RISC-V interrupts
Hesham Almatary heshamelmatary at gmail.com
Fri Jun 9 08:49:50 UTC 2017
On Fri, Jun 9, 2017 at 9:09 AM, Denis Obrezkov <denisobrezkov at gmail.com> wrote:
> 2017-06-09 1:52 GMT+03:00 Hesham Almatary <heshamelmatary at gmail.com>:
>> Hi Denis,
>> Does your board support any accesses to > 0x80000000. Note you still
>> use such region in your linker script, which shouldn't be used if your
>> board doesn't support it. I'd suggest your read about memory mapping
>> on your board and fix the linker script accordingly.
>> Regards,
>> Hesham
>> On Fri, Jun 9, 2017 at 8:38 AM, Denis Obrezkov <denisobrezkov at gmail.com>
>> wrote:
>> > 2017-06-08 17:49 GMT+03:00 Denis Obrezkov <denisobrezkov at gmail.com>:
>> >> 2017-06-08 12:24 GMT+03:00 Denis Obrezkov <denisobrezkov at gmail.com>:
>> >>> 2017-06-07 22:41 GMT+03:00 Hesham Almatary <heshamelmatary at gmail.com>:
>> >>>> On Thu, Jun 8, 2017 at 2:26 AM, Denis Obrezkov
>> >>>> wrote:
>> >>>> > 2017-06-07 14:44 GMT+03:00 Sebastian Huber
>> >>>> > <sebastian.huber at embedded-brains.de>:
>> >>>> >> On 06/06/17 18:58, Hesham Almatary wrote:
>> >>>> >>> Originally RTEMS had a one big linkcmd for each platform, which
>> >>>> >>> defines linker symbols (used in C code) and required sections.
>> >>>> >>> This
>> >>>> >>> has been improved with current BSPs (like ARM-based ones), by
>> >>>> >>> splitting up shared linkcmd parts (linkcmd base) and BSP specific
>> >>>> >>> ones
>> >>>> >>> that include the shared one. riscv_generic, given that it's old,
>> >>>> >>> follows the old way of having a single big linkcmd. You can
>> >>>> >>> change
>> >>>> >>> this for your new BSP.
>> >>>> >> New ports/BSPs should definitely use a shared linkcmds.base (see
>> >>>> >> ARM). Use
>> >>>> >> "riscv-rtems4.12-ld --verbose" to get the default linker script.
>> >>>> > Ok.
>> >>>> > Now I have a problem:
>> >>>> > https://github.com/embeddedden/rtems-riscv/blob/hifive1/c/src/lib/libbsp/riscv32/hifive1/start/start.S#L117
>> >>>> > When I step to that line, gdb hangs with a message:
>> >>>> > (gdb) step
>> >>>> > Note: automatically using hardware breakpoints for read-only
>> >>>> > addresses.
>> >>>> How do you run/attach simulator (and which one do you use)? Do GDB
>> >>>> and
>> >>>> the simulator support 0x20400000 > addresses (where your text section
>> >>>> is loaded to)? AFAIK, that's not the case. Spike's default machine
>> >>>> only works with addresses >= 0x80000000. You've to look up if Spike,
>> >>>> Qemu [1] or GDB target sim model your board.
>> >> I use openOCD from FreeStudio kit:
>> >> https://github.com/sifive/freedom-e-sdk/blob/master/FreedomStudio/HiFive1/hello/openocd.cfg
>> >> I was able to run code in ROM region, after I made this:
>> >> MEMORY
>> >>     ROM      : ORIGIN = 0x20400000, LENGTH = 128M
>> >>     RAM      : ORIGIN = 0x80000000, LENGTH = 64K
>> >> REGION_ALIAS ("REGION_VECTOR", RAM);
>> >> REGION_ALIAS ("REGION_START", ROM);
>> >> REGION_ALIAS ("REGION_TEXT", ROM);
>> >> REGION_ALIAS ("REGION_TEXT_LOAD", ROM);
>> >> REGION_ALIAS ("REGION_RODATA", ROM);
>> >> REGION_ALIAS ("REGION_RODATA_LOAD", ROM);
>> >> REGION_ALIAS ("REGION_DATA", RAM);
>> >> REGION_ALIAS ("REGION_DATA_LOAD", ROM);
>> >> REGION_ALIAS ("REGION_FAST_DATA", RAM);
>> >> REGION_ALIAS ("REGION_FAST_DATA_LOAD", ROM);
>> >> REGION_ALIAS ("REGION_BSS", RAM);
>> >> REGION_ALIAS ("REGION_WORK", RAM);
>> >> REGION_ALIAS ("REGION_STACK", RAM);
>> >> And gdb can step till the "call boot_card" instruction,
>> >> but I can't proceed any further due to the error:
>> >> gdb hands after stepping into "call boot_card"
>> >> At the same time openocd shows:
>> >> halted at 0x20400202 due to step
>> >> halted at 0x20400262 due to hardware trigger
>> >> halted at 0x204010c2 due to step
>> >> The last line appears after attempt to make the step.
>> >> Links to my linkcmd and start.S files:
>> >> https://github.com/embeddedden/rtems-riscv/blob/hifive1/c/src/lib/libbsp/riscv32/hifive1/startup/linkcmds
>> >> Regards, Denis Obrezkov
>> > I also found out that when I use stepi on "call boot_card" I got a
>> > warning
>> > from openocd:
>> > Core got an exception (0xffffffff) while reading from 0x8000effc
>> Hesham
> Yes, it definitely supports it, I've already done it.
> 0x80000000 is the start of 64 KiB RAM, and 0x20000000 is the start of flash.
> I think I found the problem. It seems that this gdb build supports 16 KiB of
> RAM (as in Freedom E300 specification).
> I changed the value of RAM length to 16 KiB, so now I can execute further.
> Thanks!
Great! Glad to know it's working now. You might want to do some
analysis of the size/footprint of your executable (e.g. hello world),
and what should go into ROM vs RAM. 64 KiB might not be enough for
some applications. Also there is a "compressed" version of the RISC-V
ISA, might be worth looking at.
Hesham
