RTEMS-libbsd USB interrupt issue[GSOC]
Sichen Zhao
zsc19940506 at outlook.com
Thu Jun 8 15:42:11 UTC 2017
Hi all,
I am porting Beagle USB from FreeBSD to RTEMS-libbsd, the file i ported is from freebsd/sys/arm/ti/am335x, the file is: AM335x_musb.c , am335x_usbss.c ,etc.
BSP: Beaglebone Black, CPU:AM335x
The issue i meeted is : When the USB1_DRVVBUS pin pull high, the interrupt vector 0x19 occured, it stuck, and don't go the the ISR.
The code stuck at here: https://github.com/freebsd/freebsd/blob/master/sys/dev/usb/controller/musb_otg.c#L3126
The install ISR at here: https://github.com/freebsd/freebsd/blob/master/sys/arm/ti/am335x/am335x_musb.c#L299
Best Regards
Sichen Zhao
