[PATCH 2/2] Review and help
Tanu Hari Dixit tokencolour at gmail.com
Mon Jun 12 02:51:45 UTC 2017
Few of the new ini files
 tester/rtems/testing/bsps/erc32-run.ini |  54 ++++++++++++++
 tester/rtems/testing/bsps/erc32.ini     |  56 ++++++++++++++
 tester/rtems/testing/defaults.ini       | 126 ++++++++++++++++++++++++++++++++
 tester/rtems/testing/testing.ini        |  57 +++++++++++++++
 4 files changed, 293 insertions(+)
 create mode 100644 tester/rtems/testing/bsps/erc32-run.ini
 create mode 100644 tester/rtems/testing/bsps/erc32.ini
 create mode 100644 tester/rtems/testing/defaults.ini
 create mode 100644 tester/rtems/testing/testing.ini
diff --git a/tester/rtems/testing/bsps/erc32-run.ini b/tester/rtems/testing/bsps/erc32-run.ini
new file mode 100644
index 0000000..4135426
--- /dev/null
+++ b/tester/rtems/testing/bsps/erc32-run.ini
@@ -0,0 +1,54 @@
+; RTEMS Tools Project (http://www.rtems.org/)
+; Copyright 2015 On-Line Applications Research Corporation (OAR).
+; All rights reserved.
+; This file is part of the RTEMS Tools package in 'rtems-tools'.
+; Redistribution and use in source and binary forms, with or without
+; modification, are permitted provided that the following conditions are met:
+; 1. Redistributions of source code must retain the above copyright notice,
+; this list of conditions and the following disclaimer.
+; 2. Redistributions in binary form must reproduce the above copyright notice,
+; this list of conditions and the following disclaimer in the documentation
+; and/or other materials provided with the distribution.
+; THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+; AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+; IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+; ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+; LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+; CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+; SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+; INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+; CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+; ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+; POSSIBILITY OF SUCH DAMAGE.
+; All paths in defaults must be Unix format. Do not store any Windows format
+; paths in the defaults.
+; Every entry must describe the type of checking a host must pass.
+; Records:
+;  key: type, attribute, value
+;   type     : none, dir, exe, triplet
+;   attribute: none, required, optional
+;   value    : 'single line', '''multi line'''
+; The erc32 BSP
+[erc32]
+bsp = erc32
+arch = sparc
+[run]
+run = %{_rtscripts}/run.cfg
+bsp_run_cmd = %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-run
+bsp_run_opts = ''
diff --git a/tester/rtems/testing/bsps/erc32.ini b/tester/rtems/testing/bsps/erc32.ini
index 0000000..c510893
--- /dev/null
+++ b/tester/rtems/testing/bsps/erc32.ini
@@ -0,0 +1,56 @@
+; Records:
+; The erc32 BSP
+[erc32]
+bsp = erc32
+arch = sparc
+[gdb_script]
+gdb = %{_rtscripts}/gdb.cfg
+gdb_script = 'erc32_gdb_script'
+erc32_gdb_script = 'target sim
+    load
+    run'
diff --git a/tester/rtems/testing/defaults.ini b/tester/rtems/testing/defaults.ini
index 0000000..81a73ae
--- /dev/null
+++ b/tester/rtems/testing/defaults.ini
@@ -0,0 +1,126 @@
+; Copyright 2010-2015 Chris Johns (chrisj at rtems.org)
+; Records:
+; Global defaults
+[global]
+; Nothing
+nil = ''
+; Paths
+_topdir = %{_prefix}
+_docdir = %{_defaultdocdir}
+_tmppath = %{_topdir}/build/tmp
+_tmproot = %{_tmppath}/rt/%{_bset}
+_datadir = %{_prefix}/share
+_defaultdocdir = %{_prefix}/share/doc
+_exeext = ''
+_exec_prefix = %{_prefix}
+_bindir = %{_exec_prefix}/bin
+_sbindir = %{_exec_prefix}/sbin
+_libexecdir = %{_exec_prefix}/libexec
+_datarootdir = %{_prefix}/share
+_datadir = %{_datarootdir}
+_sysconfdir = %{_prefix}/etc
+_sharedstatedir = %{_prefix}/com
+_localstatedir = %{prefix}/var
+_includedir = %{_prefix}/include
+_lib = lib
+_libdir = %{_exec_prefix}/%{_lib}
+_mandir = %{_datarootdir}/man
+_infodir = %{_datarootdir}/info
+_localedir = %{_datarootdir}/locale
+_localedir = %{_datadir}/locale
+_localstatedir = %{_prefix}/var
+_usr = /usr/local
+_usrsrc = %{_usr}/src
+_var = /usr/local/var
+_varrun = %{_var}/run
+; Defaults, override in platform specific modules.
+__arch_install_post = %{nil}
+__bash = /bin/bash
+__bzip2 = /usr/bin/bzip2
+__cat = /bin/cat
+__chgrp = /usr/bin/chgrp
+__chmod = /bin/chmod
+__chown = /usr/sbin/chown
+__cp = /bin/cp
+__git = /usr/bin/git
+__grep = /usr/bin/grep
+__gzip = /usr/bin/gzip
+__id = /usr/bin/id
+__id_u = %{__id} -u
+__ln_s = ln -s
+__make = make
+__mkdir = /bin/mkdir
+__mkdir_p = /bin/mkdir -p
+__mv = /bin/mv
+__patch_bin = /usr/bin/patch
+__patch_opts = %{nil}
+__patch = %{__patch_bin} %{__patch_opts}
+__svn = /usr/bin/svn
+__rm = /bin/rm
+__rmfile = %{__rm} -f
+__rmdir = %{__rm} -rf
+__sed = /usr/bin/sed
+__sh = /bin/sh
+__tar = /usr/bin/tar
+__tar_extract = %{__tar} -xvvf
+__touch = /usr/bin/touch
+__unzip = /usr/bin/unzip
+__xz = /usr/bin/xz
+; Default settings
+_target = %{nil}
+; Paths
+_rtbase = %{_rtdir}
+_rttesting = %{_rtbase}/rtems/testing
+_configdir = %{_rtbase}/config:%{_rttesting}
+; Include the testing macros.
+include = %{_rttesting}/testing.ini
diff --git a/tester/rtems/testing/testing.ini b/tester/rtems/testing/testing.ini
index 0000000..08ad574
--- /dev/null
+++ b/tester/rtems/testing/testing.ini
@@ -0,0 +1,57 @@
+; Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
+; Records:
+; Global defaults
+[global]
+; Paths
+_rtscripts = %{_rtbase}/rtems/testing
+; Defaults
+timeout = 180
+; Tests detected as invalid that are valid
+invalid_tests = '''minimum.exe'''
2.1.4
