Adding new arch/bsp to rtems tools
Denis Obrezkov denisobrezkov at gmail.com
Fri Jun 16 22:14:03 UTC 2017
Hello,
I want to compile examples-v2 for HiFive1 board.
I follow these steps in my blog but for new pair arch/bsp:
http://embeddedden.blogspot.de/2017/02/building-rtems-and-first-example.html
I've added new ini file rtems-bsps-riscv32.ini to rtems-tools/tester/rtems
and
hifive1.mc to rtems-tools/tester/rtems/testing/bsps and after rebuilding
the tools
(having the line
+ install
/home/reprofy/Projects/riscv/rtems/development/rtems/4.12/share/rtems/tester/rtems/testing/bsps/
hifive1.mc (from tester/rtems/testing/bsps/hifive1.mc)
during the process) I am trying to run configure for examples-v2:
./waf configure --rtems=$RTEMS_DEV/rtems/4.12
--rtems-tools=$RTEMS_DEV/rtems/4.12 --rtems-bsps=riscv32/hifive1
--rtems-version=4.12Setting top to                           :
/home/reprofy/Projects/riscv/rtems/development/examples-v2
Setting out to                           :
/home/reprofy/Projects/riscv/rtems/development/examples-v2/build
No valid arch/bsps found
(complete log in
/home/reprofy/Projects/riscv/rtems/development/examples-v2/build/config.log)
What should I do to make it work?
Regards, Denis Obrezkov
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170617/e697b6df/attachment-0001.html>
