[PATCH] Fix beagle i2c file bbb-i2c.c comment issues
Thu Jun 15 19:57:08 UTC 2017
Someone can push this.
On Thu, Jun 15, 2017 at 7:35 AM, Sichen Zhao <1473996754 at qq.com> wrote:
>  c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c | 42 +++++++++++++++++--------------
>  1 file changed, 23 insertions(+), 19 deletions(-)
> diff --git a/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
> index 3d7d820..26bae52 100644
> --- a/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
> +++ b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
> @@ -7,6 +7,7 @@
> + * Copyright (c) 2016 Punit Vara <punitvara at gmail.com>
>   * Copyright (c) 2017 Sichen Zhao <zsc19940506 at gmail.com>
>   * The license and distribution terms for this file may be
> @@ -48,27 +49,26 @@ static void I2C0ModuleClkConfig( void )
>              AM335X_CM_WKUP_I2C0_CLKCTRL_MODULEMODE ) ) ;
> -  ** Waiting for IDLEST field in AM335X_CM_WKUP_CONTROL_CLKCTRL
> -  ** register to attain
> -  ** desired value.
> +   * Waiting for IDLEST field in AM335X_CM_WKUP_CONTROL_CLKCTRL
> +   * register to attain desired value.
>    while ( ( AM335X_CM_WKUP_CONTROL_CLKCTRL_IDLEST_FUNC <<
>              AM335X_CM_WKUP_CONTROL_CLKCTRL_IDLEST_SHIFT ) !=
>            ( REG( AM335X_SOC_CM_WKUP_REGS + AM335X_CM_WKUP_CONTROL_CLKCTRL ) &
>              AM335X_CM_WKUP_CONTROL_CLKCTRL_IDLEST ) ) ;
> -  ** Waiting for CLKACTIVITY_I2C0_GFCLK field in AM335X_CM_WKUP_CLKSTCTRL
> -  ** register to attain desired value.
> +   * Waiting for CLKACTIVITY_I2C0_GFCLK field in AM335X_CM_WKUP_CLKSTCTRL
>    while ( AM335X_CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK !=
>            ( REG( AM335X_SOC_CM_WKUP_REGS + AM335X_CM_WKUP_CLKSTCTRL ) &
>              AM335X_CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK ) ) ;
> -  ** Waiting for IDLEST field in AM335X_CM_WKUP_I2C0_CLKCTRL register to attain
> -  ** desired value.
> +   * Waiting for IDLEST field in AM335X_CM_WKUP_I2C0_CLKCTRL register to attain
> +   * desired value.
>    while ( ( AM335X_CM_WKUP_I2C0_CLKCTRL_IDLEST_FUNC <<
>              AM335X_CM_WKUP_I2C0_CLKCTRL_IDLEST_SHIFT ) !=
>            ( REG( AM335X_SOC_CM_WKUP_REGS + AM335X_CM_WKUP_I2C0_CLKCTRL ) &
> @@ -100,7 +100,7 @@ static void am335x_i2c_reset( bbb_i2c_bus *bus )
> -   Possible values for msg->flag
> + * Possible values for msg->flag
>   * - @ref I2C_M_TEN,
>   * - @ref I2C_M_RD,
>   * - @ref I2C_M_STOP,
> @@ -116,13 +116,15 @@ static void am335x_i2c_set_address_size(
>    volatile bbb_i2c_regs *regs
> -  /*can be configured multiple modes here.
> -   **Need to think about own address modes*/
> +   * Can be configured multiple modes here.
> +   * Need to think about own address modes
>    if ( ( msgs->flags & I2C_M_TEN ) == 0 ) {
> -    /* 7-bit mode slave address mode*/
> +    /* 7-bit mode slave address mode */
>      REG( &regs->BBB_I2C_CON ) = AM335X_I2C_CFG_7BIT_SLAVE_ADDR;
>    } else {
> -    /* 10-bit slave address mode*/
> +    /* 10-bit slave address mode */
>      REG( &regs->BBB_I2C_CON ) = AM335X_I2C_CFG_10BIT_SLAVE_ADDR;
> @@ -282,12 +284,14 @@ static void am335x_i2c_interrupt( void *arg )
>    bbb_i2c_bus           *bus = arg;
>    volatile bbb_i2c_regs *regs = bus->regs;
> -  /* get status of enabled interrupts */
> +  /* Get status of enabled interrupts */
>    uint32_t irqstatus = REG( &regs->BBB_I2C_IRQSTATUS );
>    bool     done = false;
> -  /* Clear all enabled interrupt except receive ready
> -     and transmit ready interrupt in status register */
> +   * Clear all enabled interrupt except receive ready
> +   * and transmit ready interrupt in status register
>    REG( &regs->BBB_I2C_IRQSTATUS ) =
>      ( irqstatus & ~( AM335X_I2C_IRQSTATUS_RRDY |
>                       AM335X_I2C_IRQSTATUS_XRDY ) );
> @@ -417,7 +421,7 @@ int am335x_i2c_bus_register(
>    rtems_status_code sc;
>    int               err;
> -  /*check bus number is >0 & <MAX*/
> +  /* Check bus number is >0 & <MAX */
>    bus = (bbb_i2c_bus *) i2c_bus_alloc_and_init( sizeof( *bus ) );
>    if ( bus == NULL ) {
> 2.7.4
