBB_I2C_STAT_XUDF (1 << 10) /* Transmit underflow */
+#define BBB_I2C_STAT_AAS  (1 << 9)  /* Address as slave */
+#define BBB_I2C_STAT_GC (1 << 5)
+#define BBB_I2C_STAT_XRDY (1 << 4)  /* Transmit data ready */
+#define BBB_I2C_STAT_RRDY (1 << 3)  /* Receive data ready */
+#define BBB_I2C_STAT_ARDY (1 << 2)  /* Register access ready */
+#define BBB_I2C_STAT_NACK (1 << 1)  /* No acknowledgment interrupt enable */
+#define BBB_I2C_STAT_AL (1 << 0)  /* Arbitration lost interrupt enable */
 /* I2C Interrupt Enable Register (I2C_IE): */
-#define I2C_IE_GC_IE  (1 << 5)
-#define I2C_IE_XRDY_IE  (1 << 4) /* Transmit data ready interrupt enable */
-#define I2C_IE_RRDY_IE  (1 << 3) /* Receive data ready interrupt enable */
-#define I2C_IE_ARDY_IE  (1 << 2) /* Register access ready interrupt enable */
-#define I2C_IE_NACK_IE  (1 << 1) /* No acknowledgment interrupt enable */
-#define I2C_IE_AL_IE  (1 << 0) /* Arbitration lost interrupt enable */
- * The equation for the low and high time is
- * tlow = scll + scll_trim = (sampling clock * tlow_duty) / speed
- * thigh = sclh + sclh_trim = (sampling clock * (1 - tlow_duty)) / speed
- * If the duty cycle is 50%
- * tlow = scll + scll_trim = sampling clock / (2 * speed)
- * thigh = sclh + sclh_trim = sampling clock / (2 * speed)
- * In TRM
- * scll_trim = 7
- * sclh_trim = 5
- * The linux 2.6.30 kernel uses
- * scll_trim = 6
- * sclh_trim = 6
- * These are the trim values for standard and fast speed
-#ifndef I2C_FASTSPEED_SCLL_TRIM
-#define I2C_FASTSPEED_SCLL_TRIM   6
-#endif
-#ifndef I2C_FASTSPEED_SCLH_TRIM
-#define I2C_FASTSPEED_SCLH_TRIM   6
-#endif
-/* These are the trim values for high speed */
-#ifndef I2C_HIGHSPEED_PHASE_ONE_SCLL_TRIM
-#define I2C_HIGHSPEED_PHASE_ONE_SCLL_TRIM I2C_FASTSPEED_SCLL_TRIM
-#endif
-#ifndef I2C_HIGHSPEED_PHASE_ONE_SCLH_TRIM
-#define I2C_HIGHSPEED_PHASE_ONE_SCLH_TRIM I2C_FASTSPEED_SCLH_TRIM
-#endif
-#ifndef I2C_HIGHSPEED_PHASE_TWO_SCLL_TRIM
-#define I2C_HIGHSPEED_PHASE_TWO_SCLL_TRIM I2C_FASTSPEED_SCLL_TRIM
-#endif
-#ifndef I2C_HIGHSPEED_PHASE_TWO_SCLH_TRIM
-#define I2C_HIGHSPEED_PHASE_TWO_SCLH_TRIM I2C_FASTSPEED_SCLH_TRIM
-#endif
-#define OMAP_I2C_STANDARD 100000
-#define OMAP_I2C_FAST_MODE  400000
-#define OMAP_I2C_HIGH_SPEED 3400000
-/* Use the reference value of 96MHz if not explicitly set by the board */
-#ifndef I2C_IP_CLK
-#define I2C_IP_CLK    SYSTEM_CLOCK_96
-#endif
+#define BBB_I2C_IE_GC_IE  (1 << 5)
+#define BBB_I2C_IE_XRDY_IE  (1 << 4) /* Transmit data ready interrupt enable */
+#define BBB_I2C_IE_RRDY_IE  (1 << 3) /* Receive data ready interrupt enable */
+#define BBB_I2C_IE_ARDY_IE  (1 << 2) /* Register access ready interrupt enable */
+#define BBB_I2C_IE_NACK_IE  (1 << 1) /* No acknowledgment interrupt enable */
+#define BBB_I2C_IE_AL_IE  (1 << 0) /* Arbitration lost interrupt enable */
+/* I2C SYSC Register (I2C_SYSC): */
+#define BBB_I2C_SYSC_SRST (1 << 1)
+#define BBB_I2C_TIMEOUT 1000
+#define BBB_I2C_SYSS_RDONE            (1 << 0)  /* Internel reset monitoring */
+#define BBB_CONFIG_SYS_I2C_SPEED    100000
+#define BBB_CONFIG_SYS_I2C_SLAVE    1
+#define BBB_I2C_ALL_FLAGS 0x7FFF
+#define BBB_I2C_ALL_IRQ_FLAGS 0xFFFF
+#define BBB_I2C_SYSCLK 48000000
+#define BBB_I2C_INTERNAL_CLK 12000000
+#define BBB_I2C_SPEED_CLK 100000
+#define BBB_I2C_IRQ_ERROR \
+  ( AM335X_I2C_IRQSTATUS_NACK \
+    | AM335X_I2C_IRQSTATUS_ROVR \
+    | AM335X_I2C_IRQSTATUS_AL \
+    | AM335X_I2C_IRQSTATUS_ARDY \
+    | AM335X_I2C_IRQSTATUS_RRDY \
+    | AM335X_I2C_IRQSTATUS_XRDY \
+    | AM335X_I2C_IRQSTATUS_XUDF )
+#define BBB_I2C_IRQ_USED \
+  ( AM335X_I2C_IRQSTATUS_ARDY \
+    | AM335X_I2C_IRQSTATUS_XRDY )
+#define BBB_I2C_0_BUS_PATH "/dev/i2c-0"
+#define BBB_I2C_1_BUS_PATH "/dev/i2c-1"
+#define BBB_I2C_2_BUS_PATH "/dev/i2c-2"
+#define BBB_I2C0_IRQ 70
+#define BBB_I2C1_IRQ 71
+#define BBB_I2C2_IRQ 30
+#define BBB_MODE2 2
+#define BBB_MODE3 3
+typedef enum {
+  I2C0,
+  I2C1,
+  I2C2,
+  I2C_COUNT
+} bbb_i2c_id_t;
+typedef struct i2c_regs {
+  uint32_t BBB_I2C_REVNB_LO;
+  uint32_t BBB_I2C_REVNB_HI;
+  uint32_t dummy1[ 2 ];
+  uint32_t BBB_I2C_SYSC;
+  uint32_t dummy2[ 4 ];
+  uint32_t BBB_I2C_IRQSTATUS_RAW;
+  uint32_t BBB_I2C_IRQSTATUS;
+  uint32_t BBB_I2C_IRQENABLE_SET;
+  uint32_t BBB_I2C_IRQENABLE_CLR;
+  uint32_t BBB_I2C_WE;
+  uint32_t BBB_I2C_DMARXENABLE_SET;
+  uint32_t BBB_I2C_DMATXENABLE_SET;
+  uint32_t BBB_I2C_DMARXENABLE_CLR;
+  uint32_t BBB_I2C_DMATXENABLE_CLR;
+  uint32_t BBB_I2C_DMARXWAKE_EN;
+  uint32_t BBB_I2C_DMATXWAKE_EN;
+  uint32_t dummy3[ 16 ];
+  uint32_t BBB_I2C_SYSS;
+  uint32_t BBB_I2C_BUF;
+  uint32_t BBB_I2C_CNT;
+  uint32_t BBB_I2C_DATA;
+  uint32_t dummy4;
+  uint32_t BBB_I2C_CON;
+  uint32_t BBB_I2C_OA;
+  uint32_t BBB_I2C_SA;
+  uint32_t BBB_I2C_PSC;
+  uint32_t BBB_I2C_SCLL;
+  uint32_t BBB_I2C_SCLH;
+  uint32_t BBB_I2C_SYSTEST;
+  uint32_t BBB_I2C_BUFSTAT;
+  uint32_t BBB_I2C_OA1;
+  uint32_t BBB_I2C_OA2;
+  uint32_t BBB_I2C_OA3;
+  uint32_t BBB_I2C_ACTOA;
+  uint32_t BBB_I2C_SBLOCK;
+} bbb_i2c_regs;
+typedef struct bbb_i2c_bus {
+  i2c_bus base;
+  i2c_msg *msgs;
+  uint32_t msg_todo;
+  uint32_t current_msg_todo;
+  uint8_t *current_msg_byte;
+  uint32_t current_todo;
+  bool read;
+  bool hold;
+  rtems_id task_id;
+  rtems_vector_number irq;
+  uint32_t input_clock;
+  uint32_t already_transferred;
+} bbb_i2c_bus;
+static inline int bbb_register_i2c_0( void )
+  return am335x_i2c_bus_register(
+    BBB_I2C_0_BUS_PATH,
+    AM335X_I2C0_BASE,
+    I2C_BUS_CLOCK_DEFAULT,
+    BBB_I2C0_IRQ
- * The reference minimum clock for high speed is 19.2MHz.
- * The linux 2.6.30 kernel uses this value.
- * The reference minimum clock for fast mode is 9.6MHz
- * The reference minimum clock for standard mode is 4MHz
- * In TRM, the value of 12MHz is used.
-#ifndef I2C_INTERNAL_SAMPLING_CLK
-#define I2C_INTERNAL_SAMPLING_CLK 19200000
-#endif
-#define I2C_PSC_MAX   0x0f
-#define I2C_PSC_MIN   0x00
-#define DISP_LINE_LEN 128
-#define I2C_TIMEOUT 1000
-#define I2C_BUS_MAX 3
-#define I2C_BASE1         (OMAP34XX_CORE_L4_IO_BASE + 0x070000)
-#define I2C_DEFAULT_BASE      I2C_BASE1
-#define I2C_SYSS_RDONE            (1 << 0)  /* Internel reset monitoring */
-#define CONFIG_SYS_I2C_SPEED    100000
-#define CONFIG_SYS_I2C_SLAVE    1
-struct i2c {
-  unsigned short rev;   /* 0x00 */
-  unsigned short res1;
-  unsigned short ie;    /* 0x04 */
-  unsigned short res2;
-  unsigned short stat;  /* 0x08 */
-  unsigned short res3;
-  unsigned short iv;    /* 0x0C */
-  unsigned short res4;
-  unsigned short syss;  /* 0x10 */
-  unsigned short res4a;
-  unsigned short buf;   /* 0x14 */
-  unsigned short res5;
-  unsigned short cnt;   /* 0x18 */
-  unsigned short res6;
-  unsigned short data;  /* 0x1C */
-  unsigned short res7;
-  unsigned short sysc;  /* 0x20 */
-  unsigned short res8;
-  unsigned short con;   /* 0x24 */
-  unsigned short res9;
-  unsigned short oa;    /* 0x28 */
-  unsigned short res10;
-  unsigned short sa;    /* 0x2C */
-  unsigned short res11;
-  unsigned short psc;   /* 0x30 */
-  unsigned short res12;
-  unsigned short scll;  /* 0x34 */
-  unsigned short res13;
-  unsigned short sclh;  /* 0x38 */
-  unsigned short res14;
-  unsigned short systest; /* 0x3c */
-  unsigned short res15;
+static inline int bbb_register_i2c_1( void )
+    BBB_I2C_1_BUS_PATH,
+    AM335X_I2C1_BASE,
+    BBB_I2C1_IRQ
+static inline int bbb_register_i2c_2( void )
+    BBB_I2C_2_BUS_PATH,
+    AM335X_I2C2_BASE,
+    BBB_I2C2_IRQ
 #ifdef __cplusplus
diff --git a/c/src/lib/libcpu/arm/shared/include/am335x.h b/c/src/lib/libcpu/arm/shared/include/am335x.h
index f59f896..c29ae6c 100644
--- a/c/src/lib/libcpu/arm/shared/include/am335x.h
+++ b/c/src/lib/libcpu/arm/shared/include/am335x.h
@@ -563,3 +563,139 @@
+/* I2C registers */
+#define AM335X_I2C0_BASE 0x44e0b000
+    /* I2C0 base address */
+#define AM335X_I2C1_BASE 0x4802a000
+    /* I2C1 base address */
+#define AM335X_I2C2_BASE 0x4819c000
+    /* I2C2 base address */
+#define AM335X_I2C_REVNB_LO        0x00
+    /* Module Revision Register (low bytes) */
+#define AM335X_I2C_REVNB_HI        0x04
+    /* Module Revision Register (high bytes) */
+#define AM335X_I2C_SYSC            0x10
+    /* System Configuration Register */
+#define AM335X_I2C_IRQSTATUS_RAW   0x24
+    /* I2C Status Raw Register */
+#define AM335X_I2C_IRQSTATUS       0x28
+    /* I2C Status Register */
+#define AM335X_I2C_IRQENABLE_SET   0x2c
+    /* I2C Interrupt Enable Set Register */
+#define AM335X_I2C_IRQENABLE_CLR   0x30
+    /* I2C Interrupt Enable Clear Register */
+#define AM335X_I2C_WE              0x34
+    /* I2C Wakeup Enable Register */
+#define AM335X_I2C_DMARXENABLE_SET 0x38
+    /* Receive DMA Enable Set Register */
+#define AM335X_I2C_DMATXENABLE_SET 0x3c
+    /* Transmit DMA Enable Set Register */
+#define AM335X_I2C_DMARXENABLE_CLR 0x40
+    /* Receive DMA Enable Clear Register */
+#define AM335X_I2C_DMATXENABLE_CLR 0x44
+    /* Transmit DMA Enable Clear Register */
+#define AM335X_I2C_DMARXWAKE_EN    0x48
+    /* Receive DMA Wakeup Register */
+#define AM335X_I2C_DMATXWAKE_EN    0x4c
+    /* Transmit DMA Wakeup Register */
+#define AM335X_I2C_SYSS            0x90
+    /* System Status Register */
+#define AM335X_I2C_BUF             0x94
+    /* Buffer Configuration Register */
+#define AM335X_I2C_CNT             0x98
+    /* Data Counter Register */
+#define AM335X_I2C_DATA            0x9c
+    /* Data Access Register */
+#define AM335X_I2C_CON             0xa4
+    /* I2C Configuration Register */
+#define AM335X_I2C_OA              0xa8
+    /* I2C Own Address Register */
+#define AM335X_I2C_SA              0xac
+    /* I2C Slave Address Register */
+#define AM335X_I2C_PSC             0xb0
+    /* I2C Clock Prescaler Register */
+#define AM335X_I2C_SCLL            0xb4
+    /* I2C SCL Low Time Register */
+#define AM335X_I2C_SCLH            0xb8
+    /* I2C SCL High Time Register */
+#define AM335X_I2C_SYSTEST         0xbc
+    /* System Test Register */
+#define AM335X_I2C_BUFSTAT         0xc0
+    /* I2C Buffer Status Register */
+#define AM335X_I2C_OA1             0xc4
+    /* I2C Own Address 1 Register */
+#define AM335X_I2C_OA2             0xc8
+    /* I2C Own Address 2 Register */
+#define AM335X_I2C_OA3             0xcc
+    /* I2C Own Address 3 Register */
+#define AM335X_I2C_ACTOA           0xd0
+    /* Active Own Address Register */
+#define AM335X_I2C_SBLOCK          0xd4
+    /* I2C Clock Blocking Enable Register */
+#define AM335X_CM_PER_L4LS_CLKSTCTRL  (0x0)
+#define AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP  (0x2u)
+#define AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL  (0x00000003u)
+#define AM335X_CM_PER_L4LS_CLKCTRL  (0x60)
+#define AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE  (0x2u)
+#define AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE  (0x00000003u)
+#define AM335X_CM_PER_I2C1_CLKCTRL  (0x48)
+#define AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE  (0x2u)
+#define AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE  (0x00000003u)
+#define AM335X_CM_PER_I2C2_CLKCTRL (0x44)
+#define AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE_ENABLE  (0x2u)
+#define AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE  (0x00000003u)
+#define AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK (0x00000100u)
+#define AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_I2C_FCLK (0x01000000u)
+#define AM335X_I2C_CON_XSA  (0x00000100u)
+#define AM335X_I2C_CFG_10BIT_SLAVE_ADDR  AM335X_I2C_CON_XSA
+#define AM335X_I2C_CON_XSA_SHIFT  (0x00000008u)
+#define AM335X_I2C_CFG_7BIT_SLAVE_ADDR  (0 << AM335X_I2C_CON_XSA_SHIFT)
+#define AM335X_I2C_CON_I2C_EN   (0x00008000u)
+#define AM335X_I2C_CON_TRX   (0x00000200u)
+#define AM335X_I2C_CON_MST   (0x00000400u)
+#define AM335X_I2C_CON_STB   (0x00000800u)
+#define AM335X_I2C_SYSC_AUTOIDLE   (0x00000001u)
+/*I2C0 module clock registers*/
+#define AM335X_CM_WKUP_CONTROL_CLKCTRL   (0x4)
+#define AM335X_CM_WKUP_CLKSTCTRL   (0x0)
+#define AM335X_CM_WKUP_I2C0_CLKCTRL   (0xb8)
+#define AM335X_CM_WKUP_I2C0_CLKCTRL_MODULEMODE_ENABLE   (0x2u)
+#define AM335X_CM_WKUP_I2C0_CLKCTRL_MODULEMODE   (0x00000003u)
+#define AM335X_CM_WKUP_CONTROL_CLKCTRL_IDLEST_FUNC   (0x0u)
+#define AM335X_CM_WKUP_CONTROL_CLKCTRL_IDLEST_SHIFT   (0x00000010u)
+#define AM335X_CM_WKUP_CONTROL_CLKCTRL_IDLEST   (0x00030000u)
+#define AM335X_CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK   (0x00000800u)
+#define AM335X_CM_WKUP_I2C0_CLKCTRL_IDLEST_FUNC   (0x0u)
+#define AM335X_CM_WKUP_I2C0_CLKCTRL_IDLEST_SHIFT   (0x00000010u)
+#define AM335X_CM_WKUP_I2C0_CLKCTRL_IDLEST   (0x00030000u)
+#define AM335X_SOC_CM_WKUP_REGS                     (AM335X_CM_PER_ADDR + 0x400)
+/* I2C status Register */
+#define AM335X_I2C_IRQSTATUS_NACK (1 << 1)
+#define AM335X_I2C_IRQSTATUS_ROVR (1 << 11)
+#define AM335X_I2C_IRQSTATUS_AL   (1<<0)
+#define AM335X_I2C_IRQSTATUS_ARDY (1 << 2)
+#define AM335X_I2C_IRQSTATUS_RRDY (1 << 3)
+#define AM335X_I2C_IRQSTATUS_XRDY (1 << 4)
+#define AM335X_I2C_IRQSTATUS_XUDF (1 << 10)
+#define AM335X_I2C_BUF_TXFIFO_CLR   (0x00000040u)
+#define AM335X_I2C_BUF_RXFIFO_CLR   (0x00004000u)
+#define AM335X_I2C_IRQSTATUS_AAS  (1 << 9)
+#define AM335X_I2C_IRQSTATUS_BF  (1 << 8)
+#define AM335X_I2C_IRQSTATUS_STC  (1 << 6)
+#define AM335X_I2C_IRQSTATUS_GC (1 << 5)
+#define AM335X_I2C_IRQSTATUS_XDR (1 << 14)
+#define AM335X_I2C_IRQSTATUS_RDR (1 << 13)
+#define AM335X_I2C_INT_RECV_READY AM335X_I2C_IRQSTATUS_RRDY
+#define AM335X_I2C_CON_STOP  (0x00000002u)
+#define AM335X_I2C_CON_START (0x00000001u)
+#define AM335X_I2C_CFG_MST_RX AM335X_I2C_CON_MST
+#define AM335X_I2C_CFG_MST_TX  (AM335X_I2C_CON_TRX | AM335X_I2C_CON_MST)
+#define AM335X_I2C_IRQSTATUS_RAW_BB   (0x00001000u)
+#define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L4_GCLK (0x00000020u)
+#define AM335X_I2C_INT_STOP_CONDITION AM335X_I2C_IRQSTATUS_BF
2.7.4
