[PATCH] Implementation of inttypes.h and test related to its methods.
Aditya Upadhyay aadit0402 at gmail.com
Tue Jun 6 09:52:09 UTC 2017
 cpukit/inttypes/imaxabs.c                          |  47 +++----
 cpukit/inttypes/imaxdiv.c                          |  51 ++++----
 cpukit/inttypes/strtoimax.c                        | 131 ++++++++++++--------
 cpukit/inttypes/strtoumax.c                        | 111 +++++++++--------
 cpukit/inttypes/wcstoimax.c                        | 137 ++++++++++++---------
 cpukit/inttypes/wcstoumax.c                        |  99 +++++++++------
 testsuites/psxtests/Makefile.am                    |   1 +
 testsuites/psxtests/configure.ac                   |   1 +
 testsuites/psxtests/psxinttypes01/Makefile.am      |  22 ++++
 testsuites/psxtests/psxinttypes01/init.c           | 107 ++++++++++++++++
 .../psxtests/psxinttypes01/psxinttypes01.scn       |   9 ++
 testsuites/samples/Makefile.am                     |   1 -
 testsuites/samples/configure.ac                    |   1 -
 testsuites/samples/psxinttypes01/Makefile.am       |  22 ----
 testsuites/samples/psxinttypes01/init.c            |  69 -----------
 testsuites/samples/psxinttypes01/psxid01.doc       |  35 ------
 testsuites/samples/psxinttypes01/psxid01.scn       |  38 ------
 17 files changed, 470 insertions(+), 412 deletions(-)
 create mode 100644 testsuites/psxtests/psxinttypes01/Makefile.am
 create mode 100644 testsuites/psxtests/psxinttypes01/init.c
 create mode 100644 testsuites/psxtests/psxinttypes01/psxinttypes01.scn
 delete mode 100644 testsuites/samples/psxinttypes01/Makefile.am
 delete mode 100644 testsuites/samples/psxinttypes01/init.c
 delete mode 100644 testsuites/samples/psxinttypes01/psxid01.doc
 delete mode 100644 testsuites/samples/psxinttypes01/psxid01.scn
diff --git a/cpukit/inttypes/imaxabs.c b/cpukit/inttypes/imaxabs.c
index c1d25be..fe9331f 100644
--- a/cpukit/inttypes/imaxabs.c
+++ b/cpukit/inttypes/imaxabs.c
@@ -1,33 +1,36 @@
- * Copyright (c) 2001 Mike Barcroft <mike at FreeBSD.org>
- * All rights reserved.
+ *  Copyright (c) 2001 Mike Barcroft <mike at FreeBSD.org>
+ *  All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- *    notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- *    notice, this list of conditions and the following disclaimer in the
- *    documentation and/or other materials provided with the distribution.
+ *  Redistribution and use in source and binary forms, with or without
+ *  modification, are permitted provided that the following conditions
+ *  are met:
+ *  1. Redistributions of source code must retain the above copyright
+ *     notice, this list of conditions and the following disclaimer.
+ *  2. Redistributions in binary form must reproduce the above copyright
+ *     notice, this list of conditions and the following disclaimer in the
+ *     documentation and/or other materials provided with the distribution.
- * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
- * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
- * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
- * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
- * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
- * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
- * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
+ *  THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ *  ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ *  IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+ *  ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ *  FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ *  DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ *  OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ *  HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ *  LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ *  OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ *  SUCH DAMAGE.
 #if HAVE_CONFIG_H
 #include "config.h"
 #endif
-#include <stdint.h> /*intmax_t data type defined here */
+/* intmax_t data type defined here */
+#include <stdint.h>
 #include <rtems/inttypes.h>
diff --git a/cpukit/inttypes/imaxdiv.c b/cpukit/inttypes/imaxdiv.c
index 97db900..765481e 100644
--- a/cpukit/inttypes/imaxdiv.c
+++ b/cpukit/inttypes/imaxdiv.c
@@ -1,50 +1,53 @@
- * are met:
+ *  are met:
- * SUCH DAMAGE.
+ *  SUCH DAMAGE.
 #if HAVE_CONFIG_H
 #include "config.h"
 #endif
-#include <stdint.h> /* intmax_t data type defined here */
-/* See comments in div.c for implementation details. */
 imaxdiv_t
 imaxdiv(
   intmax_t numer, intmax_t denom)
   imaxdiv_t retval;
   retval.quot = numer / denom;
   retval.rem = numer % denom;
   #if !defined(__STDC_VERSION__) || (__STDC_VERSION__ < 199901L)
      if (numer >= 0 && retval.rem < 0) {
          retval.quot++;
 	 retval.rem -= denom;
   #endif
   return (retval);
diff --git a/cpukit/inttypes/strtoimax.c b/cpukit/inttypes/strtoimax.c
index e7382dd..092a2a9 100644
--- a/cpukit/inttypes/strtoimax.c
+++ b/cpukit/inttypes/strtoimax.c
@@ -1,19 +1,21 @@
- * This file has no copyright assigned and is placed in the Public Domain.
- * This file is part of the mingw-w64 runtime package.
- * No warranty is given; refer to the file DISCLAIMER.PD within this package.
+ *  This file has no copyright assigned and is placed in the Public Domain.
+ *  This file is part of the mingw-w64 runtime package.
+ *  No warranty is given; refer to the file DISCLAIMER.PD within this package.
-    This source code was extracted from the Q8 package created and
-    placed in the PUBLIC DOMAIN by Doug Gwyn <gwyn at arl.mil>
-    last edit:	1999/11/05	gwyn at arl.mil
-	Implements subclause 7.8.2 of ISO/IEC 9899:1999 (E).
+ *  This source code was extracted from the Q8 package created and
+ *  placed in the PUBLIC DOMAIN by Doug Gwyn <gwyn at arl.mil>
+ *  last edit:	1999/11/05	gwyn at arl.mil
+ *  Implements subclause 7.8.2 of ISO/IEC 9899:1999 (E).
+ *  This particular implementation requires the matching <inttypes.h>.
+ *  It also assumes that character codes for A..Z and a..z are in
+ *  contiguous ascending order; this is true for ASCII but not EBCDIC.
-	This particular implementation requires the matching <inttypes.h>.
-	It also assumes that character codes for A..Z and a..z are in
-	contiguous ascending order; this is true for ASCII but not EBCDIC.
 #include <ctype.h>
@@ -22,12 +24,14 @@
 /* Helper macros */
 /* convert digit character to number, in any base */
 #define ToNumber(c)	(isdigit(c) ? (c) - '0' : \
 			 isupper(c) ? (c) - 'A' + 10 : \
 			 islower(c) ? (c) - 'a' + 10 : \
-			 -1		/* "invalid" flag */ \
+			 -1		                  /* "invalid" flag */ \
 /* validate converted digit character for specific base */
 #define valid(n, b)	((n) >= 0 && (n) < (b))
 intmax_t
@@ -37,85 +41,104 @@ strtoimax(
   char ** __restrict__			endptr;
   register int				base;
-  register uintmax_t	accum;	/* accumulates converted value */
-  register int		n;	/* numeral from digit character */
-  int			minus;	/* set iff minus sign seen */
-  int			toobig;	/* set iff value overflows */
-  if ( endptr != NULL )
-    *endptr = (char *)nptr;	/* in case no conversion's performed */
-  if ( base < 0 || base == 1 || base > 36 )
+  register uintmax_t	accum;
+  register int		n;
+  int			minus;
+  int			toobig;
+  /* in case no conversion's performed */
+  if (endptr != NULL)
+    *endptr = (char *)nptr;
+  /* unspecified behavior */
+  if (base < 0 || base == 1 || base > 36){
     errno = EDOM;
-    return 0;		/* unspecified behavior */
+    return 0;
   /* skip initial, possibly empty sequence of white-space characters */
-  while ( isspace(*nptr) )
+  while (isspace(*nptr))
     ++nptr;
   /* process subject sequence: */
   /* optional sign */
-  if ( (minus = *nptr == '-') || *nptr == '+' )
+  if ((minus = *nptr == '-') || *nptr == '+')
     ++nptr;
-  if ( base == 0 ) {
-    if ( *nptr == '0' ) {
-      if ( nptr[1] == 'X' || nptr[1] == 'x' )
+  if (base == 0) {
+    if (*nptr == '0') {
+      if (nptr[1] == 'X' || nptr[1] == 'x'){
         base = 16;
-      else
-	base = 8;
+      }else{
+       base = 8;
-    else
-      base = 10;
+    }else{
+     base = 10;
   /* optional "0x" or "0X" for base 16 */
-  if ( base == 16 && *nptr == '0' && (nptr[1] == 'X' || nptr[1] == 'x') )
-    nptr += 2;		/* skip past this prefix */
+  /* skip past this prefix */
+  if (base == 16 && *nptr == '0' && (nptr[1] == 'X' || nptr[1] == 'x'))
+    nptr += 2;
   /* check whether there is at least one valid digit */
   n = ToNumber(*nptr);
   ++nptr;
+  /* subject seq. not of expected form */
-  if ( !valid(n, base) )
-    return 0;		/* subject seq. not of expected form */
+  if (!valid(n, base))
+    return 0;
   accum = n;
-  for ( toobig = 0; n = ToNumber(*nptr), valid(n, base); ++nptr )
-    if ( accum > (uintmax_t)(INTMAX_MAX / base + 2) ) /* major wrap-around */
-      toobig = 1;	/* but keep scanning */
+  for (toobig = 0; n = ToNumber(*nptr), valid(n, base); ++nptr)
+    /* major wrap-around */
+    if (accum > (uintmax_t)(INTMAX_MAX / base + 2))
+      /* but keep scanning */
+      toobig = 1;
     else
       accum = base * accum + n;
-    *endptr = (char *)nptr;	/* points to first not-valid-digit */
+  /* points to first not-valid-digit */
-  if ( minus )
-    if ( accum > (uintmax_t)INTMAX_MAX + 1 )
+  if (minus){
+    if (accum > (uintmax_t)INTMAX_MAX + 1)
       toobig = 1;
   else
-    if ( accum > (uintmax_t)INTMAX_MAX )
+    if (accum > (uintmax_t)INTMAX_MAX)
       toobig = 1;
-    if ( toobig )
-        errno = ERANGE;
-	return minus ? INTMAX_MIN : INTMAX_MAX;
-    else
-      return (intmax_t)(minus ? -accum : accum);
+  if (toobig){
+    errno = ERANGE;
+    return minus ? INTMAX_MIN : INTMAX_MAX;
+  else
+    return (intmax_t)(minus ? -accum : accum);
 long long __attribute__ (
 (alias ("strtoimax")))
 strtoll (
-const char* __restrict__ nptr, char ** __restrict__ endptr, int base);
+const char* __restrict__ nptr,
+char ** __restrict__ endptr, int base );
diff --git a/cpukit/inttypes/strtoumax.c b/cpukit/inttypes/strtoumax.c
index 70d15ee..48c818b 100644
--- a/cpukit/inttypes/strtoumax.c
+++ b/cpukit/inttypes/strtoumax.c
@@ -1,19 +1,21 @@
 #include <ctype.h>
@@ -22,12 +24,14 @@
 /* Helper macros */
 uintmax_t
@@ -37,19 +41,22 @@ strtoumax(
   register int				base;
-  register uintmax_t	next;	/* for computing next value of accum */
-  int			minus;	/* set iff minus sign seen (yes!) */
+  register uintmax_t	next;
+  register int		n;
+  int			minus;
+  int			toobig;
+  if ( base < 0 || base == 1 || base > 36 ){
     errno = EDOM;
+    return 0;
@@ -61,55 +68,63 @@ strtoumax(
   /* optional sign (yes!) */
     ++nptr;
-    if ( base == 0 )
-	  base = 16;
-	else
-          base = 8;
+  if (base == 0){
+    if (*nptr == '0'){
+	base = 16;
       else
-       	base = 10;
+        base = 8;
+    else
+      base = 10;
+    nptr += 2;
   ++nptr;
+    return 0;
   accum = n;
-    if ( accum > UINTMAX_MAX / base + 1	/* major wrap-around */
-	  || (next = base * accum + n) < accum	/* minor wrap-around */
+    /* major wrap-around and minor wrap-around */
+    if (accum > UINTMAX_MAX / base + 1 || (next = base * accum + n) < accum)
+      toobig = 1;
     else
       accum = next;
-    if ( toobig )
-      errno = ERANGE;
-      return UINTMAX_MAX;
-    else
-      return minus ? -accum : accum;	/* (yes!) */
+  if (toobig){
+    errno = ERANGE;
+    return UINTMAX_MAX;
+  else
+    return minus ? -accum : accum;	/* (yes!) */
 unsigned long long
diff --git a/cpukit/inttypes/wcstoimax.c b/cpukit/inttypes/wcstoimax.c
index 2ba3547..4ec0e91 100644
--- a/cpukit/inttypes/wcstoimax.c
+++ b/cpukit/inttypes/wcstoimax.c
@@ -1,19 +1,17 @@
 #include <wchar.h>
@@ -30,6 +28,7 @@
 intmax_t
@@ -38,38 +37,50 @@ wcstoimax(
   register const wchar_t * __restrict__	nptr;
   wchar_t ** __restrict__				endptr;
   register int					base;
-  printf("In wcstoimax function \n");
-    *endptr = (wchar_t *)nptr;	/* in case no conv performed */
+  /* accumulates converted value */
+  /* numeral from digit character */
+  register int		n;
+  /* set iff minus sign seen */
+  int			minus;
+  /* set iff value overflows */
+  int			toobig;
+  /* in case no conv performed */
+    *endptr = (wchar_t *)nptr;
     errno = EDOM;
+    return 0;
   /* skip initial, possibly empty sequence of white-space w.characters */
-  while ( iswspace(*nptr) )
+  while (iswspace(*nptr))
     ++nptr;
   /* optional sign */
-  if ( (minus = *nptr == L'-') || *nptr == L'+' )
+  if ((minus = *nptr == L'-') || *nptr == L'+')
     ++nptr;
-  if ( base == 0 )
-    if ( *nptr == L'0' )
-      if ( nptr[1] == L'X' || nptr[1] == L'x' )
+  if (base == 0){
+    if (*nptr == L'0'){
+      if (nptr[1] == L'X' || nptr[1] == L'x')
         base = 16;
       else
 	base = 8;
@@ -77,48 +88,58 @@ wcstoimax(
   else
     base = 10;
-  if ( base == 16 && *nptr == L'0'
-    && (nptr[1] == L'X' || nptr[1] == L'x')
+  if ( base == 16 && *nptr == L'0' && (nptr[1] == L'X' || nptr[1] == L'x'))
+    nptr += 2;
   n = ToWNumber(*nptr);
   ++nptr;
+    return 0;
   accum = n;
-  for ( toobig = 0; n = ToWNumber(*nptr), valid(n, base); ++nptr )
+  for (toobig = 0; n = ToWNumber(*nptr), valid(n, base); ++nptr)
+      toobig = 1;
     else
-      *endptr = (wchar_t *)nptr;	/* -> first not-valid-digit */
+    /* -> first not-valid-digit */
-    if ( minus )
-          toobig = 1;
-    else
-	toobig = 1;
-    if ( toobig )
-      errno = ERANGE;
-    else
+  if (minus){
+      toobig = 1;
+  else
+      toobig = 1;
+  if (toobig){
+    errno = ERANGE;
+  else
 long long
diff --git a/cpukit/inttypes/wcstoumax.c b/cpukit/inttypes/wcstoumax.c
index 36ea56b..890126e 100644
--- a/cpukit/inttypes/wcstoumax.c
+++ b/cpukit/inttypes/wcstoumax.c
@@ -3,17 +3,15 @@
 #include <wchar.h>
@@ -39,39 +37,50 @@ wcstoumax(
   register int					base;
+  register uintmax_t	accum, 	next;
+  register int		n;
+  int			minus;
+  int			toobig;
     errno = EDOM;
+    return 0;
     ++nptr;
   /* optional sign */
     ++nptr;
-  if ( base == 0 )
+  if (base == 0){
 	base = 16;
       else
 	base = 8;
@@ -79,33 +88,43 @@ wcstoumax(
     else
       base = 10;
+    nptr += 2;
   ++nptr;
+    return 0;
   accum = n;
+    /* minor wrap-around */
+      toobig = 1;
     else
       accum = next;
     if ( toobig )
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index 7bcea46..8b246d8 100644
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -49,6 +49,7 @@ _SUBDIRS += psxfatal01
 _SUBDIRS += psxfatal02
 _SUBDIRS += psxgetattrnp01
 endif
+_SUBDIRS += psxinttypes01
 if HAS_POSIX
 if HAS_CPLUSPLUS
 _SUBDIRS += psxglobalcon01
diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
index 1de1312..4db7916 100644
--- a/testsuites/psxtests/configure.ac
+++ b/testsuites/psxtests/configure.ac
@@ -162,6 +162,7 @@ psxid01/Makefile
 psximfs01/Makefile
 psximfs02/Makefile
 psxintrcritical01/Makefile
+psxinttypes01/Makefile
 psxitimer/Makefile
 psxkey01/Makefile
 psxkey02/Makefile
diff --git a/testsuites/psxtests/psxinttypes01/Makefile.am b/testsuites/psxtests/psxinttypes01/Makefile.am
new file mode 100644
index 0000000..517648c
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes01/Makefile.am
@@ -0,0 +1,22 @@
+rtems_tests_PROGRAMS = psxinttypes01
+psxinttypes01_SOURCES = init.c
+dist_rtems_tests_DATA = psxinttypes01.scn
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/include
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(psxinttypes01_OBJECTS) $(psxinttypes01_LDADD)
+LINK_LIBS = $(psxinttypes01_LDLIBS)  /home/aditya/development/b-sparc/sparc-rtems4.12/c/erc32/cpukit/inttypes/libinttypes.a
+psxinttypes01$(EXEEXT): $(psxinttypes01_OBJECTS) $(psxinttypes01_DEPENDENCIES)
+	@rm -f psxinttypes01$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/psxtests/psxinttypes01/init.c b/testsuites/psxtests/psxinttypes01/init.c
index 0000000..770b04d
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes01/init.c
@@ -0,0 +1,107 @@
+ *  This is the test for inttypes library. It covers these functions :
+ *  imaxabs(), imaxdiv(), strtoimax(), strtoumax(), wcstoimax(), wcstoumax().
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/inttypes.h>
+#include <rtems/printer.h>
+#include <rtems/test.h>
+#include <stdlib.h>
+#include <tmacros.h>
+/* forward declarations to avoid warnings */
+rtems_task Init(rtems_task_argument argument);
+const char rtems_test_name[] = "PSXINTTYPE 01";
+rtems_printer rtems_test_printer;
+ * RTEMS Startup Task
+rtems_task Init(
+  rtems_task_argument ignored
+  rtems_print_printer_printf(&rtems_test_printer);
+  rtems_test_begin();
+  char* endptr, *nptr;
+  uintmax_t j, k;
+  int base = 10;
+  rtems_test_assert (base == EINVAL)
+  wchar_t *nptr1, *endptr1;
+  intmax_t m, n;
+  nptr1 = L"10110134932";
+  nptr  = "20690239864abc";
+  /* Test for wcstoimax */
+  m = wcstoimax(nptr1, &endptr1, base);
+  rtems_test_assert (m == ERANGE)
+  rtems_test_assert (m == EINVAL)
+  printf( "wcstoimax = %jd\n", m );
+  /* test for strtoumax */
+  j = strtoumax (nptr, &endptr, base);
+  rtems_test_assert (j == ERANGE);
+  rtems_test_assert (j == EINVAL)
+  printf( "strtoumax = %ju ( base %d )\n", j, base );
+  printf( "Stopped scan at %s\n\n", endptr );
+  /*test for wcstoumax */
+  k = wcstoumax (nptr1, &endptr1, base);
+  rtems_test_assert (k == ERANGE)
+  rtems_test_assert (k == EINVAL)
+  printf( "wcstoumax = %ju\n", k );
+  /*Test for imaxdiv */
+  imaxdiv_t retrival = imaxdiv ( 27, 4 );
+  printf( "imax div value = %jd\n", retrival.rem );
+  /*Test for imaxabs  */
+  printf( "imaxabs_value = %jd\n", imaxabs (-1234));
+  /*Test for strtoimax */
+  n = strtoimax ("11111111", &endptr, 2)
+  rtems_test_assert (n == ERANGE)
+  rtems_test_assert (n == EINVAL)
+  printf( "strtoimax value = %jd\n", n);
+  rtems_test_end();
+  exit( 0 );
+/* NOTICE: the clock driver is explicitly disabled */
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS            1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#include <rtems/confdefs.h>
diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.scn b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
index 0000000..1625fa7
--- /dev/null
+++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
@@ -0,0 +1,9 @@
+*** BEGIN OF TEST PSXINTTYPE 01 ***
+wcstoimax = 10110134932
+strtoumax = 20690239864 (base 10)
+Stopped scan at abc
+wcstoumax = 10110134932
+imax div value = 3
+imaxabs_value = 1234
+strtoimax value = 255
+*** END OF TEST PSXINTTYPE 01 ***
diff --git a/testsuites/samples/Makefile.am b/testsuites/samples/Makefile.am
index fd16f57..85e89a5 100644
--- a/testsuites/samples/Makefile.am
+++ b/testsuites/samples/Makefile.am
@@ -8,7 +8,6 @@ _SUBDIRS += hello
 _SUBDIRS += minimum
 _SUBDIRS += nsecs
 _SUBDIRS += paranoia
-_SUBDIRS += psxinttypes01
 _SUBDIRS += ticker
 _SUBDIRS += unlimited
diff --git a/testsuites/samples/configure.ac b/testsuites/samples/configure.ac
index 3d0ef5b..ffe1bad 100644
--- a/testsuites/samples/configure.ac
+++ b/testsuites/samples/configure.ac
@@ -74,7 +74,6 @@ minimum/Makefile
 nsecs/Makefile
 paranoia/Makefile
 pppd/Makefile
-psxinttypes01/Makefile
 ticker/Makefile
 unlimited/Makefile
diff --git a/testsuites/samples/psxinttypes01/Makefile.am b/testsuites/samples/psxinttypes01/Makefile.am
deleted file mode 100644
index 56a85aa..0000000
--- a/testsuites/samples/psxinttypes01/Makefile.am
+++ /dev/null
@@ -1,22 +0,0 @@
-AUTOMAKE_OPTIONS = subdir-objects
-rtems_tests_PROGRAMS = psxinttypes01
-psxinttypes01_SOURCES = init.c
-##dist_rtems_tests_DATA = psxinttypes01.scn
-include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
-include $(top_srcdir)/../automake/compile.am
-include $(top_srcdir)/../automake/leaf.am
-AM_CPPFLAGS += -I$(top_srcdir)/include
-AM_CPPFLAGS += -I$(top_srcdir)/../support/include
-LINK_OBJS = $(psxinttypes01_OBJECTS) $(psxinttypes01_LDADD)
-LINK_LIBS = $(psxinttypes01_LDLIBS)  /home/aditya/development/b-sparc/sparc-rtems4.12/c/erc32/cpukit/inttypes/libinttypes.a
-psxinttypes01$(EXEEXT): $(psxinttypes01_OBJECTS) $(psxinttypes01_DEPENDENCIES)
-	@rm -f psxinttypes01$(EXEEXT)
-	$(make-exe)
-include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/samples/psxinttypes01/init.c b/testsuites/samples/psxinttypes01/init.c
index bda6879..0000000
--- a/testsuites/samples/psxinttypes01/init.c
+++ /dev/null
@@ -1,69 +0,0 @@
-/*This is the test for inttypes library. It covers these functions :
-imaxabs(), imaxdiv(), strtoimax(), strtoumax(), wcstoimax(), wcstoumax().
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <rtems/inttypes.h>
-#include <rtems/printer.h>
-#include <rtems/test.h>
-#include <stdlib.h>
-/* forward declarations to avoid warnings */
-rtems_task Init(rtems_task_argument argument);
-const char rtems_test_name[] = "PSXINTTYPE 01";
-rtems_printer rtems_test_printer;
- * RTEMS Startup Task
-rtems_task Init(
-  rtems_task_argument ignored
-  rtems_print_printer_printf(&rtems_test_printer);
-  rtems_test_begin();
-  char* endptr;
-  uintmax_t j,k;
-  int base = 10;
-  char *nptr;
-  wchar_t *nptr1, *endptr1;
-  intmax_t m;
-  nptr1 = L"10110134932";
-  nptr = "20690239864abc";
-  m = wcstoimax(nptr1, &endptr1, base);
-  printf("string = %s\n", nptr);
-  j = strtoumax(nptr, &endptr, base);
-  printf("wcstoimax = %jd\n", m);
-  k = wcstoumax(nptr1, &endptr1, base);
-  printf("wcstoumax = %ju\n", k);
-  printf("strtoumax = %ju (base %d)\n", j, base);
-  printf("Stopped scan at %s\n\n", endptr);
-  imaxdiv_t retrival = imaxdiv(27, 4);
-  printf(" Strtoimax values \n");
-  printf("%jd\n", strtoimax(" -123junk",&endptr,10)); /* base 10                    */
-  printf("%jd\n", strtoimax("11111111",&endptr,2));   /* base 2                     */
-  printf("%jd\n", strtoimax("XyZ",&endptr,36));       /* base 36                    */
-  printf("%jd\n", strtoimax("010",&endptr,0));        /* octal auto-detection       */
-  printf("%jd\n", strtoimax("10",&endptr,0));         /* decimal auto-detection     */
-  printf("%jd\n", strtoimax("0x10",&endptr,0));       /* hexadecimal auto-detection */
-  printf( "imaxabs_value = %jd\n", imaxabs(-1234));
-  printf("strtoimax value = %jd\n", strtoimax("11111111",&endptr,2));
-  printf( "imax div value = %jd\n", retrival.rem);
-  rtems_test_end();
-  exit( 0 );
-/* NOTICE: the clock driver is explicitly disabled */
-#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
-#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
-#define CONFIGURE_MAXIMUM_TASKS            1
-#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
-#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
-#include <rtems/confdefs.h>
diff --git a/testsuites/samples/psxinttypes01/psxid01.doc b/testsuites/samples/psxinttypes01/psxid01.doc
index a8ce42a..0000000
--- a/testsuites/samples/psxinttypes01/psxid01.doc
+++ /dev/null
@@ -1,35 +0,0 @@
-#  COPYRIGHT (c) 1989-2010.
-#  On-Line Applications Research Corporation (OAR).
-#  The license and distribution terms for this file may be
-#  found in the file LICENSE in this distribution or at
-#  http://www.rtems.org/license/LICENSE.
-This file describes the directives and concepts tested by this test set.
-test set name:  psxid01
-directives:
-  getegid
-  getgid
-  setgid
-  setpgid
-  geteuid
-  getuid
-  setuid
-  geteuid
-  getuid
-  getpid
-  __getpid
-  getppid
-  setsid
-  getpgrp
-  getgroups
-  getlogin
-  getlogin_r
-concepts:
-+ Fully exercise the above listed methods
diff --git a/testsuites/samples/psxinttypes01/psxid01.scn b/testsuites/samples/psxinttypes01/psxid01.scn
index e0ea2a0..0000000
--- a/testsuites/samples/psxinttypes01/psxid01.scn
+++ /dev/null
@@ -1,38 +0,0 @@
-*** BEGIN OF TEST PSXID 1 ***
-getegid = 0
-getgid = 0
-setgid(5)
-getegid = 0
-getgid = 5
-setegid(5)
-getegid = 5
-getgid = 5
-setgid(0)
-setegid(0)
-setpgid(getpid(), 10) - ENOSYS
-geteuid = 0
-getuid = 0
-setuid(5)
-geteuid = 0
-getuid = 5
-seteuid(5)
-geteuid = 5
-getuid = 5
-seteuid(0)
-setuid(0)
-getpid = 1
-__getpid = 1
-getppid = 0
-setsid - EPERM
-getpgrp - return local node - OK
-getpgrp returned 1
-setuid(5)
-getlogin() -- ()
-setuid(0)
-getlogin() -- (root)
-getlogin_r(NULL, LOGIN_NAME_MAX) -- EFAULT
-getlogin_r(buffer, 0) -- ERANGE
-*** END OF TEST PSXID 1 ***
2.7.4
