Adding new arch/bsp to rtems tools
Denis Obrezkov
denisobrezkov at gmail.com
Sat Jun 17 17:54:59 UTC 2017
> I don't think that the tester subdirectory has anything to do with this
> Confirm that you can successfully 'waf configure' for the sparc/erc32.
> If not, the problem is somewhere in your command line or install
> point. Note that rtems-tools should point to the installed toolchain,
> and --rtems should point to the installed build of your BSP/rtems.
> Check that your 'make install' succeeded.
> > Regards, Denis Obrezkov
> > devel mailing list
> > devel at rtems.org
Thank you, I really forgot to "make install" after rtems building.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170617/a462434b/attachment-0001.html>
