Risc-v memory issue
Hesham Almatary heshamelmatary at gmail.com
Wed Jun 14 05:52:30 UTC 2017
Aha, I was checking your priv-1.10_embden branch
On Wed, Jun 14, 2017 at 3:42 PM, Denis Obrezkov <denisobrezkov at gmail.com> wrote:
> 2017-06-14 8:35 GMT+03:00 Hesham Almatary <heshamelmatary at gmail.com>:
>> On Wed, Jun 14, 2017 at 2:58 PM, Denis Obrezkov <denisobrezkov at gmail.com>
>> wrote:
>> > 2017-06-14 2:18 GMT+03:00 Hesham Almatary <heshamelmatary at gmail.com>:
>> >> On Tue, Jun 13, 2017 at 10:20 PM, Joel Sherrill <joel at rtems.org> wrote:
>> >>> On Jun 12, 2017 3:10 PM, "Hesham Almatary" <heshamelmatary at gmail.com>
>> >>> wrote:
>> >>> On Tue, Jun 13, 2017 at 2:09 AM, Denis Obrezkov
>> >>> wrote:
>> >>> > Hello all,
>> >>> > I was able to debug my program on top of HiFive1 board.
>> >>> > I found out that I can't use next and until commands from gdb,
>> >>> > they just hang gdb.
>> >>> > And now I have a problem, this is my backtrace:
>> >>> > #0  0x2041d728 in _User_extensions_Iterate (arg=0x80002eb8,
>> >>> > visitor=0x2041d64e <_User_extensions_Fatal_visitor>,
>> >>> > direction=CHAIN_ITERATOR_FORWARD)
>> >>> >     at
>> >>> > /home/reprofy/Projects/riscv/rtems/development/rtems/kernel/rtems-riscv/c/src/../../cpukit/score/src/userextiterate.c:155
>> >>> > #1  0x20410ed4 in _User_extensions_Fatal
>> >>> > (source=INTERNAL_ERROR_CORE,
>> >>> > error=2) at
>> >>> > ../../cpukit/../../../hifive1/lib/include/rtems/score/userextimpl.h:307
>> >>> > #2  0x20410ef8 in _Terminate (the_source=INTERNAL_ERROR_CORE,
>> >>> > the_error=2)
>> >>> > at
>> >>> > /home/reprofy/Projects/riscv/rtems/development/rtems/kernel/rtems-riscv/c/src/../../cpukit/score/src/interr.c:35
>> >>> > #3  0x20410f40 in _Internal_error
>> >>> > (core_error=INTERNAL_ERROR_TOO_LITTLE_WORKSPACE) at
>> >>> > /home/reprofy/Projects/riscv/rtems/development/rtems/kernel/rtems-riscv/c/src/../../cpukit/score/src/interr.c:44
>> >>> > #4  0x2041e484 in _Workspace_Handler_initialization
>> >>> > (areas=0x80002f78,
>> >>> > area_count=1, extend=0x0) at
>> >>> > /home/reprofy/Projects/riscv/rtems/development/rtems/kernel/rtems-riscv/c/src/../../cpukit/score/src/wkspace.c:123
>> >>> > #5  0x2040031c in bsp_work_area_initialize_default
>> >>> > (area_begin=0x80001d58,
>> >>> > area_size=8872) at
>> >>> > ../../../../../.././hifive1/lib/include/bsp/bootcard.h:147
>> >>> > #6  0x20400372 in bsp_work_area_initialize () at
>> >>> > /home/reprofy/Projects/riscv/rtems/development/rtems/kernel/rtems-riscv/c/src/lib/libbsp/riscv32/hifive1/../../shared/bspgetworkarea.c:61
>> >>> > #7  0x2040f3ce in rtems_initialize_executive () at
>> >>> > /home/reprofy/Projects/riscv/rtems/development/rtems/kernel/rtems-riscv/c/src/../../cpukit/sapi/src/exinit.c:95
>> >>> > #8  0x204002cc in boot_card (cmdline=0x0) at
>> >>> > /home/reprofy/Projects/riscv/rtems/development/rtems/kernel/rtems-riscv/c/src/lib/libbsp/riscv32/hifive1/../../shared/bootcard.c:76
>> >>> > #9  0x20400064 in _end_clear_bss () at
>> >>> > /home/reprofy/Projects/riscv/rtems/development/rtems/kernel/rtems-riscv/c/src/lib/libbsp/riscv32/hifive1/start/start.S:116
>> >>> > So, I think I should increase a workspace.
>> >>> > Now, I have some questions:
>> >>> > I took Hesham's linker file for riscv-generic, and there were no
>> >>> > stack
>> >>> > space,
>> >>> > I allocated 0x1000 for stack. Should I make it zero again, or should
>> >>> > I
>> >>> > decrease its size?
>> >>> > what size for stack should be enough?
>> >>>>                  * The stack section will occupy the remaining
>> >>>> REGION_STACK region and may
>> >>>>                  * contain the task stacks.  Depending on the region
>> >>>> distribution this
>> >>>>                  * section may be of zero size.
>> >>> This means that the stack_end address is starting at your very top
>> >>> address space (i.e. 16KiB if you set your linker size to 16KiB). The
>> >>> stack
>> >>> grows dynamically downwards, so it might overflow other sections (e.g.
>> >>> work,
>> >>> heap, data, etc) if you don't have enough memory size to fit. You can
>> >>> try to
>> >>> see how much size each section occupies (riscv32-rtems4.12-objdump -h
>> >>> hello.exe), especially work space.
>> >>> This is how the SPARC start up stack is done. If you aren't careful,
>> >>> this
>> >>> may not match the assumption in the default method that carves up the
>> >>> workspace.
>> >>> You need to be careful that the memory regions don't overlap.
>> >>> > And why there were no space for stack? is it possible to work
>> >>> > without
>> >>> > stack
>> >>> > allocated in
>> >>> > linkcmd file?
>> >>> > Can RTEMS work with a smaller workspace?
>> >>> As far as I remember, 4KiB was the smallest I could allocate for
>> >>> workspace to work (with Epiphany). As I suggested before, you might
>> >>> want to
>> >>> start saving up memory by using the local instruction memory (on
>> >>> HiFive) and
>> >>> compressed version of RISC-V ISA.
>> >>> Is this a characteristic of this board or the architecture in general?
>> >>> I
>> >>> had the impression that the RISC-V was quite general purpose and could
>> >>> handle plenty of RAM even if some boards don't have much.
>> >> RISC-V itself doesn't put such restrictions on the size of memory (e.g.
>> >> Linux, seL4, RTEMS can run on FPGA and/or simulators). There's a
>> >> compressed
>> >> extension for RISC-V (like thumb) for platforms that have small
>> >> memories
>> >> same as HiFive. Having such small memory is only HiFive related, not
>> >> RISC-V.
>> >>> > Regards, Denis Obrezkov
>> >>> Hesha
>> >>> _______________________________________________
>> >>> devel mailing list
>> >>> devel at rtems.org
>> >>> http://lists.rtems.org/mailman/listinfo/devel
>> >> Hesham
>> > I think that RISC-V Compressed ISA can't reduce .bss and .data sections,
>> > am
>> > I right?
>> > So, it seems that space allocated by rtems for its workspace should be
>> > reduced.
>> Currently all of the sections (including .bss, .text, .data, etc) are
>> competing for 16KiB memory, if you reduced the .text (using compressed
>> RISC-V and/or ITIM) section size, this gives more space for other
>> sections, hence .work and .stack.
>> Hesham
> In my linkcmd file .text is located in flash:
> https://github.com/embeddedden/rtems-riscv/blob/hifive1/c/src/lib/libbsp/riscv32/hifive1/startup/linkcmds
Hesham
