[PATCH] Fix beagle bsp irq issue
punit vara punitvara at gmail.com
Sat Jun 17 15:14:54 UTC 2017
Good job Sichen. Keep it up
On Sat, Jun 17, 2017 at 8:01 PM, Sichen Zhao <1473996754 at qq.com> wrote:
> Enable/disable vector routines now check for a valid vector.
> Without these guards, the enable/disable vector routines
> will not work with the interrupt server.
>  c/src/lib/libbsp/arm/beagle/irq.c | 22 ++++++++++++++--------
>  1 file changed, 14 insertions(+), 8 deletions(-)
> diff --git a/c/src/lib/libbsp/arm/beagle/irq.c b/c/src/lib/libbsp/arm/beagle/irq.c
> index d080a5e..35750ba 100644
> --- a/c/src/lib/libbsp/arm/beagle/irq.c
> +++ b/c/src/lib/libbsp/arm/beagle/irq.c
> @@ -98,11 +98,14 @@ static uint32_t omap_get_mir_reg(rtems_vector_number vector, uint32_t *const mas
>  rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
>    uint32_t mask, cur;
> -  uint32_t mir_reg = omap_get_mir_reg(vector, &mask);
> -  cur = mmio_read(omap_intr.base + mir_reg);
> -  mmio_write(omap_intr.base + mir_reg, cur & ~mask);
> -  flush_data_cache();
> +  if (bsp_interrupt_is_valid_vector(vector)) {
> +    uint32_t mir_reg = omap_get_mir_reg(vector, &mask);
> +    cur = mmio_read(omap_intr.base + mir_reg);
> +    mmio_write(omap_intr.base + mir_reg, cur & ~mask);
> +    flush_data_cache();
>    return RTEMS_SUCCESSFUL;
> @@ -110,11 +113,14 @@ rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
>  rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
>    uint32_t mask, cur;
> -  mmio_write(omap_intr.base + mir_reg, cur | mask);
> +    mmio_write(omap_intr.base + mir_reg, cur | mask);
> 2.7.4
